The gyro test failed but the rotation started working after its exrcution, thanks for the suggestion!
Hydrogen breaks? Browser issue?
Hmm works here (C2, hydrogen 0.5.1) do you have any error in the console?
Updated today my new C2. All fine. Not visible change.
Nvm, there was a process running/stuck. Killed it and its working again
Thanks Jolla,
Downloading went quite fast and updates were even faster on both C2 and Mind2.
Just quick reboots and everything was working.
Maybe it did help to stop before update App Support and all apps on C2 and stop
venho-ada.service on Mind2.
Only login errors on Mind2 occurred, but that was seemingly solved
by clearing browsers’ caches.
Encountered the same issue as @eson, was fixed by suggested commands by @Keto
Otherwise update went fine.
No issue updating on my 10III and sending sms while 5G active works.
Hyvää
Please also see Sailfish Community News, 20th February 2025 - Sailfish 5.0 for all for a bit of background information. There’s also a nice summary by @makrolon regarding Tampella on the comments.
My Jolla C2 is in a boot loop and the support doesn’t answer my ticket. A new image might fix the problem. So is it possible to download the new release from Index of /images/?
Not before official release. You could download 5.0.0.43, and do OTA update from there.
I’ve already downloaded 5.0.43. Since them I have the boot loop.
Ahh… my bad. I totally misunderstood that you were on the latest EA release.
It seems ~ I have no measurements ~ that the connection is more stable when commuting. And, hence, better battery lifetime.
Thank you for the update! Everything went well on my Sony Xperia XA2, 10 II and Jolla C2. The C2 needed a reboot for the screen rotation to work again. Today I will finally start up my Mind2 for the first time, got it a week ago. So more updating is on the line…
Just a small curious notion; when going into “Settings → About product” on “Add-ons” i get sometimes all the add-ons; “MS Exchange, Predictive Text Input and AppSupport”, but sometimes nothing; just a dash instead, like I wouldn’t have any.
(X10III 5.0.0.61 - didn’t observe such behaviour before)
Yes, it is not always correct. Mine always says
MS Exchange, although I’ve never had it installed.
I’m still waiting for the upgrade for mine Xperia 10!!! .
No point in screaming about that here. Either enable Early Access in your account settings, or be patient a bit longer.
Both 5.0.x updates installed well on my XA2. The Phone got more responsive and faster. However, the battery drains much faster. I used to recharge every 2 days. Now I have to recharge every day. I already tried different use pattern (with and without apps open, AAO…). It does not seem to be related to an app. Drainage also happens during night. Are there other users having the same problem?
