weird thing, the brightness of the upgrade progress screen is very low, can barely see it. But it is progressing nicely so far
GPSInfo starts for me, but not sure which version of GPSInfo that is. On the other hand foilauth and sailfishconnect donāt. Foilauth canāt open ~/.local/share/foil/foil.key, sailfishconnect canāt connect to its background service via dbus. Sailfishconnect seems to have disabled sandboxing on their github in October, but never made a new release
So for Sailfishconnect, just update your desktop file to this: https://github.com/R1tschY/harbour-sailfishconnect/blob/master/app/harbour-sailfishconnect.desktop
Update here on my Xperia 10 II werenāt that successful, but however managed to got it installed. Presumably the update process got stuck even though it was actually ready all the time. I had to force reboot. Nevertheless, update installed and seems to be working normally
It looks like 4.3 provides libtinfo.so.5, but not libtinfo.so.6, and 4.4 provides libtinfo.so.6 but not libtinfo.so.5. That would mean separate builds for 4.3 and 4.4 for fish shell at least. Or, Iām missing something, which is also quite likely
Edit: Changelog has [ncurses] Enable ABI6 and move ABI5 libs to a separte package. but I can find no package to offer ABI5.
If passilic is started normally, itās unable to list saved password. As a workaround, itās necessary to start from terminal.
No VOLTE yet? Just checking on this much needed feature.
For me GPSInfo launches from the icon, and it asks for permissions (which I should narrow down actually). Make sure itās the OpenRepos version and not the Jolla Store version, OS upgrades tend to downgrade OpenRepos packages to whatever version Jolla Store offersā¦
I canāt install Storeman: It complains ā¦ānothing provides libsolv0ā.
Damnit, this will break basically everything running on console. Hopefully the mentioned compat package makes it into the final release.
EDIT: according to this there should be a compat package called ncurses-libs5. Hopefully this will resolve the libs correctly for old binaries.
EDIT: For detailed information on how to deal with this, see @olf 's guides below:
Original post:
I think that is because the install process picks up an older version of the storeman package (likely from the mentaljam Openrepos repo).
Current versions (from Chum) do not link against libsolv0.
So, download a current build for 4.3 from Chum and try with that.
Also, the description for Storeman-Installer on Openrepos states:
- Every SFOS release requires a configured OBS repository. Therefore Storeman installation may not be available for some time after a new SFOS release until maintainers configure a new repository. This is especially true for EA releases
I tried it with download from Chum repository built for 4.3. and get the same error
None of the versions on Chum works for me, alas.
Updated to Rauma 4.4.0.58 via command line and after reboot i can not activate SIM nor WIFI. Also no calls can be received.
Any attempts to get network up failed. Bluetooth also not working.
Any ideas?
ifconfig up also nothing; tells me no name even (no eth0 no enp4s0)
Installed the update, it actually worked through the GUI on the first try. It seems to work OK, but Iāve lost the ability to open a shell, because Iād previously installed fish and this no longer wants to start, since libncurses apparantly no longer exists:
fish: error while loading shared libraries: libncurses.so.5: cannot open shared object file: No such file or directory
I cannot login through SSH either, requesting a different shell is somehow simply ignored. This is problematic, since I always use the terminal to check whether the phone has gone off the rails (i.e. ofonod has gone into a feeding frenzy on my battery) and now I cannot open it, nor install other applications.
Thanks for the update. It seems less exciting in new features than previous ones, mainly bug fixes. But it looks the underlying platform is continuing its modernization (APIs, browser, etc.).
Looking forward for the stable release to install it on my device, and I wish VOLTE will come sooner than later (thatās one feature Iām aiming for as it will, hopefully, improve call quality a lot).
The same here on X10: On trying to install from .rpm file, phone says: xdg-open not found !
it reports 'nothing provides ālibsolv0ā needed by the to be installed harbour ā¦
Yes, I tried using fastboot to boot hybris-recovery.img, but itās stuck at āsendingā. No idea whatās wrong there, I am using a data cable and when I remove it it immediately exits with an error.
Ok, looks like we have some sailjail glitches now:
- Syncdings cannot startup syncthing anymore
- AdvancedCam pictures from sdcard are not shown in gallery
- Sailpass ist not able to select the sdcard (where I have my keys)
ā¦
