Xperia X10III upgraded fine with no problems
X10 III updated. Got stuck in the end, but I got past it with the vol up + power button held.
Pretty clean install of SFOS. Only thing special are MicroG services and Chum. Nothing from openrepos.
For some unfathomable reason, I canāt help but recommend you to change the OS to something google.
Hm, I canāt connect to my hotmail.de account using the new exchange stuff. Should that work? It seems to redirect properly after prompting me for my data, but then fail setting up the account.
Well, not necessarily for a minor update, but a newer release would probably be more reasonable than patching the old one to address certain problems.
My best guess is that the package manager is waiting for input for some question it has, thereās no way to see it. I also guess that itās caused by some third-party package⦠I think Nettiradio caused it for me once (self-built was newer than the one in Jolla Store, both downgrade and vendor change), I try to reproduce it next week when I get back to my X10II.
@jovirkku How could I collect the logs from the upgrade process?
This is another 4.4.0 āsub-releaseā, so nothing groundbreaking is actually the expected state of it
My X10III and my sisters X10II (both on Elisa/FI) made a test call after the .72 install reboot, so at least that should work fine⦠Iāve encountered some ancient missed calls pop up with various versions after prolonged power off time, perhaps thatās the issue here? Has this happened to anyone else?
I remember reading somewhere that at least outlook.com accounts donāt work yet, but should be available with later release⦠Could someone please confirm that?
How about your home folder (pictures, downloads etc.)? Was Android support removed too? Getting packages removed is one thing, but deleted user data is another⦠Please open a bug ticket about that and provide all possible background information you can.
For my 10III the update brought back mobile data connections on german provider congstar (D1 network). Thanks jolla
But still the Hotspot doesnāt work - even with ssh-proxy
No real issues, but /vendor/etc/gps.conf is still replaced with a bogus default containing SUPL_HOST=supl.sonyericsson.com. This host doesnāt exist any more and everyone using @nekronās suplpatcher and a working SUPL_HOST has to manually edit the file after each an os update.
10 III also stuck at 100%, forced reboot and it worked fine. Feels snappier!
newpipe 0.24.0 crashes aliendalvik. 100% reproducible.
Log
Oct 01 20:30:01 Xperia10III lipstick[5717]: Launching Android Intent android.intent.action.MAIN org.schabi.newpipe/org.schabi.newpipe.MainActivity
Oct 01 20:30:01 Xperia10III booster-generic[5577]: *** signal=17 pid=5577
Oct 01 20:30:01 Xperia10III /usr/libexec/mapplauncherd/booster-generic[5577]: warning: Daemon: sending exit(0) to invoker(16878)
Oct 01 20:30:01 Xperia10III kernel: binder: 15948 RLIMIT_NICE not set
Oct 01 20:30:01 Xperia10III kernel: binder: 15714 RLIMIT_NICE not set
Oct 01 20:30:02 Xperia10III kernel: binder: 15729 RLIMIT_NICE not set
Oct 01 20:30:08 Xperia10III kernel: sec_ts 1-0048: [sec_input] [P] tID:0 x:70 y:99 z:25 major:6 minor:6 tc:1 type:0 noise:0
Oct 01 20:30:08 Xperia10III kernel: sec_ts 1-0048: [sec_input] [R] tID:0 mc:4 tc:0 lx:74 ly:100 v:0100 cal:A2 id(0,0) p:0 noise:0 lp:(0)
Oct 01 20:30:08 Xperia10III kernel: binder_do_set_priority: 1 callbacks suppressed
Oct 01 20:30:08 Xperia10III kernel: binder: 15729 RLIMIT_NICE not set
Oct 01 20:30:08 Xperia10III kernel: binder: 15948 RLIMIT_NICE not set
Oct 01 20:30:08 Xperia10III kernel: binder: 15714 RLIMIT_NICE not set
Oct 01 20:30:08 Xperia10III kernel: qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30010
Oct 01 20:30:08 Xperia10III kernel: binder: 15641 RLIMIT_NICE not set
Oct 01 20:30:08 Xperia10III pulseaudio[5794]: E: [pulseaudio] classify.c: could not find group
Oct 01 20:30:08 Xperia10III kernel: [aw882xx_smartpa]aw882xx_startup: capture enter
Oct 01 20:30:08 Xperia10III kernel: [aw882xx_smartpa]aw882xx_set_fmt: fmt=0x4001
Oct 01 20:30:08 Xperia10III kernel: msm_mi2s_snd_startup: set sysclk failed, err:-524
Oct 01 20:30:08 Xperia10III kernel: __afe_port_start: port id: 0x1001
Oct 01 20:30:08 Xperia10III kernel: afe_find_cal_topo_id_by_port: port id: 0x1001, dev_acdb_id: -22
Oct 01 20:30:08 Xperia10III kernel: afe_find_cal_topo_id_by_port: top_id:1000ff02 acdb_id:102 afe_port:0x1001
Oct 01 20:30:08 Xperia10III kernel: afe_get_cal_topology_id: port_id = 0x1001 acdb_id = 102 topology_id = 0x1000ff02 cal_type_index=8 ret=0
Oct 01 20:30:08 Xperia10III kernel: afe_send_port_topology_id: AFE set topology id 0x1000ff02 enable for port 0x1001 ret 0
Oct 01 20:30:08 Xperia10III kernel: send_afe_cal_type: cal_index is 1
Oct 01 20:30:08 Xperia10III kernel: send_afe_cal_type: dev_acdb_id[41] is -22
Oct 01 20:30:08 Xperia10III kernel: send_afe_cal_type: Sending cal_index cal 1
Oct 01 20:30:08 Xperia10III kernel: afe_send_hw_delay: port_id 0x1001 rate 48000 delay_usec 578 status 0
Oct 01 20:30:08 Xperia10III kernel: [aw882xx_smartpa]aw882xx_mute: mute state=0
Oct 01 20:30:08 Xperia10III kernel: [aw882xx_smartpa]aw882xx_startup: playback enter
Oct 01 20:30:08 Xperia10III kernel: __afe_port_start: port id: 0x1000
Oct 01 20:30:08 Xperia10III kernel: afe_find_cal_topo_id_by_port: port id: 0x1000, dev_acdb_id: 124
Oct 01 20:30:08 Xperia10III kernel: afe_find_cal_topo_id_by_port: top_id:1001025f acdb_id:124 afe_port_id:0x1000
Oct 01 20:30:08 Xperia10III kernel: afe_get_cal_topology_id: port_id = 0x1000 acdb_id = 124 topology_id = 0x1001025f cal_type_index=8 ret=0
Oct 01 20:30:08 Xperia10III kernel: afe_send_port_topology_id: AFE set topology id 0x1001025f enable for port 0x1000 ret 0
Oct 01 20:30:08 Xperia10III kernel: send_afe_cal_type: cal_index is 0
Oct 01 20:30:08 Xperia10III kernel: send_afe_cal_type: dev_acdb_id[40] is 124
Oct 01 20:30:08 Xperia10III kernel: afe_find_cal: cal_index 0 port_id 0x1000 port_index 40
Oct 01 20:30:08 Xperia10III kernel: afe_find_cal: acdb_id 124 dev_acdb_id 124 sample_rate 48000 afe_sample_rates 48000
Oct 01 20:30:08 Xperia10III kernel: afe_find_cal: cal block is a match, size is 868
Oct 01 20:30:08 Xperia10III kernel: send_afe_cal_type: Sending cal_index cal 0
Oct 01 20:30:08 Xperia10III kernel: afe_send_hw_delay: port_id 0x1000 rate 48000 delay_usec 474 status 0
Oct 01 20:30:08 Xperia10III kernel: [aw882xx_smartpa]aw882xx_smartpa_cfg: flag = 1, power status = 0
Oct 01 20:30:08 Xperia10III kernel: [aw882xx_smartpa]aw882xx_clear_sysint: get_sysint=0x4395
Oct 01 20:30:08 Xperia10III kernel: [aw882xx_smartpa]aw882xx_clear_sysint: get_sysint=0x0000
Oct 01 20:30:08 Xperia10III kernel: [aw882xx_smartpa]aw882xx_monitor_start: enter
Oct 01 20:30:08 Xperia10III kernel: [aw882xx_smartpa]aw882xx_monitor_get_data: vol: ipeak = 0x8, gain = 0x0, vmax = 0x0
Oct 01 20:30:08 Xperia10III kernel: [aw882xx_smartpa]aw882xx_monitor_get_data: temp: ipeak = 0x8, gain = 0x0, vmax = 0x0
Oct 01 20:30:08 Xperia10III kernel: [aw882xx_smartpa]aw882xx_monitor_set_ipeak: ipeak = 0x8, no change
Oct 01 20:30:08 Xperia10III kernel: [aw882xx_smartpa]aw882xx_monitor_set_gain: set db = 0.0 dB, no change
Oct 01 20:30:08 Xperia10III kernel: [aw882xx_smartpa]aw882xx_monitor_set_vmax: set vmax = 0x0
Oct 01 20:30:09 Xperia10III kernel: binder: 15641 RLIMIT_NICE not set
Oct 01 20:30:10 Xperia10III kernel: sec_ts 1-0048: [sec_input] [P] tID:0 x:946 y:254 z:35 major:9 minor:9 tc:1 type:0 noise:0
Oct 01 20:30:10 Xperia10III kernel: sec_ts 1-0048: [sec_input] [R] tID:0 mc:5 tc:0 lx:942 ly:255 v:0100 cal:A2 id(0,0) p:0 noise:0 lp:(0)
Oct 01 20:30:11 Xperia10III healthd: battery l=62 v=3905 t=37.2 h=2 st=3 c=-810242 fc=4486000 cc=32 chg=
Oct 01 20:30:11 Xperia10III kernel: sec_ts 1-0048: [sec_input] [P] tID:0 x:139 y:390 z:30 major:7 minor:7 tc:1 type:0 noise:0
Oct 01 20:30:11 Xperia10III kernel: sec_ts 1-0048: [sec_input] [R] tID:0 mc:5 tc:0 lx:142 ly:393 v:0100 cal:A2 id(0,0) p:0 noise:0 lp:(0)
Oct 01 20:30:12 Xperia10III connmand[5102]: Online check failed for 0xcc812e0 NETGEAR91-5G
Oct 01 20:30:13 Xperia10III kernel: sec_ts 1-0048: [sec_input] [P] tID:0 x:221 y:564 z:34 major:9 minor:9 tc:1 type:0 noise:0
Oct 01 20:30:13 Xperia10III kernel: sec_ts 1-0048: [sec_input] [R] tID:0 mc:2 tc:0 lx:222 ly:565 v:0100 cal:A2 id(0,0) p:0 noise:0 lp:(0)
Oct 01 20:30:13 Xperia10III kernel: binder_do_set_priority: 116 callbacks suppressed
Oct 01 20:30:13 Xperia10III kernel: binder: 15641 RLIMIT_NICE not set
Oct 01 20:30:14 Xperia10III kernel: binder: 15641 RLIMIT_NICE not set
Oct 01 20:30:15 Xperia10III [15672]: [C] unknown:0 - Cannot clear icon cache dir at ā/home/defaultuser/.cache/apkd-bridge-user/apkd-bridge-user/mpris/coverArtsā
Oct 01 20:30:15 Xperia10III kernel: sec_ts 1-0048: [sec_input] sec_ts_read_event: STATUS 1d 69 1 0 0 0 0 0
Oct 01 20:30:15 Xperia10III kernel: sec_ts 1-0048: [sec_input] sec_ts_read_event: STATUS 1d 69 0 0 0 0 0 0
Oct 01 20:30:15 Xperia10III kernel: msm_vidc: high: 00000001: ā¦d: Opening video instance: 0000000000000000, 1
Oct 01 20:30:16 Xperia10III [15672]: [C] unknown:0 - Cannot clear icon cache dir at ā/home/defaultuser/.cache/apkd-bridge-user/apkd-bridge-user/mpris/coverArtsā
Oct 01 20:30:16 Xperia10III bluetoothd[4208]: bluetoothd[4208]: Player registered: sender=:1.86 path=/_1_146
Oct 01 20:30:16 Xperia10III bluetoothd[4208]: Player registered: sender=:1.86 path=/_1_146
Oct 01 20:30:16 Xperia10III [15672]: [C] unknown:0 - Media ConverArt icon path: ā/home/defaultuser/.cache/apkd-bridge-user/apkd-bridge-user/mpris/coverArts/alien_mpris_coverArt.pngā
Oct 01 20:30:17 Xperia10III kernel: sec_ts 1-0048: [sec_input] [P] tID:0 x:241 y:827 z:35 major:9 minor:9 tc:1 type:0 noise:0
Oct 01 20:30:17 Xperia10III kernel: sec_ts 1-0048: [sec_input] [R] tID:0 mc:4 tc:0 lx:241 ly:830 v:0100 cal:A2 id(0,0) p:0 noise:0 lp:(0)
Oct 01 20:30:18 Xperia10III kernel: binder_do_set_priority: 176 callbacks suppressed
Oct 01 20:30:18 Xperia10III kernel: binder: 15641 RLIMIT_NICE not set
Oct 01 20:30:19 Xperia10III kernel: binder: 15641 RLIMIT_NICE not set
Oct 01 20:30:23 Xperia10III kernel: binder_do_set_priority: 155 callbacks suppressed
Oct 01 20:30:23 Xperia10III kernel: binder: 15641 RLIMIT_NICE not set
Oct 01 20:30:24 Xperia10III kernel: binder: 15641 RLIMIT_NICE not set
Oct 01 20:30:24 Xperia10III kernel: sec_ts 1-0048: [sec_input] [P] tID:0 x:799 y:1502 z:28 major:7 minor:7 tc:1 type:0 noise:0
Oct 01 20:30:26 Xperia10III kernel: sec_ts 1-0048: [sec_input] [R] tID:0 mc:177 tc:0 lx:909 ly:759 v:0100 cal:A2 id(0,0) p:0 noise:0 lp:(0)
Oct 01 20:30:26 Xperia10III kernel: sec_ts 1-0048: [sec_input] [P] tID:0 x:528 y:1254 z:33 major:8 minor:8 tc:1 type:0 noise:0
Oct 01 20:30:26 Xperia10III kernel: sec_ts 1-0048: [sec_input] [R] tID:0 mc:3 tc:0 lx:527 ly:1253 v:0100 cal:A2 id(0,0) p:0 noise:0 lp:(0)
Oct 01 20:30:28 Xperia10III kernel: msm_vidc: high: 00000001: h264d: Closed video instance: 0000000000000000
Oct 01 20:30:28 Xperia10III systemd[1]: Starting Cleanup of Temporary Directoriesā¦
Oct 01 20:30:28 Xperia10III systemd[1]: Started Cleanup of Temporary Directories.
Oct 01 20:30:28 Xperia10III bluetoothd[4208]: bluetoothd[4208]: Player unregistered: sender=:1.86 path=/_1_146
Oct 01 20:30:28 Xperia10III [15672]: [C] unknown:0 - Cannot clear icon cache dir at ā/home/defaultuser/.cache/apkd-bridge-user/apkd-bridge-user/mpris/coverArtsā
Oct 01 20:30:28 Xperia10III bluetoothd[4208]: Player unregistered: sender=:1.86 path=/_1_146
Oct 01 20:30:28 Xperia10III dbus-daemon[1872]: [system] Rejected send message, 2 matched rules; type=āerrorā, sender=":1.69" (uid=100000 pid=5717 comm="/usr/bin/lipstick -plugin evdevtouch -plugin evdev" label=āu:r:kernel:s0ā) interface="(unset)" member="(unset)" error name=āorg.freedesktop.DBus.Error.UnknownMethodā requested_reply=ā0ā destination=":1.3" (uid=0 pid=3120 comm="/usr/sbin/ohmd --no-daemon --mlock=none" label=āu:r:kernel:s0ā)
Oct 01 20:30:28 Xperia10III dbus-daemon[1872]: dbus-daemon[1872]: [system] Rejected send message, 2 matched rules; type=āerrorā, sender=":1.69" (uid=100000 pid=5717 comm="/usr/bin/lipstick -plugin evdevtouch -plugin evdev" label=āu:r:kernel:s0ā) interface="(unset)" member="(unset)" error name=āorg.freedesktop.DBus.Error.UnknownMethodā requested_reply=ā0ā destination=":1.3" (uid=0 pid=3120 comm="/usr/sbin/ohmd --no-daemon --mlock=none" label=āu:r:kernel:s0ā)
Oct 01 20:30:28 Xperia10III kernel: Core dump to |/bin/false disabled
Oct 01 20:30:28 Xperia10III kernel: binder: undelivered transaction 598923, process died.
Oct 01 20:30:28 Xperia10III sensorfwd[3303]: [SocketHandler]: Socket error: QLocalSocket::PeerClosedError
Oct 01 20:30:28 Xperia10III sensorfwd[3303]: [SocketHandler]: Noticed lost session: 47
Oct 01 20:30:28 Xperia10III sensorfwd[3303]: virtual bool HybrisAdaptor::setInterval(unsigned int, int) setInterval not ok
Oct 01 20:30:28 Xperia10III sensorfwd[3303]: [SocketHandler]: Noticed lost session: 42
Oct 01 20:30:28 Xperia10III sensorfwd[3303]: [SocketHandler]: Noticed lost session: 44
Oct 01 20:30:28 Xperia10III sensorfwd[3303]: [SocketHandler]: Noticed lost session: 46
Oct 01 20:30:28 Xperia10III kernel: binder: release 15672:15738 transaction 574695 in, still active
Oct 01 20:30:28 Xperia10III kernel: binder: send failed reply for transaction 574695 to 15858:15946
Oct 01 20:30:28 Xperia10III sensorfwd[3303]: [SocketHandler]: Noticed lost session: 43
Oct 01 20:30:28 Xperia10III sensorfwd[3303]: [SocketHandler]: Noticed lost session: 45
Oct 01 20:30:28 Xperia10III kernel: binder: undelivered transaction 598924, process died.
Oct 01 20:30:28 Xperia10III booster-qt5[5574]: *** signal=17 pid=5574
Oct 01 20:30:28 Xperia10III /usr/libexec/mapplauncherd/booster-qt5[5574]: warning: boosted process (pid=15672) signal(Segmentation fault)
Oct 01 20:30:28 Xperia10III /usr/libexec/mapplauncherd/booster-qt5[5574]: warning: Daemon: sending exit(1) to invoker(15675)
Oct 01 20:30:28 Xperia10III invoker[15675]: warning: application (pid=-1) exit(1) signal(0)
Oct 01 20:30:28 Xperia10III systemd[5534]: apkd-bridge-user.service: Main process exited, code=exited, status=1/FAILURE
Oct 01 20:30:28 Xperia10III systemd[5534]: apkd-bridge-user.service: Failed with result āexit-codeā.
Oct 01 20:30:28 Xperia10III init: Received control message āinterface_startā for āandroid.hardware.gnss@2.0::IGnss/defaultā from pid: 54 (/system/bin/hwservicemanager)
Oct 01 20:30:28 Xperia10III init: Could not find āandroid.hardware.gnss@2.0::IGnss/defaultā for ctl.interface_start
Oct 01 20:30:28 Xperia10III init: Received control message āinterface_startā for āandroid.hardware.gnss@1.1::IGnss/defaultā from pid: 54 (/system/bin/hwservicemanager)
Oct 01 20:30:28 Xperia10III init: Could not find āandroid.hardware.gnss@1.1::IGnss/defaultā for ctl.interface_start
Oct 01 20:30:28 Xperia10III init: Received control message āinterface_startā for āandroid.hardware.gnss@1.0::IGnss/defaultā from pid: 54 (/system/bin/hwservicemanager)
Oct 01 20:30:28 Xperia10III init: Could not find āandroid.hardware.gnss@1.0::IGnss/defaultā for ctl.interface_start
Oct 01 20:30:28 Xperia10III logd: logdr: UID=1000 GID=1000 PID=1198 n tail=127 logMask=19 pid=0 start=0ns timeout=0ns
Oct 01 20:30:28 Xperia10III logd: logdr: UID=1000 GID=1000 PID=1210 n tail=127 logMask=19 pid=0 start=0ns timeout=0ns
Oct 01 20:30:28 Xperia10III logd: logdr: UID=1000 GID=1000 PID=1213 n tail=127 logMask=19 pid=0 start=0ns timeout=0ns
Oct 01 20:30:28 Xperia10III init: Received control message āstopā for āwpa_supplicantā from pid: 256 (system_server)
Oct 01 20:30:28 Xperia10III init: Could not find āwpa_supplicantā for ctl.stop
Oct 01 20:30:28 Xperia10III kernel: msm_vidc: high: 00000001: ā¦d: Opening video instance: 0000000000000000, 1
Oct 01 20:30:28 Xperia10III kernel: binder_transaction: 10 callbacks suppressed
Oct 01 20:30:28 Xperia10III kernel: binder: 15858:16717 transaction failed 29189/-22, size 136-16 line 3099
Oct 01 20:30:28 Xperia10III kernel: binder_do_set_priority: 168 callbacks suppressed
Oct 01 20:30:28 Xperia10III kernel: binder: 15641 RLIMIT_NICE not set
Oct 01 20:30:29 Xperia10III kernel: binder: 15641 RLIMIT_NICE not set
Oct 01 20:30:29 Xperia10III init: Received control message āinterface_startā for āandroid.hardware.gnss@1.0::IGnss/defaultā from pid: 54 (/system/bin/hwservicemanager)
Oct 01 20:30:29 Xperia10III init: Could not find āandroid.hardware.gnss@1.0::IGnss/defaultā for ctl.interface_start
Oct 01 20:30:29 Xperia10III init: Untracked pid 1226 exited with status 0
Oct 01 20:30:29 Xperia10III init: Untracked pid 1228 exited with status 0
Oct 01 20:30:29 Xperia10III systemd[5534]: apkd-bridge-user.service: Service hold-off time over, scheduling restart.
Oct 01 20:30:29 Xperia10III systemd[5534]: apkd-bridge-user.service: Scheduled restart job, restart counter is at 1.
Oct 01 20:30:29 Xperia10III systemd[5534]: Stopped Bridge native data to Alien Dalvik.
Oct 01 20:30:29 Xperia10III systemd[5534]: Started Bridge native data to Alien Dalvik.
Oct 01 20:30:29 Xperia10III kernel: binder: undelivered TRANSACTION_COMPLETE
Oct 01 20:30:29 Xperia10III kernel: binder: undelivered transaction 601147, process died.
Oct 01 20:30:29 Xperia10III kernel: binder: 15581:16122 transaction failed 29189/-22, size 64-0 line 3099
Oct 01 20:30:29 Xperia10III kernel: binder_thread_write: 10 callbacks suppressed
Oct 01 20:30:29 Xperia10III kernel: binder: 15619:15619 BC_DEAD_BINDER_DONE 0000000000000001 not found
Oct 01 20:30:29 Xperia10III kernel: binder: 15131:15131 BC_DEAD_BINDER_DONE 0000000000000001 not found
Oct 01 20:30:29 Xperia10III apkd[5117]: [W] unknown:0 - package died! Trying to reconnect.
Oct 01 20:30:29 Xperia10III kernel: binder: 5117:5117 BC_DEAD_BINDER_DONE 0000000000000001 not found
Oct 01 20:30:29 Xperia10III kernel: binder: 5117:5117 BC_DEAD_BINDER_DONE 0000000000000004 not found
Oct 01 20:30:29 Xperia10III apkd[5117]: [W] unknown:0 - alien died! Trying to reconnect.
Oct 01 20:30:29 Xperia10III apkd[5117]: [W] unknown:0 - activity died! Trying to reconnect.
Oct 01 20:30:29 Xperia10III kernel: binder: 5117:5117 BC_DEAD_BINDER_DONE 0000000000000002 not found
Oct 01 20:30:29 Xperia10III kernel: binder: 5117:5117 BC_DEAD_BINDER_DONE 0000000000000003 not found
Oct 01 20:30:29 Xperia10III apkd[5117]: [W] unknown:0 - alarm died! Trying to reconnect.
Oct 01 20:30:29 Xperia10III kernel: binder: 15567:15740 transaction failed 29189/-22, size 116-8 line 3099
Oct 01 20:30:29 Xperia10III kernel: binder: 15131:15131 BC_DEAD_BINDER_DONE 0000000000000002 not found
Oct 01 20:30:29 Xperia10III [15131]: [W] unknown:0 - alien.contacts died! Trying to reconnect.
Oct 01 20:30:29 Xperia10III lipstick[5717]: [W] unknown:967 - file:///usr/share/lipstick-jolla-home-qt5/compositor.qml:967: TypeError: Cannot read property ācloseHintedā of null
Oct 01 20:30:29 Xperia10III init: Service āzygoteā (pid 39) received signal 9
Oct 01 20:30:29 Xperia10III init: Sending signal 9 to service āzygoteā (pid 39) process groupā¦
Oct 01 20:30:29 Xperia10III libprocessgroup: Successfully killed process cgroup uid 0 pid 39 in 0ms
Oct 01 20:30:29 Xperia10III init: Command āwrite /sys/power/state onā action=onrestart (<Service āzygoteā onrestart>:2) took 0ms and failed: Unable to write to file ā/sys/power/stateā: open() failed: Read-only file system
Oct 01 20:30:29 Xperia10III init: Sending signal 9 to service āaudioserverā (pid 50) process groupā¦
Oct 01 20:30:29 Xperia10III libprocessgroup: Successfully killed process cgroup uid 1041 pid 50 in 0ms
Oct 01 20:30:29 Xperia10III init: Sending signal 9 to service ācameraserverā (pid 57) process groupā¦
Oct 01 20:30:29 Xperia10III libprocessgroup: Successfully killed process cgroup uid 1047 pid 57 in 0ms
Oct 01 20:30:29 Xperia10III init: Sending signal 9 to service āmediaā (pid 66) process groupā¦
Oct 01 20:30:29 Xperia10III libprocessgroup: Successfully killed process cgroup uid 1013 pid 66 in 0ms
Oct 01 20:30:29 Xperia10III init: Sending signal 9 to service ānetdā (pid 38) process groupā¦
Oct 01 20:30:29 Xperia10III libprocessgroup: Successfully killed process cgroup uid 0 pid 38 in 0ms
Oct 01 20:30:29 Xperia10III init: Could not restart āwificondā: Cannot find ā/system/bin/wificond_ALIEN_DISABLEDā: No such file or directory
Oct 01 20:30:29 Xperia10III init: Received sys.powerctl=āshutdownā from pid: 1 (/system/bin/init)
Oct 01 20:30:29 Xperia10III init: Clear action queue and start shutdown trigger
Oct 01 20:30:29 Xperia10III init: processing action (shutdown_done) from (:0)
Oct 01 20:30:29 Xperia10III init: Reboot start, reason: shutdown, rebootTarget:
Oct 01 20:30:29 Xperia10III [15711]: [W] unknown:0 - Sensor not supported ( QAmbientLightSensor )
Oct 01 20:30:29 Xperia10III init: Shutdown timeout: 6000 ms
Oct 01 20:30:29 Xperia10III init: starting service āblank_screenāā¦
Oct 01 20:30:29 Xperia10III libprocessgroup: Failed to make and chown /acct/uid_1000: Read-only file system
Oct 01 20:30:29 Xperia10III init: createProcessGroup(1000, 1244) failed for service āblank_screenā: Read-only file system
Oct 01 20:30:29 Xperia10III init: Could not start shutdown critical service āhwservicemanagerā: Cannot find ā/system/bin/hwservicemanager_ALIEN_DISABLEDā: No such file or directory
Oct 01 20:30:29 Xperia10III init: terminating init services
Oct 01 20:30:29 Xperia10III init: Sending signal 15 to service āvendor.thermal-hal-1-0_ALIENā (pid 81) process groupā¦
Oct 01 20:30:29 Xperia10III init: Sending signal 15 to service āvendor.drm-hal-1-0_ALIENā (pid 79) process groupā¦
Oct 01 20:30:29 Xperia10III init: Sending signal 15 to service āgatekeeperdā (pid 70) process groupā¦
Oct 01 20:30:29 Xperia10III init: Sending signal 15 to service āmedia.swcodecā (pid 69) process groupā¦
Oct 01 20:30:29 Xperia10III init: Sending signal 15 to service āstoragedā (pid 68) process groupā¦
Oct 01 20:30:29 Xperia10III init: Sending signal 15 to service āstatsdā (pid 67) process groupā¦
Oct 01 20:30:29 Xperia10III init: Sending signal 15 to service āmediaā (pid 66) process groupā¦
Oct 01 20:30:29 Xperia10III init: Sending signal 15 to service āmediametricsā (pid 65) process groupā¦
Oct 01 20:30:29 Xperia10III init: Sending signal 15 to service āmediaextractorā (pid 64) process groupā¦
Oct 01 20:30:29 Xperia10III init: Sending signal 15 to service āmediadrmā (pid 63) process groupā¦
Oct 01 20:30:29 Xperia10III init: Sending signal 15 to service ākeystoreā (pid 62) process groupā¦
Oct 01 20:30:29 Xperia10III init: Sending signal 15 to service āinstalldā (pid 61) process groupā¦
Oct 01 20:30:29 Xperia10III init: Sending signal 15 to service āincidentdā (pid 60) process groupā¦
Oct 01 20:30:29 Xperia10III init: Sending signal 15 to service āidmap2dā (pid 59) process groupā¦
Oct 01 20:30:29 Xperia10III init: Sending signal 15 to service ādrmā (pid 58) process groupā¦
Oct 01 20:30:29 Xperia10III init: Sending signal 15 to service ācameraserverā (pid 57) process groupā¦
Oct 01 20:30:29 Xperia10III init: Sending signal 15 to service āmediacodec_ALIENā (pid 55) process groupā¦
Oct 01 20:30:29 Xperia10III init: Sending signal 15 to service ālmkdā (pid 52) process groupā¦
Oct 01 20:30:29 Xperia10III init: Sending signal 15 to service āgpuā (pid 51) process groupā¦
Oct 01 20:30:29 Xperia10III init: Sending signal 15 to service āaudioserverā (pid 50) process groupā¦
Oct 01 20:30:29 Xperia10III init: Sending signal 15 to service āashmemdā (pid 49) process groupā¦
Oct 01 20:30:29 Xperia10III init: Sending signal 15 to service āhealthdā (pid 48) process groupā¦
Oct 01 20:30:29 Xperia10III init: Sending signal 15 to service āsystem_suspendā (pid 47) process groupā¦
Oct 01 20:30:29 Xperia10III init: Sending signal 15 to service āhidl_memoryā (pid 46) process groupā¦
Oct 01 20:30:29 Xperia10III init: Sending signal 15 to service āvendor.hwcomposer-2-1ā (pid 45) process groupā¦
Oct 01 20:30:29 Xperia10III init: Sending signal 15 to service āvendor.drm-clearkey-hal-1-2ā (pid 44) process groupā¦
Oct 01 20:30:29 Xperia10III init: Sending signal 15 to service āvendor.configstore-halā (pid 43) process groupā¦
Oct 01 20:30:29 Xperia10III init: Sending signal 15 to service āvendor.audio-hal-2-0ā (pid 42) process groupā¦
Oct 01 20:30:29 Xperia10III init: Sending signal 15 to service āzygote_secondaryā (pid 40) process groupā¦
Oct 01 20:30:29 Xperia10III init: Sending signal 15 to service ānetdā (pid 38) process groupā¦
Oct 01 20:30:29 Xperia10III [15711]: [W] unknown:0 - Sensor not supported ( QCompass )
Oct 01 20:30:29 Xperia10III [15711]: [W] unknown:0 - Sensor not supported ( QRotationSensor )
Oct 01 20:30:29 Xperia10III systemd[1]: selinux: Unknown permission status for class system
Oct 01 20:30:29 Xperia10III init: Service āblank_screenā (pid 1244) exited with status 255
Oct 01 20:30:29 Xperia10III systemd[1]: selinux: Unknown class service
Oct 01 20:30:29 Xperia10III droid-hal-init: Control message: Could not find āandroid.hardware.graphics.allocator@2.0::IAllocator/defaultā for ctl.interface_start from pid: 3205 (/system/bin/hwservicemanager)
Oct 01 20:30:30 Xperia10III kernel: msm_vidc: err : ffffffff: ā¦: DBLP Set: status 0
Oct 01 20:30:32 Xperia10III kernel: [aw882xx_smartpa]aw882xx_mute: mute state=1
Oct 01 20:30:32 Xperia10III kernel: [aw882xx_smartpa]aw882xx_smartpa_cfg: flag = 0, power status = 2
Oct 01 20:30:32 Xperia10III kernel: [aw882xx_smartpa]aw882xx_monitor_stop: enter
Oct 01 20:30:32 Xperia10III kernel: [aw882xx_smartpa]aw882xx_stop: get_sysint=0x0000
Oct 01 20:30:32 Xperia10III kernel: afe_close: port_id = 0x1000
Oct 01 20:30:32 Xperia10III kernel: afe_close: port_id = 0x1001
Oct 01 20:30:32 Xperia10III kernel: sec_ts 1-0048: [sec_input] [P] tID:0 x:414 y:1402 z:27 major:7 minor:7 tc:1 type:0 noise:0
Oct 01 20:30:32 Xperia10III kernel: sec_ts 1-0048: [sec_input] [R] tID:0 mc:2 tc:0 lx:415 ly:1401 v:0100 cal:A2 id(0,0) p:0 noise:0 lp:(0)
Oct 01 20:30:32 Xperia10III invoker[6514]: WARNING: An inactive plugin is misbehaving - tried to show a window!
Oct 01 20:30:32 Xperia10III invoker[6514]: WARNING: requestActivate() called for QQuickView(0x284a3520) which has Qt::WindowDoesNotAcceptFocus set.
Oct 01 20:30:32 Xperia10III init: Terminating running services took 3002ms with remaining services:30
Oct 01 20:30:32 Xperia10III init: Sending signal 9 to service āvendor.thermal-hal-1-0_ALIENā (pid 81) process groupā¦
Oct 01 20:30:32 Xperia10III libprocessgroup: Successfully killed process cgroup uid 1000 pid 81 in 0ms
Oct 01 20:30:32 Xperia10III init: Sending signal 9 to service āvendor.drm-hal-1-0_ALIENā (pid 79) process groupā¦
Oct 01 20:30:32 Xperia10III libprocessgroup: Successfully killed process cgroup uid 1013 pid 79 in 0ms
Oct 01 20:30:32 Xperia10III init: Sending signal 9 to service āgatekeeperdā (pid 70) process groupā¦
Oct 01 20:30:32 Xperia10III libprocessgroup: Successfully killed process cgroup uid 1000 pid 70 in 0ms
Oct 01 20:30:32 Xperia10III init: Sending signal 9 to service āmedia.swcodecā (pid 69) process groupā¦
Oct 01 20:30:32 Xperia10III libprocessgroup: Successfully killed process cgroup uid 1046 pid 69 in 0ms
Oct 01 20:30:32 Xperia10III init: Sending signal 9 to service āstoragedā (pid 68) process groupā¦
Oct 01 20:30:32 Xperia10III libprocessgroup: Successfully killed process cgroup uid 0 pid 68 in 0ms
Oct 01 20:30:32 Xperia10III init: Sending signal 9 to service āstatsdā (pid 67) process groupā¦
Oct 01 20:30:32 Xperia10III libprocessgroup: Successfully killed process cgroup uid 1066 pid 67 in 0ms
Oct 01 20:30:32 Xperia10III init: Sending signal 9 to service āmediaā (pid 66) process groupā¦
Oct 01 20:30:32 Xperia10III libprocessgroup: Successfully killed process cgroup uid 1013 pid 66 in 0ms
Oct 01 20:30:32 Xperia10III init: Sending signal 9 to service āmediametricsā (pid 65) process groupā¦
Oct 01 20:30:32 Xperia10III libprocessgroup: Successfully killed process cgroup uid 1013 pid 65 in 0ms
Oct 01 20:30:32 Xperia10III init: Sending signal 9 to service āmediaextractorā (pid 64) process groupā¦
Oct 01 20:30:32 Xperia10III libprocessgroup: Successfully killed process cgroup uid 1040 pid 64 in 0ms
Oct 01 20:30:32 Xperia10III init: Sending signal 9 to service āmediadrmā (pid 63) process groupā¦
Oct 01 20:30:32 Xperia10III libprocessgroup: Successfully killed process cgroup uid 1013 pid 63 in 0ms
Oct 01 20:30:32 Xperia10III init: Sending signal 9 to service ākeystoreā (pid 62) process groupā¦
Oct 01 20:30:32 Xperia10III libprocessgroup: Successfully killed process cgroup uid 1017 pid 62 in 0ms
Oct 01 20:30:32 Xperia10III init: Sending signal 9 to service āinstalldā (pid 61) process groupā¦
Oct 01 20:30:32 Xperia10III libprocessgroup: Successfully killed process cgroup uid 0 pid 61 in 0ms
Oct 01 20:30:32 Xperia10III init: Sending signal 9 to service āincidentdā (pid 60) process groupā¦
Oct 01 20:30:32 Xperia10III libprocessgroup: Successfully killed process cgroup uid 1067 pid 60 in 0ms
Oct 01 20:30:32 Xperia10III init: Sending signal 9 to service āidmap2dā (pid 59) process groupā¦
Oct 01 20:30:32 Xperia10III libprocessgroup: Successfully killed process cgroup uid 1000 pid 59 in 0ms
Oct 01 20:30:32 Xperia10III init: Sending signal 9 to service ādrmā (pid 58) process groupā¦
Oct 01 20:30:32 Xperia10III libprocessgroup: Successfully killed process cgroup uid 1019 pid 58 in 0ms
Oct 01 20:30:32 Xperia10III init: Sending signal 9 to service ācameraserverā (pid 57) process groupā¦
Oct 01 20:30:32 Xperia10III libprocessgroup: Successfully killed process cgroup uid 1047 pid 57 in 0ms
Oct 01 20:30:32 Xperia10III init: Sending signal 9 to service āmediacodec_ALIENā (pid 55) process groupā¦
Oct 01 20:30:32 Xperia10III libprocessgroup: Successfully killed process cgroup uid 1046 pid 55 in 0ms
Oct 01 20:30:32 Xperia10III init: Sending signal 9 to service ālmkdā (pid 52) process groupā¦
Oct 01 20:30:32 Xperia10III libprocessgroup: Successfully killed process cgroup uid 1069 pid 52 in 0ms
Oct 01 20:30:32 Xperia10III init: Sending signal 9 to service āgpuā (pid 51) process groupā¦
Oct 01 20:30:32 Xperia10III libprocessgroup: Successfully killed process cgroup uid 1072 pid 51 in 0ms
Oct 01 20:30:32 Xperia10III init: Sending signal 9 to service āaudioserverā (pid 50) process groupā¦
Oct 01 20:30:32 Xperia10III libprocessgroup: Successfully killed process cgroup uid 1041 pid 50 in 0ms
Oct 01 20:30:32 Xperia10III init: Sending signal 9 to service āashmemdā (pid 49) process groupā¦
Oct 01 20:30:32 Xperia10III libprocessgroup: Successfully killed process cgroup uid 9999 pid 49 in 0ms
Oct 01 20:30:32 Xperia10III init: Sending signal 9 to service āhealthdā (pid 48) process groupā¦
Oct 01 20:30:32 Xperia10III libprocessgroup: Successfully killed process cgroup uid 0 pid 48 in 0ms
Oct 01 20:30:32 Xperia10III init: Sending signal 9 to service āsystem_suspendā (pid 47) process groupā¦
Oct 01 20:30:32 Xperia10III libprocessgroup: Successfully killed process cgroup uid 1000 pid 47 in 0ms
Oct 01 20:30:32 Xperia10III init: Sending signal 9 to service āhidl_memoryā (pid 46) process groupā¦
Oct 01 20:30:32 Xperia10III libprocessgroup: Successfully killed process cgroup uid 1000 pid 46 in 0ms
Oct 01 20:30:32 Xperia10III init: Sending signal 9 to service āvendor.hwcomposer-2-1ā (pid 45) process groupā¦
Oct 01 20:30:32 Xperia10III libprocessgroup: Successfully killed process cgroup uid 1000 pid 45 in 0ms
Oct 01 20:30:32 Xperia10III init: Sending signal 9 to service āvendor.drm-clearkey-hal-1-2ā (pid 44) process groupā¦
Oct 01 20:30:32 Xperia10III libprocessgroup: Successfully killed process cgroup uid 1013 pid 44 in 0ms
Oct 01 20:30:32 Xperia10III init: Sending signal 9 to service āvendor.configstore-halā (pid 43) process groupā¦
Oct 01 20:30:32 Xperia10III libprocessgroup: Successfully killed process cgroup uid 1000 pid 43 in 0ms
Oct 01 20:30:32 Xperia10III init: Sending signal 9 to service āvendor.audio-hal-2-0ā (pid 42) process groupā¦
Oct 01 20:30:32 Xperia10III libprocessgroup: Successfully killed process cgroup uid 1041 pid 42 in 0ms
Oct 01 20:30:32 Xperia10III init: Sending signal 9 to service āzygote_secondaryā (pid 40) process groupā¦
Oct 01 20:30:32 Xperia10III libprocessgroup: Successfully killed process cgroup uid 0 pid 40 in 0ms
Oct 01 20:30:32 Xperia10III init: Sending signal 9 to service ānetdā (pid 38) process groupā¦
Oct 01 20:30:32 Xperia10III libprocessgroup: Successfully killed process cgroup uid 0 pid 38 in 0ms
Oct 01 20:30:32 Xperia10III vdc: Waited 0ms for vold
Oct 01 20:30:32 Xperia10III kernel: binder: 15522:15528 transaction failed 29189/-22, size 92-0 line 3099
Oct 01 20:30:32 Xperia10III init: Sending signal 9 to service āvoldā (pid 8) process groupā¦
Oct 01 20:30:32 Xperia10III libprocessgroup: Successfully killed process cgroup uid 0 pid 8 in 0ms
Oct 01 20:30:32 Xperia10III init: Sending signal 9 to service ātombstonedā (pid 71) process groupā¦
Oct 01 20:30:32 Xperia10III libprocessgroup: Successfully killed process cgroup uid 1058 pid 71 in 0ms
Oct 01 20:30:32 Xperia10III init: Sending signal 9 to service ālogdā (pid 4) process groupā¦
Oct 01 20:30:32 Xperia10III libprocessgroup: Successfully killed process cgroup uid 1036 pid 4 in 0ms
Oct 01 20:30:32 Xperia10III init: sync() before umountā¦
Oct 01 20:30:32 Xperia10III init: sync() before umount took7ms
Oct 01 20:30:32 Xperia10III init: sync() after umountā¦
Oct 01 20:30:32 Xperia10III init: sync() after umount took1ms
Oct 01 20:30:32 Xperia10III kernel: msm_vidc: high: 00000001: h264d: Closed video instance: 0000000000000000
Oct 01 20:30:32 Xperia10III init: powerctl_shutdown_time_ms:3394:0
Oct 01 20:30:32 Xperia10III init: Reboot ending, jumping to kernel
Oct 01 20:30:32 Xperia10III alienaudioservice[15619]: [gbinder] WARNING: Service manager /dev/puddlejumper has died
Oct 01 20:30:32 Xperia10III kernel: binder: 15619:15619 BC_DEAD_BINDER_DONE 0000000000000000 not found
Oct 01 20:30:32 Xperia10III kernel: binder: 15645:15645 BC_DEAD_BINDER_DONE 0000000000000000 not found
Oct 01 20:30:32 Xperia10III kernel: binder: 15131:15131 BC_DEAD_BINDER_DONE 0000000000000000 not found
Oct 01 20:30:32 Xperia10III alienkeyboardservice[15645]: [gbinder] WARNING: Service manager /dev/puddlejumper has died
Oct 01 20:30:32 Xperia10III alienaudioservice[15619]: [gbinder] WARNING: Service manager /dev/vndpuddlejumper has died
Oct 01 20:30:32 Xperia10III alienaudioservice[15619]: [AlienAudioService] Service manager has died.
Oct 01 20:30:32 Xperia10III ofonod[3321]: [gbinder] WARNING! Service manager /dev/hwpuddlejumper has died
Oct 01 20:30:32 Xperia10III kernel: binder: 15711:15711 BC_CLEAR_DEATH_NOTIFICATION invalid ref 4
Oct 01 20:30:32 Xperia10III kernel: binder: 15711:15711 BC_CLEAR_DEATH_NOTIFICATION invalid ref 5
Oct 01 20:30:32 Xperia10III kernel: binder: 15619:15619 transaction failed 29189/-22, size 0-0 line 3099
Oct 01 20:30:32 Xperia10III kernel: binder: 15645:15645 transaction failed 29189/-22, size 0-0 line 3099
Oct 01 20:30:32 Xperia10III kernel: binder: 15131:15131 transaction failed 29189/-22, size 0-0 line 3099
Oct 01 20:30:32 Xperia10III kernel: binder: 5117:5117 transaction failed 29189/-22, size 0-0 line 3099
Oct 01 20:30:32 Xperia10III kernel: binder: 15711:15711 transaction failed 29189/-22, size 0-0 line 3099
Oct 01 20:30:33 Xperia10III systemd[1]: aliendalvik.service: Main process exited, code=exited, status=1/FAILURE
Oct 01 20:30:33 Xperia10III stop-aliendalvik.sh[17146]: lxc-attach: aliendalvik: attach.c: get_attach_context: 403 Failed to get init pid
Oct 01 20:30:33 Xperia10III stop-aliendalvik.sh[17146]: lxc-attach: aliendalvik: attach.c: lxc_attach: 1430 Failed to get attach context
Oct 01 20:30:33 Xperia10III systemd[5534]: selinux: Unknown class service
Oct 01 20:30:33 Xperia10III systemd[5534]: Stopping Alien Audio Serviceā¦
Oct 01 20:30:33 Xperia10III systemd[5534]: Stopped Alien Audio Service.
Oct 01 20:30:33 Xperia10III systemd[5534]: Stopping Alien Keyboard Serviceā¦
Oct 01 20:30:33 Xperia10III systemd[5534]: Stopped Alien Keyboard Service.
Oct 01 20:30:33 Xperia10III systemd[5534]: Stopping Bridge native data to Alien Dalvikā¦
Oct 01 20:30:33 Xperia10III /usr/libexec/mapplauncherd/booster-qt5[5574]: warning: terminating: booster:15131 invoker:15662 socket:16
Oct 01 20:30:33 Xperia10III /usr/libexec/mapplauncherd/booster-qt5[5574]: warning: Daemon: sending exit(1) to invoker(15662)
Oct 01 20:30:33 Xperia10III /usr/libexec/mapplauncherd/booster-qt5[5574]: warning: sending SIGTERM to booster (pid=15131)
Oct 01 20:30:33 Xperia10III systemd[5534]: Stopped Bridge native data to Alien Dalvik.
Oct 01 20:30:33 Xperia10III booster-qt5[5574]: *** signal=17 pid=5574
Oct 01 20:30:33 Xperia10III /usr/libexec/mapplauncherd/booster-qt5[5574]: warning: terminating: booster:15711 invoker:17067 socket:18
Oct 01 20:30:33 Xperia10III /usr/libexec/mapplauncherd/booster-qt5[5574]: warning: Daemon: sending exit(1) to invoker(17067)
Oct 01 20:30:33 Xperia10III /usr/libexec/mapplauncherd/booster-qt5[5574]: warning: sending SIGTERM to booster (pid=15711)
Oct 01 20:30:33 Xperia10III sensorfwd[3303]: [SocketHandler]: Socket error: QLocalSocket::PeerClosedError
Oct 01 20:30:33 Xperia10III sensorfwd[3303]: [SocketHandler]: Noticed lost session: 48
Oct 01 20:30:33 Xperia10III sensorfwd[3303]: virtual bool HybrisAdaptor::setInterval(unsigned int, int) setInterval not ok
Oct 01 20:30:33 Xperia10III sensorfwd[3303]: [SocketHandler]: Noticed lost session: 50
Oct 01 20:30:33 Xperia10III sensorfwd[3303]: [SocketHandler]: Noticed lost session: 52
Oct 01 20:30:33 Xperia10III sensorfwd[3303]: [SocketHandler]: Noticed lost session: 49
Oct 01 20:30:33 Xperia10III sensorfwd[3303]: [SocketHandler]: Noticed lost session: 53
Oct 01 20:30:33 Xperia10III sensorfwd[3303]: [SocketHandler]: Noticed lost session: 51
Oct 01 20:30:33 Xperia10III systemd[1]: aliendalvik.service: Failed with result āexit-codeā.
Oct 01 20:30:33 Xperia10III kernel: binder_transaction: 14 callbacks suppressed
Oct 01 20:30:33 Xperia10III kernel: binder: 5117:5117 transaction failed 29189/-22, size 0-0 line 3099
Oct 01 20:30:33 Xperia10III kernel: binder: 3321:3321 transaction failed 29189/-22, size 32-0 line 3099
Oct 01 20:30:34 Xperia10III kernel: binder: 5117:5117 transaction failed 29189/-22, size 0-0 line 3099
Oct 01 20:30:34 Xperia10III kernel: msm_vidc: err : ffffffff: ā¦: DBLP Set: status 0
Oct 01 20:30:34 Xperia10III kernel: binder: 3321:3321 transaction failed 29189/-22, size 32-0 line 3099
Oct 01 20:30:35 Xperia10III kernel: binder: 3321:3321 transaction failed 29189/-22, size 32-0 line 3099
Oct 01 20:30:35 Xperia10III kernel: binder: 5117:5117 transaction failed 29189/-22, size 0-0 line 3099
Oct 01 20:30:36 Xperia10III kernel: qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30010
Oct 01 20:30:36 Xperia10III kernel: binder: 5117:5117 transaction failed 29189/-22, size 0-0 line 3099
Oct 01 20:30:36 Xperia10III systemd[1]: aliendalvik.service: Service hold-off time over, scheduling restart.
Oct 01 20:30:36 Xperia10III systemd[1]: aliendalvik.service: Scheduled restart job, restart counter is at 4.
Oct 01 20:30:36 Xperia10III systemd[1]: Stopped Alien Dalvik.
Oct 01 20:30:36 Xperia10III systemd[1]: Starting Alien Dalvikā¦
Oct 01 20:30:36 Xperia10III systemd[17190]: aliendalvik.service: Executable /usr/bin/start-aliendalvik-preinit.sh missing, skipping: No such file or directory
Oct 01 20:30:36 Xperia10III systemd[17191]: aliendalvik.service: Executable /usr/sbin/start-aliendalvik-preinit.sh missing, skipping: No such file or directory
Oct 01 20:30:37 Xperia10III start-aliendalvik.sh[17195]: lxc-start: aliendalvik: utils.c: lxc_can_use_pidfd: 1772 Kernel does not support pidfds
Oct 01 20:30:37 Xperia10III start-aliendalvik.sh[17195]: lxc-start: aliendalvik: conf.c: turn_into_dependent_mounts: 3724 Invalid argument - Failed to recursively turn old root mount tree into dependent mount. Continuingā¦
Oct 01 20:30:37 Xperia10III kernel: EXT4-fs (loop21): VFS: Canāt find ext4 filesystem
Oct 01 20:30:37 Xperia10III kernel: ISOFS: Unable to identify CD-ROM format.
Oct 01 20:30:37 Xperia10III kernel: FAT-fs (loop21): bogus number of FAT structure
Oct 01 20:30:37 Xperia10III kernel: FAT-fs (loop21): Canāt find a valid FAT filesystem
Oct 01 20:30:37 Xperia10III start-aliendalvik.sh[17195]: lxc-start: aliendalvik: utils.c: safe_mount: 1198 No such file or directory - Failed to mount ā/dev/fb0ā onto ā/usr/lib64/lxc/rootfs/dev/fb0ā
Oct 01 20:30:37 Xperia10III start-aliendalvik.sh[17195]: lxc-start: aliendalvik: utils.c: safe_mount: 1198 No such file or directory - Failed to mount ā/dev/graphics/fb0ā onto ā/usr/lib64/lxc/rootfs/dev/graphics/fb0ā
Oct 01 20:30:37 Xperia10III start-aliendalvik.sh[17195]: lxc-start: aliendalvik: utils.c: __safe_mount_beneath_at: 1100 Function not implemented - Failed to open 44(proc)
Oct 01 20:30:37 Xperia10III start-aliendalvik.sh[17195]: lxc-start: aliendalvik: confile.c: get_config_unsupported_key: 158 Invalid argument - Unsupported config key ālxc.seccompā
Oct 01 20:30:37 Xperia10III start-aliendalvik.sh[17195]: lxc-attach: aliendalvik: attach.c: lxc_attach_run_command: 1808 No such file or directory - Failed to exec ā/system/bin/getpropā
Oct 01 20:30:37 Xperia10III start-aliendalvik.sh[17195]: Waiting for hwservicemanager
Oct 01 20:30:37 Xperia10III init: mkdir("/dev/pts", 0755) failed File exists
Oct 01 20:30:37 Xperia10III init: mknod("/dev/random", S_IFCHR | 0666, makedev(1, 8)) failed File exists
Oct 01 20:30:37 Xperia10III init: mknod("/dev/urandom", S_IFCHR | 0666, makedev(1, 9)) failed File exists
Oct 01 20:30:37 Xperia10III init: mknod("/dev/null", S_IFCHR | 0666, makedev(1, 3)) failed File exists
Oct 01 20:30:37 Xperia10III init: Init encountered errors starting first stage, ignoring
Oct 01 20:30:37 Xperia10III init: init first stage started!
Oct 01 20:30:37 Xperia10III init: [libfs_mgr]ReadFstabFromDt(): failed to read fstab from dt
Oct 01 20:30:37 Xperia10III init: [libfs_mgr]ReadDefaultFstab(): failed to find device default fstab
Oct 01 20:30:37 Xperia10III init: Failed to fstab for first stage mount
Oct 01 20:30:37 Xperia10III init: Using Android DT directory /proc/device-tree/firmware/android/
Oct 01 20:30:37 Xperia10III init: First stage mount skipped (missing/incompatible/empty fstab in device tree)
Ok, so just noticed that after the .72 update the Jolla Store tells me that I ādo not have any installed appsā. All my apps are actually there and working, its just that the Jolla store doesnāt seem to know about them anymore.
Openrepos works fine and recognises what I have installed and so does CHUM.
Somehow the store installed package list must have been deleted by the upgrade process. Any ideas?
Maybe you should install Utilities from Jolla and clear Package cache
Hi Steve, I observed the same yesterday. Today all apps were shown again without doing something particular.
I trie to install the update.
All went well at first, but after aprx. it said āupdate failedā. Now, the update is not available any longer and the phone already displaya the currebt release version. I just invoked āzypper dupā and I hope this will finish the process.
I can confirm exactly that. More precise: Itās about sending SMS. Receiving is possible even with 4G registered.
Question to jolla: Why arenāt such basic features not tested before rollout? Iād be happy to wait longer for an update, knowing that basic operations wonāt be compromised. I can only ask again: Please improve your QA.
It looks like is because VoLTE is enabled. But you have to remember that VoLTE is still in Beta.
Yes also by me on my Sony Xperia 10ii - I lost all cntact pictures and 2. the 4G network on sim1. I solved both with:
- open my backup and search in folder āPeople/dataā the file āall.vcfā and open it with the app contacts - after the import and restart the contact apps the pictures are back
- delete the sim1 pin in settings and reboot with volume+ and activate the pin for sim1 and wait a long time (60min)
Now no trouble.
The new function with microsoft365 work untill to the point, when the administrator is informed. Now I will see what microsoft will answering.
Call waiting switch in Phone settings still doesnāt work
āProblem with changing Call Waiting statusāā¦
Iām not brave enough to test if Call Barring options now work correctly.
To ask this here, too ⦠ist zstd REQUIRED or an option as of 4.5. See: Q: 4.5 will switch RPM compression. What does that mean for existing RPMs?
Thank you for precise and well elaborated bug report.
