quick question: how were you able to fix this with MeeCast? it doesn’t work for me. and I haven’t read a solution here yet.
Thank you very much
@OhneZ This instruction helped me with same issue on 5.0.0.55:
Updated X10III from 5.0.0.55->61 without any issue.
Noticed a rather funny thing : some menu entries in Jolla Store display in French (Jeux and Places de marché ).
The others (Activity, New Apps…) are in English (the phone is in EN UK; the SIM card is French, but would be strange ).
I don’t for how long it has been like that, it may even predate v5.
I think the names in the Jolla store are translated based on the language your Jolla account is set to, not the language of the device.
Well, store translation gods have chosen Frenglish
Some labels EN, some FR.
I just checked and my jolla (shop.jolla.com) account displays all in EN and has no language choices.
Probably a bug, but easy to live with.
Any guestimates when it will fully usable? Screen of my XA2 Plus is degrading, generates false events time-to-time (known tipical way how much jis model dies), 10V is on the drawer flashed with SFOS but cannot use it…
that would be sad to fall between the chairs…
For me this helped on xperia 10III lateat sw.
turn on untrusted software
download and install this (meecast)
after download and install meecast deamon
and now the app keeps the settings and the saved cities after closing the app.
i installed from file manager the aarch64 version.
you can try installing the rest of the meecast packages. (didnt worked for me.)
For me an update in openrepos for meecast eventsview was indicated but I could not install it. It said no package found. I uninstalled meecast eventsview. Then checked if I still have lipstick-jolla-home-qt5-weather-widget-settings, which I didn’t. So I installed this package with pkcon and then reinstalled meecast eventsview. Then restartet and weather on events view worked again.
what is the situation with chum at the moment?
or openrepos for that matter.
can they be installed on 5.0.0.61 yet?
Chum works from the first 5.0 release all you need to set the repos to 4.6.
Can’t find it in Chum on C2. Is that really the package name?
With the default settings it is not shown in search results. You have to go to the settings and deselect “show only applications” first
Thanks. Unfortunately I still can’t find it.
Is it because the repos are set to 4.3.0.15 and I can’t change it? Didn’t notice that before.
I’m sorry, it is not from chum, you have to install it using pkcon from the command line:
Open terminal as root (devel-su):
pkcon install lipstick-jolla-home-qt5-weather-widget-settings
Thanks. I could install that but not Eventview due to “unchangable” 4.3.0.15 repo setting in my previous post.
Chum is already on SFOS 5, so you can disable version setting.
Xperia 10 Dual SIM - Update after reset to 4.4.0.72 worked in two steps (4.5.0.25 in between) without any issues.
After this, I reflashed again to get the larger root partition. This also worked perfectly.
Thanks very much Jollyboys!
edit: in the step in between, on 4.5.0.25, I also did 2 reboots and some little UI interactions for testing before proceeding to next update to 5.0.0.61
I inserted my SIM Card in slot 1 (previously in slot 2). I have rebooted the system, I have stopped and started the Androiod App Support, VoLTE ist registered. But still my Android Apps (like Spotify) cannot connect via mobile data.
Did the same happens on 5.0.0.62?
I have to do the following steps after each reboot:
- stop AppSupport
- disable SIM1
- enable SIM1
- start AppSupport
Then mobile data works in AppSupport
