After that, I also need to enable mobile data separately in sim card settings on App support.
Please update to 5.0.0.62 an check if the problem consists. There have been work on that problem.
Before 5.0.0.62 I did not have a any method to enable mobile data on App Support. SIM card was not recognised in any situation what i tried.
Has the out of memory killer behaviour got worse in 5.0.0.61 on the 10iii?
I’m resigned to its behaviour in the web browser - with it constantly forcing a page reload.
However, never in all my years on SFOS4 do i recall it interfering with the EPUB reader app.
Behaviour:
#1 - force reload of the app (irritating but acceptable)
#2 - after reload, forgetting the page (completely infuriating)
Done this to me half a dozen times now - to the point where i keep a note of the page I last left the book on!
I am presuming this isn’t an app problem, but I might be wrong here.
No changes per se and there have not been changes OOM after 10 III was launched. The next update will have adjustments which hopefully improve situation.
See also Sailfish Community News, 20th March 2025 - Upgrade jenga
cheers. wonder what the change was that meant ebook reader on 4.6.0.15 didn’t refresh to zero where that is what happens in 5.0.0.61…
Lock/unlock no longer seems to work, rotation starts working after good 5-10 minutes after reboot (csd trick still works, but why the 5+ minutes waittime, some kind of timeout needs to be hit)
Not a EA user, but had the same problem. I even talked to support and nobody could figure out what it was. Installed the update just now. Thanks a lot!
@maikek, are you still on 5.0.0.61?
ts 5.0.0.78, why do you ask?
