I don’t know how well it will support a system that has been in use for a time, but I recently bought an XA2 to test SailfishOS, and when I flashed SFOS using the initial instructions, I then flashed the latest driver bundle from Sony, and it seems to be working properly.
AAS has nothing to do with the android vendor image you have to use during the installation.
Thank you for your comments. I’ve understood that it is at least safe to try the latest vendor image and then rollback if issues surface.
