Please give this a try: Changelog_from_4.6.0.15_to_5.0.0.55.md
because i did not read this and also i have free trial on my test Xperia10Plus so i dont have available updates from the UI, so i always updating from terminal via ssh
ssu release 5.0.0.55
version --dup
reboot
all works fine, so what could go wrong or is there some missed lunch of scripts or something else by updating from terminal?
Help needed: TLDR - How to sync/install to the latest state (5.0.0.55).
If tried to update a Xperia 10 (i4113) from 4.6.0.13 to 5.0.0.55 via GUI.
Started the reboot, update with progress, then a screen saying “something went wrong, with a restart button”. I restarted the phone and it booted into the OS. It seems that only a part of the rpm package were installed.
Normally the directory under /home/.pk-zypp-dist-upgrade-cache does not have any packages after the update anymore. Currently I see that some (274) are still there:
[root@Sailfish .pk-zypp-dist-upgrade-cache]# find . |grep rpm$|wc -l
274
I have totally 985 packages on the system but only 337 package are installed today (updated).
For instance, a newer package of sailfish-office is in the cache directory and not installed:
# rpm -q sailfish-office
sailfish-office-1.6.8-1.8.3.jolla.armv7hl
# find /home/.pk-zypp-dist-upgrade-cache/ |grep sailfish-office
/home/.pk-zypp-dist-upgrade-cache/packages/apps/apps/armv7hl/sailfish-office-1.6.10-1.10.1.jolla.armv7hl.rpm
The GUI says I am on 5.0.0.55 and
$ grep VER /etc/os-release
VERSION="5.0.0.55 (Tampella)"
VERSION_ID=5.0.0.55
but I am sure that is only the half of the story. Albeit, I could boot into the OS in this current state!
So, how do I sync/install to the latest state (5.0.0.55)? Thanks!
Update: I did following:
# ssu release 5.0.0.55
Changing release from 4.6.0.13 to 5.0.0.55
Your device is now in release mode!
[root@Sailfish ~]# version --dup
REFRESHING CACHE AND DOWNLOADING PACKAGES
Finished transaction (status=1, runtime=25144ms)
UPGRADING SYSTEM
Finished transaction (status=1, runtime=144483ms)
FINISHING
Download (7 packages)
Install (281 packages)
as you can see it installed the rest of the rpms from /home/.pk-zypp-dist-upgrade-cache but
I can not boot into the system anymore. The LUKS/Password unlock UI does not appear after the reboot
anymore. Trying to ssh into it shows:
"System is booting up. Unprivileged users are not permitted to log in yet. Please come back later. For technical details, see pam_nologin(8)."
Any help?
For now it needs to be installed manually, it is a feature that is available for those who are interested and based on feedback we will improve it for 5.1 when it is installed with the OS upgrade. Install the wireguard packages with:
pkcon install jolla-settings-networking-plugin-vpn-wireguard
and then restart phone (or just connman: systemctl restart connman).
what about
version --dup
See my update above …
Flawlessly updated via GUI on an Xperia 10 III. It all works as before.
Really looking forward to the MicroG instructions as the Swiss Postfinance Banking app does not work with MicroG 3.6.
The new browser does not show the salesforce website either. Not sure how to report this as the website is password protected but works in Fennec at least.
sorry I tried all possible option, Disable enable WLAn, Flightmode, restarting appsupport, but nothing helped, No data connection in appsupport
ah sorry to read this
i see only difference that i updated from 4.6.0.15 (xperia10plus is same as your 10 but with bigger screen - no hw issue expected)
i ques that you have disabled all patches before updating
these 7 new packages were from jollastore? but it should not be the problem…
anyway i would expect fail to boot after interrupted update, not after finishing, but who knows it is early access so we must count that anything could fail
well i think that faster way will be reflash ![]()
edit: i have this version of blob SW_binaries_for_Xperia_Android_9.0_2.3.2_v9_ganges
edit2: don’t you have a list of packages what failed to install in first step. it may help developers to identify which one could did it
Somehow GUI Settings download always stopped at 5-10% and other glitches. Had to upgrade via root-terminal and upgrade went without errors. XA2 SailfishOS 5.0 is really smooth experience! Thank you.
No way to upload txt files. Therefore this way :
LIST FAILED STATE
abseil-cpp-20230802.1+git1-1.2.2.jolla.armv7hl acl-2.3.1+git2-1.6.20.jolla.armv7hl aliendalvik-1.8.0-1.5.1.jolla.armv7hl aliendalvik-configs-11.0.168-1.37.1.jolla.armv7hl all-translations-pack-0.8.2-1.5.3.jolla.noarch alsa-lib-1.2.8+git1-1.6.2.jolla.armv7hl amber-mpris-1.2.9-1.9.2.jolla.armv7hl amber-qml-plugin-mpris-1.2.9-1.9.2.jolla.armv7hl ambienced-0.29.34-1.9.2.jolla.armv7hl apkd8-11.0.0.69.1-1.22.1.jolla.armv7hl apkd8-android-settings-11.0.0.69.1-1.22.1.jolla.armv7hl apkd8-l10n-all-translations-1.88.2-1.12.1.jolla.noarch apkd-plugin-geo-qtpositioning-1.0.1-1.2.1.jolla.armv7hl apkd-plugin-launchers-fdo-ext-1.4.2-1.4.1.jolla.armv7hl apkd-plugin-media-mpris-1.0.3-1.3.1.jolla.armv7hl apkd-plugin-notifications-fdo-ext-1.0.4-1.1.2.jolla.armv7hl apkd-plugin-permissions-sfos-1.3.0-1.4.1.jolla.armv7hl appsupport11-system-privileged-11.0.0.76.53-1.16.1.jolla.armv7hl appsupportaudio-1.33.0-1.5.1.jolla.armv7hl appsupportaudio-plugin-pulseaudio-1.25.1-1.2.1.jolla.armv7hl appsupportaudio-plugin-sailfish-1.7.0-1.1.1.jolla.armv7hl appsupport-config-generator-1.12.5-1.21.1.jolla.armv7hl appsupportkeyboardservice-1.0.2-1.3.1.jolla.armv7hl archivemount-0.9.1+git2-1.6.4.jolla.armv7hl audiosystem-passthrough-1.3.1-1.5.1.jolla.armv7hl audiosystem-passthrough-dummy-af-1.3.1-1.5.1.jolla.armv7hl audit-libs-3.1.2+git1-1.9.2.jolla.armv7hl audit-libs-python3-3.1.2+git1-1.9.2.jolla.armv7hl augeas-libs-1.12.0+git4-1.6.4.jolla.armv7hl basesystem-11+git1-1.5.3.jolla.noarch binder-utils-1.0.7-1.4.1.jolla.armv7hl bindfs-1.13.10+git1-1.2.1.jolla.armv7hl bind-utils-9.11.19+git2-1.2.2.jolla.armv7hl binutils-2.42+git1-1.8.3.jolla.armv7hl bluebinder-1.0.18-1.3.2.jolla.armv7hl bluez5-5.72+git1-1.9.2.jolla.armv7hl bluez5-libs-5.76+git2-1.11.1.jolla.armv7hl bluez5-obexd-5.72+git1-1.9.2.jolla.armv7hl bluez5-tools-5.72+git1-1.9.2.jolla.armv7hl bluez5-tools-hciattach-5.72+git1-1.9.2.jolla.armv7hl boost-atomic-1.81.0+git2-1.8.3.jolla.armv7hl boost-chrono-1.81.0+git2-1.8.3.jolla.armv7hl boost-date-time-1.81.0+git2-1.8.3.jolla.armv7hl boost-filesystem-1.81.0+git2-1.8.3.jolla.armv7hl boost-system-1.81.0+git2-1.8.3.jolla.armv7hl boost-thread-1.81.0+git2-1.8.3.jolla.armv7hl busybox-1.36.1+git6-1.13.1.jolla.armv7hl busybox-symlinks-coreutils-1.36.1+git6-1.13.1.jolla.armv7hl busybox-symlinks-dhcp-1.36.1+git6-1.13.1.jolla.armv7hl busybox-symlinks-diffutils-1.36.1+git6-1.13.1.jolla.armv7hl busybox-symlinks-dosfstools-1.36.1+git6-1.13.1.jolla.armv7hl busybox-symlinks-findutils-1.36.1+git6-1.13.1.jolla.armv7hl busybox-symlinks-grep-1.36.1+git6-1.13.1.jolla.armv7hl busybox-symlinks-gzip-1.36.1+git6-1.13.1.jolla.armv7hl busybox-symlinks-procps-1.36.1+git6-1.13.1.jolla.armv7hl busybox-symlinks-psmisc-1.36.1+git6-1.13.1.jolla.armv7hl busybox-symlinks-sed-1.36.1+git6-1.13.1.jolla.armv7hl busybox-symlinks-tar-1.36.1+git6-1.13.1.jolla.armv7hl busybox-symlinks-which-1.36.1+git6-1.13.1.jolla.armv7hl buteo-mtp-qt5-0.9.8-1.9.3.jolla.armv7hl buteo-syncfw-qt5-0.11.3-1.21.3.jolla.armv7hl buteo-syncfw-qt5-msyncd-0.11.3-1.21.3.jolla.armv7hl buteo-sync-plugin-caldav-0.3.12-1.14.2.jolla.armv7hl buteo-sync-plugin-carddav-0.1.10-1.11.2.jolla.armv7hl buteo-sync-plugin-nextcloud-backup-1.0.9-1.10.1.jolla.armv7hl buteo-sync-plugin-nextcloud-images-1.0.9-1.10.1.jolla.armv7hl buteo-sync-plugin-nextcloud-posts-1.0.9-1.10.1.jolla.armv7hl buteo-sync-plugins-email-0.1.10-1.9.3.jolla.armv7hl buteo-sync-plugins-social-0.4.24-1.17.1.jolla.armv7hl buteo-sync-plugins-social-dropbox-0.4.24-1.17.1.jolla.armv7hl buteo-sync-plugins-social-facebook-0.4.24-1.17.1.jolla.armv7hl buteo-sync-plugins-social-google-0.4.24-1.17.1.jolla.armv7hl buteo-sync-plugins-social-onedrive-0.4.24-1.17.1.jolla.armv7hl buteo-sync-plugins-social-twitter-0.4.24-1.17.1.jolla.armv7hl buteo-sync-plugin-webcal-0.1.11-1.8.6.jolla.armv7hl bzip2-1.0.8+git2-1.6.6.jolla.armv7hl bzip2-libs-1.0.8+git2-1.6.6.jolla.armv7hl ca-certificates-2023.2.62_v7.0.401-1.6.1.jolla.noarch cairo-1.18.0+git1-1.8.3.jolla.armv7hl calligra-components-3.2.1+git4-1.11.6.jolla.armv7hl calligra-data-3.2.1+git5-1.12.2.jolla.armv7hl calligra-filters-3.2.1+git4-1.11.6.jolla.armv7hl calligra-kf5-3.2.1+git4-1.11.6.jolla.armv7hl calligra-libs-3.2.1+git4-1.11.6.jolla.armv7hl calligra-plugins-3.2.1+git4-1.11.6.jolla.armv7hl calligra-sheets-core-3.2.1+git4-1.11.6.jolla.armv7hl calligra-stage-core-3.2.1+git4-1.11.6.jolla.armv7hl calligra-words-core-3.2.1+git4-1.11.6.jolla.armv7hl checkpolicy-3.1+git2-1.4.5.jolla.armv7hl commhistory-daemon-0.8.45-1.11.2.jolla.armv7hl connectionagent-qt5-0.12.5-1.10.1.jolla.armv7hl connectionagent-qt5-declarative-0.12.5-1.10.1.jolla.armv7hl connman-1.38+git12-1.31.1.jolla.armv7hl connman-configs-sailfish-0.11.17-1.15.1.jolla.noarch connman-network-monitor-0.0.0+git3-1.6.1.jolla.armv7hl connman-plugin-vpn-l2tp-1.38+git12-1.31.1.jolla.armv7hl connman-plugin-vpn-openconnect-1.38+git12-1.31.1.jolla.armv7hl connman-plugin-vpn-openvpn-1.38+git12-1.31.1.jolla.armv7hl connman-plugin-vpn-pptp-1.38+git12-1.31.1.jolla.armv7hl connman-plugin-vpn-vpnc-1.38+git12-1.31.1.jolla.armv7hl connman-qt5-1.4.11-1.19.1.jolla.armv7hl connman-qt5-declarative-1.4.11-1.19.1.jolla.armv7hl connman-tools-1.38+git12-1.31.1.jolla.armv7hl connman-vpn-scripts-1.38+git12-1.31.1.jolla.armv7hl contactsd-1.4.14-1.17.4.jolla.armv7hl cor-0.1.21-1.4.8.jolla.armv7hl cpio-2.15+git1-1.8.3.jolla.armv7hl crda-4.14+git5-1.6.7.jolla.armv7hl cryptsetup-2.4.3+git1-1.5.3.jolla.armv7hl cryptsetup-libs-2.4.3+git1-1.5.3.jolla.armv7hl csd-0.16.47-1.13.1.jolla.armv7hl curl-8.9.1+git1-1.11.2.jolla.armv7hl db4-4.8.30-1.6.6.jolla.armv7hl db4-utils-4.8.30-1.6.6.jolla.armv7hl dbus-1.14.10+git1-1.7.1.jolla.armv7hl dbusextended-qt5-0.0.3-1.2.1.jolla.armv7hl dbus-glib-0.100.2-1.4.6.jolla.armv7hl dbus-libs-1.14.10+git1-1.7.1.jolla.armv7hl dconf-0.40.0+git5-1.9.2.jolla.armv7hl declarative-transferengine-qt5-1.1.6-1.1.2.jolla.armv7hl deltarpm-3.6.3+git1-1.6.12.jolla.armv7hl desktop-file-utils-0.26+git4-1.7.4.jolla.armv7hl device-mapper-2.02.177+git6-1.7.4.jolla.armv7hl device-mapper-event-2.02.177+git6-1.7.4.jolla.armv7hl device-mapper-event-libs-2.02.177+git6-1.7.4.jolla.armv7hl device-mapper-libs-2.02.177+git6-1.7.4.jolla.armv7hl dirmngr-1.0.3+git3-1.7.2.jolla.armv7hl droid-config-i4113-0.0.74-1.9.1.jolla.armv7hl droid-config-i4113-bluez5-0.0.74-1.9.1.jolla.armv7hl droid-config-i4113-flashing-0.0.78-1.12.1.jolla.armv7hl droid-config-i4113-policy-settings-0.0.78-1.12.1.jolla.armv7hl droid-config-i4113-preinit-plugin-0.0.78-1.12.1.jolla.armv7hl droid-config-i4113-pulseaudio-settings-0.0.78-1.12.1.jolla.armv7hl droid-config-i4113-sailfish-0.0.74-1.9.1.jolla.noarch droid-hal-kirin-0.0.59-1.10.5.jolla.armv7hl droid-hal-kirin-detritus-0.0.59-1.10.5.jolla.armv7hl droid-hal-kirin-img-boot-4.9.210.20240702.1-1.4.10.jolla.armv7hl droid-hal-kirin-img-recovery-4.9.210.20240702.1-1.4.10.jolla.armv7hl droid-hal-kirin-tools-0.0.59-1.10.5.jolla.armv7hl droid-hal-kirin-users-0.0.59-1.10.5.jolla.armv7hl droid-hal-version-i4113-1.0.0-1.4.8.jolla.armv7hl droidmedia-0.20240905.0-1.9.1.jolla.armv7hl droid-system-kirin-0.1.0-1.2.1.jolla.armv7hl droid-system-kirin-i4113-0.1.0-1.2.1.jolla.armv7hl droid-system-vendor-kirin-0.1.0-1.2.1.jolla.armv7hl droid-system-vendor-kirin-i4113-0.1.0-1.2.1.jolla.armv7hl dsme-0.84.0-1.6.5.jolla.armv7hl duktape-2.7.0-1.1.1.jolla.armv7hl e2fsprogs-1.47.0+git2-1.6.3.jolla.armv7hl e2fsprogs-libs-1.47.0+git2-1.6.3.jolla.armv7hl elfutils-0.190+git1-1.7.5.jolla.armv7hl elfutils-libelf-0.190+git1-1.7.5.jolla.armv7hl elfutils-libs-0.190+git1-1.7.5.jolla.armv7hl embedlite-components-qt5-1.24.35-1.26.1.jolla.armv7hl eventsview-extensions-0.1.11-1.4.1.jolla.armv7hl eventsview-extensions-nextcloud-1.0.9-1.10.1.jolla.armv7hl eventsview-extensions-twitter-posts-0.1.11-1.4.1.jolla.armv7hl exempi-2.5.2+git1-1.8.7.jolla.armv7hl expat-2.6.1+git1-1.7.4.jolla.armv7hl farstream-0.2.9+git1-1.5.6.jolla.armv7hl feature-alien-0.5.1-1.3.1.jolla.armv7hl feature-jolla-0.1.8-1.5.7.jolla.noarch feature-sailfish-eas-0.1.1-1.3.1.jolla.armv7hl feature-xt9-0.1.1-1.3.1.jolla.armv7hl ffmpeg-5.1.6+git1-1.10.3.jolla.armv7hl file-5.41+git1-1.6.7.jolla.armv7hl file-libs-5.41+git1-1.6.7.jolla.armv7hl filesystem-3.16+git1-1.8.2.jolla.armv7hl fingerterm-1.4.7-1.9.2.jolla.armv7hl firejail-0.9.72+git3-1.10.1.jolla.armv7hl flac-1.4.3+git1-1.6.2.jolla.armv7hl fontconfig-2.13.96+git3-1.5.3.jolla.armv7hl fontpackages-filesystem-1.44-1.5.2.jolla.noarch freetype-2.13.1+git1-1.6.3.jolla.armv7hl fribidi-1.0.12+git1-1.7.3.jolla.armv7hl fuse-2.9.9+git3-1.6.2.jolla.armv7hl fuse-common-3.16.2+git1-1.6.1.jolla.armv7hl fuse-libs-2.9.9+git3-1.6.2.jolla.armv7hl gawk-3.1.5-1.5.6.jolla.armv7hl gdb-gdbserver-12.1.0+git2-1.9.2.jolla.armv7hl gecko-camera-0.1.7-1.5.3.jolla.armv7hl gecko-camera-droid-plugin-0.1.7-1.5.2.jolla.armv7hl geoclue-0.12.99.8+git2-1.6.4.jolla.armv7hl geoclue-provider-hybris-binder-0.2.36-1.5.1.jolla.armv7hl geoclue-provider-mlsdb-0.2.2-1.6.3.jolla.armv7hl geoclue-provider-mlsdb-agreements-0.2.2-1.6.3.jolla.armv7hl giflib-5.2.2+git1-1.8.2.jolla.armv7hl glib2-2.78.4+git4-1.8.1.jolla.armv7hl glibc-2.30+git12-1.10.3.jolla.armv7hl glibc-common-2.30+git12-1.10.3.jolla.armv7hl glib-networking-2.78.0+git1-1.5.2.jolla.armv7hl gmime-3.2.14+git1-1.8.3.jolla.armv7hl gmp-droid-0.8-1.4.2.jolla.armv7hl gnu-bash-5.0.18+git2-1.6.6.jolla.armv7hl gnupg2-2.0.4+git5-1.7.5.jolla.armv7hl gnutls-2.12.24+git2-1.6.11.jolla.armv7hl gpgme-1.2.0+git9-1.8.2.jolla.armv7hl graphite2-1.3.14+git2-1.5.5.jolla.armv7hl grilo-0.3.15+git1-1.6.3.jolla.armv7hl grilo-plugins-0.3.15+git1-1.8.3.jolla.armv7hl grilo-plugin-tracker-0.3.15+git1-1.8.3.jolla.armv7hl grilo-qt5-0.4.3-1.12.1.jolla.armv7hl grilo-qt5-qml-plugin-0.4.3-1.12.1.jolla.armv7hl gstreamer1.0-1.24.6+git1-1.12.1.jolla.armv7hl gstreamer1.0-droid-0.20240322.0-1.5.1.jolla.armv7hl gstreamer1.0-libav-1.22.10+git1-1.9.2.jolla.armv7hl gstreamer1.0-plugins-bad-1.22.10+git1-1.9.2.jolla.armv7hl gstreamer1.0-plugins-base-1.24.6+git1-1.11.1.jolla.armv7hl gstreamer1.0-plugins-good-1.22.10+git1-1.9.2.jolla.armv7hl harbour-barcode-1.0.53-1.armv7hl harbour-fahrplan2-2.0.42-1.9.1.jolla.armv7hl harbour-foilauth-1.1.3-1.armv7hl harbour-foilnotes-1.1.0-1.armv7hl harbour-foilpics-1.1.3-1.armv7hl harbour-qrclip-1.0.11-1.armv7hl harbour-screen-message-0.3.1-1.armv7hl harbour-scribble-0.6-2.armv7hl harbour-simplecrop-1.2.3-1.noarch harbour-tasklist-1.9.2-1.3.1.jolla.armv7hl harbour-unplayer-2.1.1-1.armv7hl harfbuzz-8.1.1+git1-1.5.2.jolla.armv7hl htop-3.2.0+git1-1.2.4.jolla.armv7hl htop-desktop-3.2.0+git1-1.2.4.jolla.noarch hunspell-1.7.1+git1-1.7.2.jolla.armv7hl hwdata-0.387+git2-1.6.1.jolla.noarch hybris-libsensorfw-qt5-binder-0.15.0-1.11.1.jolla.armv7hl info-6.3+git1-1.6.3.jolla.armv7hl iproute-6.9.0+git1-1.7.1.jolla.armv7hl iptables-1.8.10+git1-1.7.2.jolla.armv7hl iptables-ipv6-1.8.10+git1-1.7.2.jolla.armv7hl iw-5.0.1+git2-1.6.3.jolla.armv7hl jolla-actdead-charging-0.13.13-1.2.3.jolla.armv7hl jolla-alarm-ui-0.2.22-1.8.1.jolla.armv7hl jolla-alarm-ui-all-translations-pack-0.8.2-1.5.3.jolla.noarch jolla-ambient-sound-theme-0.1.0-1.2.2.jolla.noarch jolla-ca-0.11-1.3.2.jolla.noarch jolla-calculator-1.0.10-1.5.1.jolla.armv7hl jolla-calculator-all-translations-pack-0.8.2-1.5.2.jolla.noarch jolla-calendar-1.1.15.1-1.13.1.jolla.armv7hl jolla-calendar-all-translations-pack-0.8.2-1.5.3.jolla.noarch jolla-camera-1.2.27-1.13.1.jolla.armv7hl jolla-camera-lockscreen-1.2.27-1.13.1.jolla.armv7hl jolla-camera-settings-1.2.27-1.13.1.jolla.armv7hl jolla-clock-1.1.21-1.5.1.jolla.armv7hl jolla-clock-all-translations-pack-0.8.2-1.5.3.jolla.noarch jolla-common-configurations-0.11.13-1.10.1.jolla.noarch jolla-contacts-0.6.40-1.8.1.jolla.armv7hl jolla-contacts-settings-0.6.40-1.8.1.jolla.armv7hl jolla-developer-mode-0.6.23-1.4.2.jolla.armv7hl jolla-developer-mode-preload-0.6.23-1.4.2.jolla.armv7hl jolla-developer-mode-profile-0.6.23-1.4.7.jolla.armv7hl jolla-email-1.1.43-1.12.1.jolla.armv7hl jolla-email-all-translations-pack-0.8.2-1.5.3.jolla.noarch jolla-email-crypto-gnupg-1.1.43-1.12.1.jolla.armv7hl jolla-email-settings-1.1.43-1.12.1.jolla.armv7hl jolla-gallery-1.1.8-1.10.1.jolla.armv7hl jolla-gallery-ambience-0.2.37-1.4.2.jolla.armv7hl jolla-gallery-extension-nextcloud-1.0.9-1.10.1.jolla.armv7hl jolla-gallery-extensions-0.2.14-1.1.17.jolla.armv7hl jolla-gallery-extensions-dropbox-0.2.14-1.1.17.jolla.armv7hl jolla-gallery-extensions-onedrive-0.2.14-1.1.17.jolla.armv7hl jolla-gallery-facebook-0.1.14-1.4.3.jolla.armv7hl jolla-handwriting-0.1.7-1.3.3.jolla.armv7hl jolla-keyboard-0.9.7-1.10.1.jolla.armv7hl jolla-keyboard-hwr-0.9.7-1.10.1.jolla.armv7hl jolla-keyboard-layout-all-0.9.7-1.10.1.jolla.armv7hl jolla-keyboard-layout-chinese-0.9.7-1.10.1.jolla.armv7hl jolla-keyboard-layout-indian-0.9.7-1.10.1.jolla.armv7hl jolla-keyboard-layout-kazakh-0.9.7-1.10.1.jolla.armv7hl jolla-keyboard-layout-russian-0.9.7-1.10.1.jolla.armv7hl jolla-keyboard-layout-tatar-0.9.7-1.10.1.jolla.armv7hl jolla-keyboard-layout-western-0.9.7-1.10.1.jolla.armv7hl jolla-keyboard-settings-xt9-0.9.10-1.13.1.jolla.armv7hl jolla-mediaplayer-1.3.13-1.7.1.jolla.armv7hl jolla-mediaplayer-all-translations-pack-0.8.2-1.5.2.jolla.noarch jolla-messages-1.1.71-1.10.1.jolla.armv7hl jolla-messages-settings-1.1.71-1.10.1.jolla.armv7hl jolla-notes-1.0.24-1.6.3.jolla.armv7hl jolla-notes-all-translations-pack-0.8.2-1.5.1.jolla.noarch jolla-notes-settings-1.0.24-1.6.3.jolla.armv7hl jolla-rnd-device-0.5.2-1.1.9.jolla.armv7hl jolla-sessions-qt5-1.4.24-1.5.1.jolla.armv7hl jolla-settings-1.1.23-1.7.1.jolla.armv7hl jolla-settings-accounts-0.4.79-1.12.1.jolla.armv7hl jolla-settings-accounts-extensions-0.4.79-1.12.1.jolla.armv7hl jolla-settings-accounts-extensions-3rd-party-all-0.4.79-1.12.1.jolla.armv7hl jolla-settings-accounts-extensions-dropbox-0.4.79-1.12.1.jolla.armv7hl jolla-settings-accounts-extensions-email-0.4.79-1.12.1.jolla.armv7hl jolla-settings-accounts-extensions-email-crypto-0.4.79-1.12.1.jolla.armv7hl jolla-settings-accounts-extensions-facebook-0.4.79-1.12.1.jolla.armv7hl jolla-settings-accounts-extensions-fruux-0.4.79-1.12.1.jolla.armv7hl jolla-settings-accounts-extensions-google-0.4.79-1.12.1.jolla.armv7hl jolla-settings-accounts-extensions-jabber-0.4.79-1.12.1.jolla.armv7hl jolla-settings-accounts-extensions-jolla-0.4.79-1.12.1.jolla.armv7hl jolla-settings-accounts-extensions-memotoo-0.4.79-1.12.1.jolla.armv7hl jolla-settings-accounts-extensions-onedrive-0.4.79-1.12.1.jolla.armv7hl jolla-settings-accounts-extensions-onlinesync-0.4.79-1.12.1.jolla.armv7hl jolla-settings-accounts-extensions-twitter-0.4.79-1.12.1.jolla.armv7hl jolla-settings-accounts-extensions-webcal-0.4.79-1.12.1.jolla.armv7hl jolla-settings-accounts-extensions-yahoo-0.4.79-1.12.1.jolla.armv7hl jolla-settings-bluetooth-0.2.17-1.4.1.jolla.armv7hl jolla-settings-homescreen-1.2.24.1-1.17.1.jolla.armv7hl jolla-settings-layout-1.1.23-1.7.1.jolla.armv7hl jolla-settings-networking-1.0.31.2-1.16.1.jolla.armv7hl jolla-settings-networking-cellular-1.0.31.2-1.16.1.jolla.armv7hl jolla-settings-networking-multisim-1.0.31.2-1.16.1.jolla.armv7hl jolla-settings-networking-plugin-vpn-l2tp-1.0.31.2-1.16.1.jolla.armv7hl jolla-settings-networking-plugin-vpn-openconnect-1.0.31.2-1.16.1.jolla.armv7hl jolla-settings-networking-plugin-vpn-openvpn-1.0.31.2-1.16.1.jolla.armv7hl jolla-settings-networking-plugin-vpn-pptp-1.0.31.2-1.16.1.jolla.armv7hl jolla-settings-networking-plugin-vpn-vpnc-1.0.31.2-1.16.1.jolla.armv7hl jolla-settings-networking-tethering-1.0.31.2-1.16.1.jolla.armv7hl jolla-settings-networking-vpn-1.0.31.2-1.16.1.jolla.armv7hl jolla-settings-sailfishos-0.2.28-1.5.3.jolla.armv7hl jolla-settings-system-1.2.24.1-1.17.1.jolla.armv7hl jolla-settings-system-about-eula-sailfish-1.2.50.1-1.35.1.jolla.armv7hl jolla-settings-system-about-product-license-jolla-1.2.50.1-1.35.1.jolla.armv7hl jolla-settings-system-about-product-trademark-jolla-1.2.50.1-1.35.1.jolla.armv7hl jolla-settings-system-developermode-1.2.24.1-1.17.1.jolla.armv7hl jolla-settings-system-flashlight-1.2.24.1-1.17.1.jolla.armv7hl jolla-settings-system-location-1.2.24.1-1.17.1.jolla.armv7hl jolla-settings-system-nfc-1.2.24.1-1.17.1.jolla.armv7hl jolla-settings-system-orientation-1.2.24.1-1.17.1.jolla.armv7hl jolla-settings-system-presence-1.2.24.1-1.17.1.jolla.armv7hl jolla-settings-system-reset-1.2.24.1-1.17.1.jolla.armv7hl jolla-settings-system-sideloading-1.2.24.1-1.17.1.jolla.armv7hl jolla-settings-transferui-qt5-1.1.6-1.1.2.jolla.armv7hl jolla-signon-ui-0.2.13-1.3.4.jolla.armv7hl jolla-startupwizard-0.5.9-1.8.1.jolla.armv7hl jolla-vault-1.1.44-1.4.1.jolla.armv7hl jolla-vault-units-1.1.46-1.5.2.jolla.armv7hl jolla-xt9-0.5.22-1.6.3.jolla.armv7hl jolla-xt9-cp-0.2.15-1.4.2.jolla.armv7hl json-c-0.15+git1-1.4.5.jolla.armv7hl json-glib-1.6.0+git1-1.4.6.jolla.armv7hl kcalcore-qt5-4.10.2+9git28-1.4.1.jolla.armv7hl kf5bluezqt-bluez5-5.112.0+git2-1.9.2.jolla.armv7hl kf5bluezqt-bluez5-declarative-5.112.0+git2-1.9.2.jolla.armv7hl kf5-calendarcore-5.94+git2-1.10.1.jolla.armv7hl kmod-29+git2-1.6.3.jolla.armv7hl kmod-libs-29+git2-1.6.3.jolla.armv7hl libaccounts-glib-1.24+git5-1.4.5.jolla.armv7hl libaccounts-glib-tools-1.24+git5-1.4.5.jolla.armv7hl libaccounts-qt5-1.16+git3-1.6.5.jolla.armv7hl libacl-2.3.1+git2-1.6.20.jolla.armv7hl libapkd-1.18.2-1.9.1.jolla.armv7hl libappsupportaudio-1.26.0-1.1.1.jolla.armv7hl libarchive-3.7.4+git1-1.10.1.jolla.armv7hl libasyncns-0.8-1.5.4.jolla.armv7hl libattr-2.5.1+git1-1.7.3.jolla.armv7hl libblkid-2.38.1+git6-1.13.1.jolla.armv7hl libblockdev-2.26+git1-1.5.4.jolla.armv7hl libblockdev-crypto-2.26+git1-1.5.4.jolla.armv7hl libblockdev-fs-2.26+git1-1.5.4.jolla.armv7hl libblockdev-loop-2.26+git1-1.5.4.jolla.armv7hl libblockdev-part-2.26+git1-1.5.4.jolla.armv7hl libblockdev-swap-2.26+git1-1.5.4.jolla.armv7hl libblockdev-utils-2.26+git1-1.5.4.jolla.armv7hl libcanberra-0.30+git2-1.6.3.jolla.armv7hl libcap-2.69+git1-1.7.4.jolla.armv7hl libcap-ng-0.8.3+git1-1.7.2.jolla.armv7hl libcgroup-0.41+git2-1.5.2.jolla.armv7hl libcom_err-1.47.0+git2-1.6.3.jolla.armv7hl libcommhistory-qt5-1.12.1-1.12.2.jolla.armv7hl libcommhistory-qt5-declarative-1.12.1-1.12.2.jolla.armv7hl libcommhistory-qt5-tools-1.12.1-1.12.2.jolla.armv7hl libcontentaction-qt5-0.4.8-1.10.1.jolla.armv7hl libcurl-8.9.1+git1-1.11.2.jolla.armv7hl libdbusaccess-1.0.20-1.7.2.jolla.armv7hl libdbuslogserver-dbus-1.0.22-1.5.6.jolla.armv7hl libdbuslogserver-gio-1.0.22-1.5.6.jolla.armv7hl libdbus-qeventloop-qt5-1.32.0-1.9.3.jolla.armv7hl libdres-1.1.18-1.5.5.jolla.armv7hl libdrm-2.4.122+git1-1.7.1.jolla.armv7hl libdsme-0.67.0-1.8.1.jolla.armv7hl libexif-0.6.24+git1-1.5.2.jolla.armv7hl libfdisk-2.38.1+git6-1.13.1.jolla.armv7hl libffi-3.4.4+git1-1.7.2.jolla.armv7hl libgbinder-1.1.40-1.11.1.jolla.armv7hl libgbinder-radio-1.6.0-1.9.1.jolla.armv7hl libgcc-10.3.1-1.8.6.jolla.armv7hl libgcrypt-1.10.3+git1-1.7.2.jolla.armv7hl libglibutil-1.0.79-1.17.1.jolla.armv7hl libgofono-2.1.6-1.8.3.jolla.armv7hl libgofonoext-1.0.14-1.6.3.jolla.armv7hl libgomp-10.3.1-1.8.6.jolla.armv7hl libgpg-error-1.42+git2-1.7.3.jolla.armv7hl libgrilio-1.0.44-1.6.5.jolla.armv7hl libgrilio-binder-1.2.7-1.4.6.jolla.armv7hl libgsf-1.14.52+git1-1.8.2.jolla.armv7hl libgsupplicant-1.0.27-1.8.3.jolla.armv7hl libgudev-237+git1-1.6.5.jolla.armv7hl libhybris-0.0.5.55-1.11.1.jolla.armv7hl libhybris-libEGL-0.0.5.55-1.11.1.jolla.armv7hl libhybris-libGLESv2-0.0.5.55-1.11.1.jolla.armv7hl libhybris-libhardware-0.0.5.55-1.11.1.jolla.armv7hl libhybris-libsync-0.0.5.55-1.11.1.jolla.armv7hl libhybris-libwayland-egl-0.0.5.55-1.11.1.jolla.armv7hl libical-3.0.16+git1-1.6.4.jolla.armv7hl libicu-70.1+git1-1.6.2.jolla.armv7hl libiodata-qt5-0.19.14-1.8.2.jolla.armv7hl libiphb-1.2.7-1.4.4.jolla.armv7hl libiptcdata-1.0.5+git1-1.4.4.jolla.armv7hl libjollamediaplayer-1.3.13-1.7.1.jolla.armv7hl libjollasettingssailfishos-0.2.28-1.5.3.jolla.armv7hl libjollasignontrampolineservice-qt5-0.4.22-1.7.1.jolla.armv7hl libjollasignonuiservice-qt5-0.4.21-1.6.1.jolla.armv7hl libjollasignonuiservice-qt5-plugin-0.4.21-1.6.1.jolla.armv7hl libjpeg-turbo-3.0.3+git1-1.8.1.jolla.armv7hl libkeepalive-1.8.10-1.8.2.jolla.armv7hl libkeepalive-glib-1.8.11-1.9.2.jolla.armv7hl libkf5archive-5.75.0+git1-1.4.9.jolla.armv7hl libksba-1.6.3+git1-1.8.2.jolla.armv7hl liblua-5.4.6-1.7.3.jolla.armv7hl libmce-glib-1.1.0-1.7.2.jolla.armv7hl libmce-qt5-1.5.1-1.7.2.jolla.armv7hl libmce-qt5-declarative-1.5.1-1.7.2.jolla.armv7hl libmediaart-1.9.5+git1-1.6.4.jolla.armv7hl libmlocale-qt5-0.7.8-1.9.1.jolla.armv7hl libmount-2.38.1+git6-1.13.1.jolla.armv7hl libmpg123-1.32.5+git1-1.9.2.jolla.armv7hl libncicore-1.1.28-1.5.1.jolla.armv7hl libnciplugin-1.2.0-1.8.1.jolla.armv7hl libnemotransferengine-qt5-2.0.5-1.12.2.jolla.armv7hl libnfcdef-1.0.0-1.1.1.jolla.armv7hl libngf-0.28-1.4.5.jolla.armv7hl libngf-qt5-0.8.6-1.11.2.jolla.armv7hl libngf-qt5-declarative-0.8.6-1.11.2.jolla.armv7hl libngf-qt5-qtfeedback-0.8.6-1.11.2.jolla.armv7hl libnghttp2-1.58.0+git1-1.5.2.jolla.armv7hl libnice-0.1.21+git1-1.6.3.jolla.armv7hl libnl-3.7.0+git1-1.7.2.jolla.armv7hl libogg-1.3.5-1.5.4.jolla.armv7hl libopenconnect5-9.12+git2-1.8.6.jolla.armv7hl libpcap-1.10.3+git2-1.7.1.jolla.armv7hl libphonenumber-8.13.27+git1-1.10.2.jolla.armv7hl libphonenumber-geocoding-8.13.27+git1-1.10.2.jolla.armv7hl libpng-1.6.40+git1-1.5.3.jolla.armv7hl libprofile-qt5-0.35.6-1.8.2.jolla.armv7hl libprolog-1.2.2-1.5.4.jolla.armv7hl libpsl-0.21.5+git1-1.7.1.jolla.armv7hl libpython3_7m1_0-3.7.2+git9-1.6.2.jolla.armv7hl libqapk-0.5.1-1.2.3.jolla.armv7hl libqmfclient1-qt5-4.0.4+git144-1.9.2.jolla.armv7hl libqmfclient1-qt5-cryptoplugins-4.0.4+git144-1.9.2.jolla.armv7hl libqmfmessageserver1-qt5-4.0.4+git144-1.9.2.jolla.armv7hl libqofonoext-1.0.32-1.8.1.jolla.armv7hl libqofonoext-declarative-1.0.32-1.8.1.jolla.armv7hl libqofono-qt5-0.124-1.11.1.jolla.armv7hl libqofono-qt5-declarative-0.124-1.11.1.jolla.armv7hl libqt5sparql-0.3.9-1.9.1.jolla.armv7hl libqt5sparql-tracker-0.2.22+git1-1.3.2.jolla.armv7hl libqt5sparql-tracker-direct-0.3.9-1.9.1.jolla.armv7hl libquillmetadata-qt5-2.0.0-1.5.3.jolla.armv7hl libresource-0.25.2-1.6.1.jolla.armv7hl libresourceqt-qt5-1.32.0-1.9.3.jolla.armv7hl libsailfishapp-1.2.15-1.7.2.jolla.armv7hl libsailfishapp-launcher-1.2.15-1.7.2.jolla.armv7hl libsailfishcrypto-0.2.38-1.11.3.jolla.armv7hl libsailfishcryptoplugin-0.2.38-1.11.3.jolla.armv7hl libsailfishcryptopluginapi-0.2.38-1.11.3.jolla.armv7hl libsailfishkeyprovider-1.0.9-1.5.3.jolla.armv7hl libsailfishkeyprovider-data-jolla-0.1.0-1.2.2.jolla.armv7hl libsailfishsecrets-0.2.38-1.11.3.jolla.armv7hl libsailfishsecretsplugin-0.2.38-1.11.3.jolla.armv7hl libsailfishsecretspluginapi-0.2.38-1.11.3.jolla.armv7hl libsbc-2.0+git1-1.7.2.jolla.armv7hl libseccomp-2.5.2+git1-1.5.4.jolla.armv7hl libselinux-3.1+git3-1.5.8.jolla.armv7hl libselinux-utils-3.1+git3-1.5.8.jolla.armv7hl libsemanage-3.1+git2-1.4.15.jolla.armv7hl libsepol-3.1+git3-1.5.4.jolla.armv7hl libshadowutils-0.0.5-1.6.4.jolla.armv7hl libsigc++20-2.10.4+git1-1.5.4.jolla.armv7hl libsignon-glib-1.15+git1-1.5.5.jolla.armv7hl libsignon-qt5-8.61.0+git1-1.10.1.jolla.armv7hl libsmartcols-2.38.1+git6-1.13.1.jolla.armv7hl libsndfile-1.2.2+git1-1.7.2.jolla.armv7hl libsocialcache-0.1.8-1.5.2.jolla.armv7hl libsocialcache-qml-plugin-0.1.8-1.5.2.jolla.armv7hl libsolv-0.7.20+git2-1.6.4.jolla.armv7hl libsolv-tools-0.7.20+git2-1.6.4.jolla.armv7hl libsoup-2.74.3+git1-1.6.4.jolla.armv7hl libsrtp-2.3.0+git1-1.5.4.jolla.armv7hl libss-1.47.0+git2-1.6.3.jolla.armv7hl libstdc++-10.3.1-1.8.6.jolla.armv7hl libtasn1-4.19.0+git1-1.7.3.jolla.armv7hl libtheora-1.2.0alpha1+git4-1.6.3.jolla.armv7hl libtiff-4.6.0+git1-1.7.4.jolla.armv7hl libtool-ltdl-2.4.7-1.5.3.jolla.armv7hl libtrace-1.1.8+git4-1.6.4.jolla.armv7hl libudisks2-2.9.4+git5-1.10.4.jolla.armv7hl libusb-0.1.7+git2-1.5.4.jolla.armv7hl libusb1-1.0.26+git2-1.8.1.jolla.armv7hl libusb-moded-qt5-1.11-1.7.2.jolla.armv7hl libuser-0.62+git5-1.6.5.jolla.armv7hl libutempter-1.1.5+git3-1.6.12.jolla.armv7hl libuuid-2.38.1+git6-1.13.1.jolla.armv7hl libvorbis-1.3.7-1.4.4.jolla.armv7hl libvpx-1.14.1+git1-1.7.1.jolla.armv7hl libwbxml2-0.11.6+git2-1.6.4.jolla.armv7hl libwebp-1.4.0+git1-1.11.1.jolla.armv7hl libwspcodec-2.2.6-1.5.4.jolla.armv7hl libxcrypt-4.4.23+git2-1.2.4.jolla.armv7hl libxkbcommon-1.3.1+git1-1.6.6.jolla.armv7hl libxml2-2.13.4+git2-1.10.1.jolla.armv7hl libxslt-1.1.42+git1-1.10.1.jolla.armv7hl libzstd-1.5.0+git2-1.2.5.jolla.armv7hl libzypp-17.31.28+git1-1.7.3.jolla.armv7hl lipstick-jolla-home-qt5-1.26.12.4-1.22.1.jolla.armv7hl lipstick-jolla-home-qt5-components-1.26.12.4-1.22.1.jolla.armv7hl lipstick-qt5-0.36.41-1.20.1.jolla.armv7hl lsof-4.94.0+git2-1.6.9.jolla.armv7hl lvm2-2.02.177+git6-1.7.4.jolla.armv7hl lvm2-libs-2.02.177+git6-1.7.4.jolla.armv7hl lxc-5.0.2+git1-1.7.5.jolla.armv7hl lxc-libs-5.0.2+git1-1.7.5.jolla.armv7hl lz4-libs-1.9.4+git1-1.1.2.jolla.armv7hl lzo-2.10-1.6.3.jolla.armv7hl make-4.2.1-1.5.5.jolla.armv7hl maliit-framework-wayland-2.2.1+git3-1.10.2.jolla.armv7hl maliit-framework-wayland-inputcontext-2.2.1+git3-1.10.2.jolla.armv7hl mapplauncherd-4.2.13-1.11.3.jolla.armv7hl mapplauncherd-booster-browser-0.2.2-1.1.1.jolla.armv7hl mapplauncherd-booster-silica-qt5-0.5.6-1.1.2.jolla.armv7hl mapplauncherd-booster-silica-qt5-media-0.5.6-1.1.2.jolla.armv7hl mapplauncherd-qt5-1.1.22-1.8.4.jolla.armv7hl mce-1.115.4-1.14.2.jolla.armv7hl mce-plugin-libhybris-1.14.5-1.3.1.jolla.armv7hl mce-tools-1.115.4-1.14.2.jolla.armv7hl mkcal-qt5-0.7.25-1.22.1.jolla.armv7hl mlite-qt5-0.4.3-1.11.1.jolla.armv7hl mlsdb-data-eastern-europe-0.2.1-1.11.1.jolla.armv7hl mlsdb-data-northern-europe-0.2.1-1.11.1.jolla.armv7hl mlsdb-data-southern-europe-0.2.1-1.11.1.jolla.armv7hl mlsdb-data-western-europe-0.2.1-1.11.1.jolla.armv7hl mms-engine-1.0.81-1.6.6.jolla.armv7hl mobile-broadband-provider-info-20131125+git89-1.10.1.jolla.noarch mpris-qt5-1.0.6-1.4.6.jolla.armv7hl mpris-qt5-qml-plugin-1.0.6-1.4.6.jolla.armv7hl mtdev-1.1.6+git1-1.6.3.jolla.armv7hl mtp-vendor-configuration-sailfish-0.11.13-1.10.1.jolla.noarch ncurses-base-6.5+git1-1.8.1.jolla.armv7hl ncurses-libs-6.5+git1-1.8.1.jolla.armv7hl nemo-gstreamer1.0-interfaces-0.20211122.0-1.5.4.jolla.armv7hl nemo-password-manager-0.1.5-1.5.5.jolla.armv7hl nemo-qml-plugin-alarms-qt5-0.3.13-1.7.2.jolla.armv7hl nemo-qml-plugin-calendar-qt5-0.7.3-1.15.1.jolla.armv7hl nemo-qml-plugin-calendar-qt5-lightweight-0.7.3-1.15.1.jolla.armv7hl nemo-qml-plugin-calendar-qt5-tools-0.7.3-1.15.1.jolla.armv7hl nemo-qml-plugin-configuration-qt5-0.2.8-1.9.3.jolla.armv7hl nemo-qml-plugin-connectivity-0.2.22-1.15.1.jolla.armv7hl nemo-qml-plugin-contacts-qt5-0.3.27-1.14.2.jolla.armv7hl nemo-qml-plugin-contacts-qt5-tools-0.3.27-1.14.2.jolla.armv7hl nemo-qml-plugin-contentaction-0.4.8-1.10.1.jolla.armv7hl nemo-qml-plugin-contextkit-qt5-2.0.2-1.6.2.jolla.armv7hl nemo-qml-plugin-dbus-qt5-2.1.35-1.10.2.jolla.armv7hl nemo-qml-plugin-devicelock-0.4.0-1.9.1.jolla.armv7hl nemo-qml-plugin-email-qt5-0.6.34-1.12.1.jolla.armv7hl nemo-qml-plugin-filemanager-0.1.45-1.16.1.jolla.armv7hl nemo-qml-plugin-messages-internal-qt5-0.1.31-1.7.3.jolla.armv7hl nemo-qml-plugin-models-qt5-0.2.8-1.10.1.jolla.armv7hl nemo-qml-plugin-notifications-qt5-1.2.26-1.12.1.jolla.armv7hl nemo-qml-plugin-policy-qt5-0.1.5-1.7.2.jolla.armv7hl nemo-qml-plugin-social-qt5-0.1.4-1.7.2.jolla.armv7hl nemo-qml-plugin-systemsettings-0.10.9-1.15.1.jolla.armv7hl nemo-qml-plugin-thumbnailer-qt5-1.0.9-1.7.2.jolla.armv7hl nemo-qml-plugin-time-qt5-0.1.7-1.8.2.jolla.armv7hl nemo-qtmultimedia-plugins-gstvideotexturebackend-0.1.4-1.5.4.jolla.armv7hl nemo-transferengine-qt5-2.0.5-1.12.2.jolla.armv7hl net-tools-1.60-1.5.4.jolla.armv7hl nfcd-1.2.0-1.13.1.jolla.armv7hl nfcd-binder-plugin-1.1.9-1.2.3.jolla.armv7hl nfcd-dbuslog-plugin-1.0.3-1.5.2.jolla.armv7hl nfcd-mce-plugin-1.0.2-1.4.8.jolla.armv7hl ngfd-1.4.2-1.8.1.jolla.armv7hl ngfd-plugin-native-vibrator-1.4.1-1.8.1.jolla.armv7hl ngfd-settings-sailfish-0.11.13-1.10.1.jolla.noarch nspr-4.35.0+git2-1.6.2.jolla.armv7hl nss-3.101+git1-1.8.2.jolla.armv7hl nss-softokn-3.101+git1-1.8.2.jolla.armv7hl nss-softokn-freebl-3.101+git1-1.8.2.jolla.armv7hl nss-sysinit-3.101+git1-1.8.2.jolla.armv7hl nss-util-3.101+git1-1.8.2.jolla.armv7hl obex-capability-0.0.4-1.6.3.jolla.armv7hl obexd-calldata-provider-0.1.5-1.3.2.jolla.armv7hl obexd-contentfilter-helper-0.0.2-1.1.11.jolla.noarch ofono-1.29+git11-1.15.2.jolla.armv7hl ofono-alien-binder-plugin-0.3.3-1.6.1.jolla.armv7hl ofono-ril-binder-plugin-1.2.7-1.4.6.jolla.armv7hl ofono-ril-plugin-1.0.7-1.3.1.jolla.armv7hl ohm-1.3.2-1.6.1.jolla.armv7hl ohm-plugin-accessories-1.10.0-1.9.3.jolla.armv7hl ohm-plugin-core-1.3.2-1.6.1.jolla.armv7hl ohm-plugin-mdm-1.10.0-1.9.3.jolla.armv7hl ohm-plugin-media-1.10.0-1.9.3.jolla.armv7hl ohm-plugin-profile-1.10.0-1.9.3.jolla.armv7hl ohm-plugin-resolver-1.1.18-1.5.5.jolla.armv7hl ohm-plugin-route-1.10.0-1.9.3.jolla.armv7hl ohm-plugin-ruleengine-1.1.14-1.4.4.jolla.armv7hl ohm-plugins-dbus-1.10.0-1.9.3.jolla.armv7hl ohm-plugin-signaling-1.10.0-1.9.3.jolla.armv7hl ohm-plugins-misc-1.10.0-1.9.3.jolla.armv7hl ohm-plugin-telephony-1.10.0-1.9.3.jolla.armv7hl oneshot-0.6.12-1.6.2.jolla.noarch openconnect-9.12+git2-1.8.6.jolla.armv7hl openjpeg-2.5.0+git1-1.7.4.jolla.armv7hl openssh-9.8p1+git1-1.10.2.jolla.armv7hl openssh-clients-9.8p1+git1-1.10.2.jolla.armv7hl openssh-server-9.8p1+git1-1.10.2.jolla.armv7hl openssl-1.1.1v+git1-1.12.1.jolla.armv7hl openssl-libs-1.1.1v+git1-1.12.1.jolla.armv7hl openvpn-2.6.12+git1-1.12.1.jolla.armv7hl opus-1.5.1+git1-1.6.2.jolla.armv7hl orc-0.4.39+git1-1.9.1.jolla.armv7hl p11-kit-0.23.22+git1-1.6.6.jolla.armv7hl p11-kit-nss-ckbi-0.23.22+git1-1.6.6.jolla.armv7hl p11-kit-trust-0.23.22+git1-1.6.6.jolla.armv7hl PackageKit-1.2.5+git3.2-1.8.1.jolla.armv7hl PackageKit-glib-1.2.5+git3.2-1.8.1.jolla.armv7hl PackageKit-Qt5-1.0.2+git1-1.5.5.jolla.armv7hl PackageKit-zypp-1.2.5+git3.2-1.8.1.jolla.armv7hl pacrunner-0.18+git2-1.7.3.jolla.armv7hl pam-1.6.1+git1-1.8.1.jolla.armv7hl pango-1.51.1+git1-1.7.2.jolla.armv7hl passwd-0.80+git2-1.6.3.jolla.armv7hl patch-2.7.6+git2-1.6.3.jolla.armv7hl patterns-sailfish-api-3-3.0.2-1.5.2.jolla.noarch patterns-sailfish-app-blacklist-1.1.32-1.14.1.jolla.noarch patterns-sailfish-applications-1.1.32-1.14.1.jolla.noarch patterns-sailfish-cellular-apps-1.1.32-1.14.1.jolla.noarch patterns-sailfish-consumer-generic-1.1.32-1.14.1.jolla.noarch patterns-sailfish-core-1.1.32-1.14.1.jolla.noarch patterns-sailfish-core-device-1.1.32-1.14.1.jolla.noarch patterns-sailfish-customer-content-default-1.1.32-1.14.1.jolla.noarch patterns-sailfish-device-adaptation-kirin-0.0.74-1.9.1.jolla.armv7hl patterns-sailfish-device-configuration-common-i4113-0.0.74-1.9.1.jolla.armv7hl patterns-sailfish-device-configuration-i4113-0.0.74-1.9.1.jolla.armv7hl patterns-sailfish-mw-1.1.32-1.14.1.jolla.noarch patterns-sailfish-ui-1.1.32-1.14.1.jolla.noarch patterns-sailfish-xt9-0.1.1-1.3.1.jolla.armv7hl pcre2-10.42+git1-1.1.2.jolla.armv7hl pcre-8.45+git2-1.7.4.jolla.armv7hl perl-5.16.3-1.7.6.jolla.armv7hl perl-Filter-1.40-1.7.6.jolla.armv7hl perl-libs-5.16.3-1.7.6.jolla.armv7hl perl-macros-5.16.3-1.7.6.jolla.armv7hl perl-Module-Pluggable-4.00-1.7.6.jolla.noarch perl-parent-0.225-1.7.6.jolla.noarch perl-Pod-Escapes-1.04-1.7.6.jolla.noarch perl-Pod-Parser-1.51-1.7.6.jolla.noarch perl-Pod-Perldoc-3.17.00-1.7.6.jolla.noarch perl-Pod-Simple-3.20-1.7.6.jolla.noarch perl-Scalar-List-Utils-1.25-1.7.6.jolla.armv7hl perl-Socket-2.001-1.7.6.jolla.armv7hl perl-threads-1.86-1.7.6.jolla.armv7hl perl-threads-shared-1.40-1.7.6.jolla.armv7hl pixman-0.42.2+git1-1.7.3.jolla.armv7hl pkgconfig-0.29.2+git1-1.5.4.jolla.armv7hl policycoreutils-3.1+git3-1.5.7.jolla.armv7hl policy-settings-common-0.13.0-1.9.2.jolla.armv7hl polkit-125+git1-1.8.1.jolla.armv7hl poppler-24.08.0+git2-1.10.1.jolla.armv7hl poppler-glib-24.08.0+git2-1.10.1.jolla.armv7hl poppler-qt5-23.07.0+git1-1.7.2.jolla.armv7hl popt-1.18+git1-1.4.4.jolla.armv7hl ppp-2.4.9+git2-1.6.4.jolla.armv7hl ppp-libs-2.4.9+git2-1.6.4.jolla.armv7hl pptp-1.10+git1-1.6.3.jolla.armv7hl profiled-1.0.14-1.6.2.jolla.armv7hl prolog-resourcepolicy-extensions-1.1.14-1.4.4.jolla.armv7hl protobuf-lite-25.1+git1-1.8.3.jolla.armv7hl provisioning-service-0.1.8-1.7.6.jolla.armv7hl pth-2.0.7-1.6.3.jolla.armv7hl pulseaudio-14.2+git9-1.10.2.jolla.armv7hl pulseaudio-module-keepalive-1.1.0-1.6.4.jolla.armv7hl pulseaudio-modules-droid-hidl-1.5.0-1.3.4.jolla.armv7hl pulseaudio-modules-droid-jb2q-14.2.102-1.5.1.jolla.armv7hl pulseaudio-modules-droid-jb2q-common-14.2.102-1.5.1.jolla.armv7hl pulseaudio-modules-nemo-common-14.2.31-1.5.3.jolla.armv7hl pulseaudio-modules-nemo-mainvolume-14.2.31-1.5.3.jolla.armv7hl pulseaudio-modules-nemo-parameters-14.2.31-1.5.3.jolla.armv7hl pulseaudio-modules-nemo-stream-restore-14.2.31-1.5.3.jolla.armv7hl pulseaudio-policy-enforcement-14.2.47-1.7.3.jolla.armv7hl pyotherside-qml-plugin-python3-qt5-1.5.9+git4-1.5.4.jolla.armv7hl python-2.7.17+git8-1.1.1.jolla.armv7hl python3-base-3.8.18+git1-1.9.5.jolla.armv7hl python3-imaging-9.0.0+git2-1.5.4.jolla.armv7hl python3-IPy-0.83+git4-1.4.3.jolla.noarch python3-libs-3.8.18+git1-1.9.5.jolla.armv7hl python3-libselinux-3.1+git3-1.5.8.jolla.armv7hl python3-libsemanage-3.1+git2-1.4.15.jolla.armv7hl python3-sqlite-3.8.18+git1-1.8.2.jolla.armv7hl python-libs-2.7.17+git8-1.1.1.jolla.armv7hl qmf-notifications-plugin-0.2.11-1.5.4.jolla.armv7hl qmf-notifications-plugin-all-translations-pack-0.8.2-1.7.2.jolla.noarch qmf-oauth2-plugin-0.1.0-1.1.18.jolla.armv7hl qmllive-1.0.0+git8-1.4.3.jolla.armv7hl qmllive-sailfish-0.3.2-1.5.7.jolla.armv7hl qr-filter-qml-plugin-1.1.2-1.7.1.jolla.armv7hl qt5-plugin-bearer-connman-5.6.3+git55-1.18.1.jolla.armv7hl qt5-plugin-generic-evdev-5.6.3+git52-1.15.7.jolla.armv7hl qt5-plugin-geoservices-here-5.4.2+git3-1.6.2.jolla.armv7hl qt5-plugin-imageformat-gif-5.6.3+git52-1.15.7.jolla.armv7hl qt5-plugin-imageformat-ico-5.6.3+git52-1.15.7.jolla.armv7hl qt5-plugin-imageformat-jpeg-5.6.3+git52-1.15.7.jolla.armv7hl qt5-plugin-platform-minimal-5.6.3+git52-1.15.7.jolla.armv7hl qt5-plugin-position-geoclue-5.4.2+git3-1.6.2.jolla.armv7hl qt5-plugin-sqldriver-sqlcipher-0.2.41-1.13.2.jolla.armv7hl qt5-plugin-sqldriver-sqlite-5.6.3+git55-1.18.1.jolla.armv7hl qt5-qpa-hwcomposer-plugin-5.6.2.24-1.4.2.jolla.armv7hl qt5-qtconcurrent-5.6.3+git55-1.18.1.jolla.armv7hl qt5-qtcore-5.6.3+git55-1.18.1.jolla.armv7hl qt5-qtdbus-5.6.3+git55-1.18.1.jolla.armv7hl qt5-qtdeclarative-5.6.3+git25-1.8.2.jolla.armv7hl qt5-qtdeclarative-import-folderlistmodel-5.6.3+git25-1.8.2.jolla.armv7hl qt5-qtdeclarative-import-localstorageplugin-5.6.3+git25-1.8.2.jolla.armv7hl qt5-qtdeclarative-import-location-5.4.2+git3-1.6.2.jolla.armv7hl qt5-qtdeclarative-import-models2-5.6.3+git25-1.8.2.jolla.armv7hl qt5-qtdeclarative-import-multimedia-5.6.2+git31-1.11.5.jolla.armv7hl qt5-qtdeclarative-import-particles2-5.6.3+git25-1.8.2.jolla.armv7hl qt5-qtdeclarative-import-positioning-5.4.2+git3-1.6.3.jolla.armv7hl qt5-qtdeclarative-import-qtquick2plugin-5.6.3+git25-1.8.2.jolla.armv7hl qt5-qtdeclarative-import-qttest-5.6.3+git25-1.8.2.jolla.armv7hl qt5-qtdeclarative-import-sensors-5.6.3+git4-1.6.1.jolla.armv7hl qt5-qtdeclarative-import-window2-5.6.3+git25-1.8.2.jolla.armv7hl qt5-qtdeclarative-import-xmllistmodel-5.6.3+git25-1.8.2.jolla.armv7hl qt5-qtdeclarative-plugin-qmlinspector-5.6.3+git25-1.8.2.jolla.armv7hl qt5-qtdeclarative-qtquick-5.6.3+git25-1.8.2.jolla.armv7hl qt5-qtdeclarative-qtquickparticles-5.6.3+git25-1.8.2.jolla.armv7hl qt5-qtdeclarative-qtquicktest-5.6.3+git25-1.8.2.jolla.armv7hl qt5-qtdocgallery-5.3.0+git6-1.9.1.jolla.armv7hl qt5-qtfeedback-5.2.0+git7-1.4.8.jolla.armv7hl qt5-qtgraphicaleffects-5.6.2+git4-1.5.3.jolla.armv7hl qt5-qtgui-5.6.3+git55-1.18.1.jolla.armv7hl qt5-qtimageformats-plugin-tiff-5.6.3+git4-1.5.3.jolla.armv7hl qt5-qtimageformats-plugin-webp-5.6.3+git4-1.5.3.jolla.armv7hl qt5-qtlocation-5.4.2+git3-1.6.2.jolla.armv7hl qt5-qtmultimedia-5.6.2+git31-1.11.5.jolla.armv7hl qt5-qtmultimedia-gsttools-5.6.2+git31-1.11.5.jolla.armv7hl qt5-qtmultimedia-plugin-audio-pulseaudio-5.6.2+git31-1.11.5.jolla.armv7hl qt5-qtmultimedia-plugin-mediaservice-gstcamerabin-5.6.2+git31-1.11.5.jolla.armv7hl qt5-qtmultimedia-plugin-mediaservice-gstmediacapture-5.6.2+git31-1.11.5.jolla.armv7hl qt5-qtmultimedia-plugin-mediaservice-gstmediaplayer-5.6.2+git31-1.11.5.jolla.armv7hl qt5-qtmultimedia-plugin-resourcepolicy-resourceqt-5.6.2+git31-1.11.5.jolla.armv7hl qt5-qtnetwork-5.6.3+git55-1.18.1.jolla.armv7hl qt5-qtopengl-5.6.3+git52-1.15.7.jolla.armv7hl qt5-qtpim-contacts-5.6.0+git15-1.5.5.jolla.armv7hl qt5-qtpim-versit-5.6.0+git15-1.5.5.jolla.armv7hl qt5-qtpositioning-5.4.2+git3-1.6.3.jolla.armv7hl qt5-qtprintsupport-5.6.3+git52-1.15.7.jolla.armv7hl qt5-qtquickcontrols-layouts-5.2.1+git4-1.4.5.jolla.armv7hl qt5-qtsensors-5.6.3+git4-1.6.1.jolla.armv7hl qt5-qtsensors-plugin-sensorfw-5.6.3+git4-1.6.1.jolla.armv7hl qt5-qtsql-5.6.3+git55-1.18.1.jolla.armv7hl qt5-qtsvg-5.6.2+git3-1.4.7.jolla.armv7hl qt5-qtsvg-plugin-imageformat-svg-5.6.2+git3-1.4.7.jolla.armv7hl qt5-qttest-5.6.3+git55-1.18.1.jolla.armv7hl qt5-qtwayland-wayland_egl-5.6.3+git3-1.8.2.jolla.armv7hl qt5-qtwidgets-5.6.3+git52-1.15.7.jolla.armv7hl qt5-qtxml-5.6.3+git55-1.18.1.jolla.armv7hl qt5-qtxmlpatterns-5.6.3+git4-1.6.3.jolla.armv7hl qtcontacts-sqlite-qt5-0.3.20-1.8.1.jolla.armv7hl qtmozembed-qt5-1.53.25-1.22.2.jolla.armv7hl qtscenegraph-adaptation-0.8.0-1.3.3.jolla.armv7hl quazip-1.2+git2-1.5.6.jolla.armv7hl quota-minimal-4.05+git3-1.6.2.jolla.armv7hl quota-nld-4.05+git3-1.6.2.jolla.armv7hl readline-8.1+git1-1.6.3.jolla.armv7hl rootfiles-8.1+git3-1.5.3.jolla.noarch rpm-4.16.1.3+git17-1.12.1.jolla.armv7hl rpm-build-4.16.1.3+git17-1.12.1.jolla.armv7hl rsync-3.2.7+git1-1.6.3.jolla.armv7hl sailfish-access-control-0.0.8-1.7.1.jolla.armv7hl sailfish-access-control-qml-plugin-0.0.8-1.7.1.jolla.armv7hl sailfish-account-nextcloud-1.0.9-1.10.1.jolla.armv7hl sailfish-account-nextcloud-features-all-1.0.9-1.10.1.jolla.armv7hl sailfish-aml-1.0.5-1.2.1.jolla.armv7hl sailfish-aml-data-1.0.5-1.2.1.jolla.noarch sailfish-archive-0.1.2-1.1.13.jolla.armv7hl sailfish-audiorecorder-0.1.9-1.4.1.jolla.armv7hl sailfish-audiorecorder-l10n-all-translations-1.25.2-1.9.1.jolla.noarch sailfish-browser-2.2.63-1.12.2.jolla.armv7hl sailfish-browser-settings-2.2.63-1.12.2.jolla.armv7hl sailfish-ca-0.2-1.2.2.jolla.noarch sailfish-components-accounts-qt5-0.4.5-1.1.2.jolla.armv7hl sailfish-components-accounts-qt5-tools-0.4.5-1.1.2.jolla.armv7hl sailfish-components-bluetooth-qt5-0.2.30-1.8.1.jolla.armv7hl sailfish-components-calendar-qt5-1.1.15.1-1.13.1.jolla.armv7hl sailfish-components-contacts-qt5-0.4.50-1.9.1.jolla.armv7hl sailfish-components-email-qt5-0.1.5-1.3.1.jolla.armv7hl sailfish-components-filemanager-0.2.27-1.1.2.jolla.armv7hl sailfish-components-gallery-qt5-1.2.21-1.2.1.jolla.armv7hl sailfish-components-media-qt5-0.9.16-1.5.2.jolla.armv7hl sailfish-components-pickers-qt5-1.0.28-1.8.1.jolla.armv7hl sailfish-components-secrets-ui-0.1.9-1.3.4.jolla.armv7hl sailfish-components-store-0.0.13-1.2.2.jolla.armv7hl sailfish-components-telephony-qt5-0.2.5-1.3.3.jolla.armv7hl sailfish-components-textlinking-0.1.6-1.2.2.jolla.armv7hl sailfish-components-timezone-qt5-0.2.5-1.5.2.jolla.armv7hl sailfish-components-weather-qt5-1.1.22-1.10.1.jolla.armv7hl sailfish-components-weather-qt5-all-translations-pack-0.8.1-1.4.1.jolla.noarch sailfish-components-webview-qt5-1.5.21-1.13.1.jolla.armv7hl sailfish-components-webview-qt5-pickers-1.5.21-1.13.1.jolla.armv7hl sailfish-components-webview-qt5-popups-1.5.21-1.13.1.jolla.armv7hl sailfish-connman-plugin-suspend-0.0.10-1.2.3.jolla.armv7hl sailfish-content-ambiences-default-1.0.12-1.2.5.jolla.noarch sailfish-content-ambiences-default-about-1.0.12-1.2.5.jolla.noarch sailfish-content-ambiences-default-airy-1.0.12-1.2.5.jolla.noarch sailfish-content-ambiences-default-community-1.0.12-1.2.5.jolla.noarch sailfish-content-ambiences-default-default-ambience-1.0.12-1.2.5.jolla.noarch sailfish-content-ambiences-default-favorites-1.0.12-1.2.5.jolla.noarch sailfish-content-ambiences-default-flow-1.0.12-1.2.5.jolla.noarch sailfish-content-ambiences-default-glacial-1.0.12-1.2.5.jolla.noarch sailfish-content-ambiences-default-origami-1.0.12-1.2.5.jolla.noarch sailfish-content-ambiences-default-party-1.0.12-1.2.5.jolla.noarch sailfish-content-ambiences-default-rolling-1.0.12-1.2.5.jolla.noarch sailfish-content-ambiences-default-sailfish3-1.0.12-1.2.5.jolla.noarch sailfish-content-ambiences-default-sailing-1.0.12-1.2.5.jolla.noarch sailfish-content-ambiences-default-salamander-1.0.12-1.2.5.jolla.noarch sailfish-content-ambiences-default-silent-1.0.12-1.2.5.jolla.noarch sailfish-content-ambiences-default-work-1.0.12-1.2.5.jolla.noarch sailfish-content-apps-default-configs-0.11.17-1.15.1.jolla.noarch sailfish-content-browser-default-0.1.7-1.3.1.jolla.noarch sailfish-content-gallery-configuration-2k-0.31.5-1.5.1.jolla.noarch sailfish-content-gallery-default-0.32.0-1.1.9.jolla.noarch sailfish-content-graphics-closed-0.7.0-1.3.1.jolla.noarch sailfish-content-graphics-closed-z1.75-0.7.0-1.3.1.jolla.noarch sailfish-content-graphics-default-1.4.2-1.8.2.jolla.noarch sailfish-content-graphics-default-z1.75-1.4.2-1.8.2.jolla.noarch sailfish-content-profiled-settings-default-0.16.2-1.2.1.jolla.noarch sailfish-content-tones-default-0.16.2-1.2.1.jolla.noarch sailfish-content-vpn-default-0.0.1-1.2.9.jolla.noarch sailfish-device-encryption-0.11.7-1.8.2.jolla.armv7hl sailfish-device-encryption-service-0.11.13-1.14.1.jolla.armv7hl sailfish-device-encryption-settings-0.11.7-1.8.2.jolla.armv7hl sailfish-device-encryption-unlock-ui-0.11.13-1.14.1.jolla.armv7hl sailfish-device-encryption-unlock-ui-resources-z1.75-0.11.13-1.14.1.jolla.armv7hl sailfish-devicelock-fpd-1.1.4-1.2.2.jolla.armv7hl sailfish-devicelock-libs-1.2.0-1.4.2.jolla.armv7hl sailfish-filemanager-0.1.4-1.4.3.jolla.armv7hl sailfish-filemanager-l10n-all-translations-1.26.1-1.6.1.jolla.noarch sailfish-fonts-0.3.1-1.1.1.jolla.noarch sailfish-fpd-1.5.6-1.5.1.jolla.armv7hl sailfish-fpd-slave-binder-1.5.6-1.3.1.jolla.armv7hl sailfish-homescreen-services-0.1.9-1.6.3.jolla.armv7hl sailfish-homescreen-services-libs-0.1.10-1.7.2.jolla.armv7hl sailfish-installationhandler-1.0.11-1.7.3.jolla.armv7hl sailfish-locale-1.0.2-1.2.4.jolla.armv7hl sailfish-maps-all-translations-pack-0.8.2-1.5.1.jolla.noarch sailfish-minui-resources-z1.75-0.1.8-1.9.1.jolla.armv7hl sailfish-office-1.6.8-1.8.3.jolla.armv7hl sailfish-office-all-translations-pack-0.8.2-1.5.3.jolla.noarch sailfish-policy-0.4.20-1.2.2.jolla.armv7hl sailfishsecretsdaemon-0.2.38-1.11.3.jolla.armv7hl sailfishsecretsdaemon-cryptoplugins-default-0.2.38-1.11.3.jolla.armv7hl sailfishsecretsdaemon-cryptoplugins-gnupg-0.2.38-1.11.3.jolla.armv7hl sailfishsecretsdaemon-secretsplugin-common-0.2.38-1.11.3.jolla.armv7hl sailfishsecretsdaemon-secretsplugins-default-0.2.38-1.11.3.jolla.armv7hl sailfish-secrets-ui-0.1.9-1.3.4.jolla.armv7hl sailfish-settings-networking-1.0.31.2-1.16.1.jolla.armv7hl sailfish-settings-networking-vpn-1.0.52-1.28.1.jolla.armv7hl sailfish-setup-0.3.4-1.6.2.jolla.noarch sailfishshare-components-1.1.6-1.1.2.jolla.armv7hl sailfish-silica-background-qt5-0.9.15-1.1.18.jolla.armv7hl sailfishsilica-qt5-1.2.119.1-1.21.1.jolla.armv7hl sailfish-tutorial-default-0.2.33-1.8.1.jolla.armv7hl sailfish-tutorial-default-data-0.2.34-1.8.1.jolla.noarch sailfish-upgrade-ui-0.1.18-1.4.1.jolla.armv7hl sailfish-upgrade-ui-resources-logo-z1.75-0.1.18-1.4.1.jolla.armv7hl sailfish-upgrade-ui-resources-z1.75-0.1.18-1.4.1.jolla.armv7hl sailfish-utilities-0.1.22-1.9.1.jolla.armv7hl sailfish-utilities-all-translations-pack-0.8.2-1.5.3.jolla.noarch sailfish-version-5.0.0-1.11.55.jolla.noarch sailfish-version-variant-5.0.0-1.11.55.jolla.noarch sailfish-wayland-libs-0.1.4-1.4.3.jolla.armv7hl sailfish-weather-1.0.16-1.9.1.jolla.armv7hl sailfish-weather-all-translations-pack-0.8.2-1.5.2.jolla.noarch sailjail-1.1.26-1.18.2.jolla.armv7hl sailjail-daemon-1.1.26-1.18.2.jolla.armv7hl sailjail-permissions-1.1.15-1.35.1.jolla.armv7hl screen-4.9.1+git1-1.9.2.jolla.armv7hl sdk-deploy-rpm-1.7-1.4.3.jolla.armv7hl SDL2-2.30.0+git2-1.9.3.jolla.armv7hl SDL2_gfx-1.0.4+git5-1.7.1.jolla.armv7hl SDL2_image-2.8.2+git1-1.8.2.jolla.armv7hl SDL2_mixer-2.8.0+git1-1.8.2.jolla.armv7hl SDL2_net-2.2.0+git1-1.7.4.jolla.armv7hl SDL2_ttf-2.22.0+git1-1.8.2.jolla.armv7hl sensorfw-qt5-0.15.0-1.14.1.jolla.armv7hl sensorfw-qt5-configs-0.15.0-1.14.1.jolla.noarch setup-2.13.6+git6-1.10.3.jolla.noarch shadow-utils-4.16+git1-1.8.1.jolla.armv7hl shared-mime-info-2.4+git2-1.9.2.jolla.armv7hl signon-plugin-oauth2-qt5-0.25+git5-1.7.3.jolla.armv7hl signon-qt5-8.61.0+git1-1.10.1.jolla.armv7hl simkit-0.4.31-1.4.4.jolla.armv7hl sound-theme-freedesktop-0.8+git1-1.6.2.jolla.noarch speex-1.2.1+git2-1.7.3.jolla.armv7hl speexdsp-1.2.1+git1-1.6.2.jolla.armv7hl sqlcipher-4.5.0+git2-1.5.7.jolla.armv7hl sqlite-3.46.1+git1-1.9.2.jolla.armv7hl sqlite-libs-3.46.1+git1-1.9.2.jolla.armv7hl ssu-1.6.0-1.13.1.jolla.armv7hl ssu-declarative-1.6.0-1.13.1.jolla.armv7hl ssu-sysinfo-1.5.0-1.9.1.jolla.armv7hl ssu-vendor-data-jolla-1.1.3-1.16.1.jolla.noarch store-client-1.3.14-1.8.2.jolla.armv7hl store-client-common-1.4.0-1.16.1.jolla.armv7hl sudo-1.9.15p4+git1-1.4.2.jolla.armv7hl swi-prolog-7.6.4+git3-1.7.3.jolla.armv7hl swi-prolog-library-core-7.6.4+git3-1.7.3.jolla.armv7hl swi-prolog-runtime-lib-7.6.4+git3-1.7.3.jolla.armv7hl systemd-238+git23-1.15.1.jolla.armv7hl systemd-config-sailfish-0.11.17-1.15.1.jolla.noarch systemd-libs-238+git23-1.15.1.jolla.armv7hl systemd-user-session-targets-0.0.2-1.6.3.jolla.noarch taglib-1.12+git2-1.5.6.jolla.armv7hl tayga-0.9.2+git3-1.1.2.jolla.armv7hl tcpdump-4.99.4+git1-1.5.1.jolla.armv7hl telepathy-accounts-signon-0.1.29-1.7.2.jolla.armv7hl telepathy-farstream-0.6.2+git1-1.4.5.jolla.armv7hl telepathy-gabble-0.18.4+git6-1.8.3.jolla.armv7hl telepathy-glib-0.24.1+git1-1.4.5.jolla.armv7hl telepathy-mission-control-5.16.6+git7-1.6.4.jolla.armv7hl telepathy-qt5-0.9.8+git5-1.9.6.jolla.armv7hl telepathy-qt5-farstream-0.9.8+git5-1.9.6.jolla.armv7hl telepathy-ring-2.5.13-1.6.14.jolla.armv7hl thumbnaild-0.1.2-1.8.2.jolla.armv7hl timed-qt5-3.6.21-1.13.1.jolla.armv7hl timed-qt5-tools-3.6.21-1.13.1.jolla.armv7hl totem-pl-parser-3.26.6+git3-1.6.5.jolla.armv7hl tracker-3.3.3+git2-1.7.4.jolla.armv7hl tracker-miners-3.3.3+git1-1.9.1.jolla.armv7hl transferengine-plugin-bluetooth-0.4.2-1.9.1.jolla.armv7hl transferengine-plugin-core-0.4.5-1.12.1.jolla.armv7hl transferengine-plugin-nextcloud-1.0.9-1.10.1.jolla.armv7hl transferengine-plugins-0.4.2-1.9.1.jolla.armv7hl tzdata-2024a+git1-1.6.1.jolla.noarch tzdata-timed-2024a+git1-1.8.2.jolla.noarch udisks2-2.9.4+git5-1.10.4.jolla.armv7hl unzip-6.0-1.5.13.jolla.armv7hl usb-moded-0.86.0+mer66-1.13.2.jolla.armv7hl user-managerd-0.8.9-1.9.2.jolla.armv7hl util-linux-2.38.1+git6-1.13.1.jolla.armv7hl vault-1.0.6-1.6.1.jolla.armv7hl vim-common-9.1.0727+git1-1.9.1.jolla.armv7hl vim-data-9.1.0727+git1-1.9.1.jolla.noarch vim-enhanced-9.1.0727+git1-1.9.1.jolla.armv7hl vim-filesystem-9.1.0727+git1-1.9.1.jolla.armv7hl vim-minimal-9.1.0727+git1-1.9.1.jolla.armv7hl voicecall-qt5-0.8.2-1.10.2.jolla.armv7hl voicecall-qt5-plugin-telepathy-0.8.2-1.10.2.jolla.armv7hl voicecall-ui-jolla-1.15.5-1.8.1.jolla.armv7hl voicecall-ui-jolla-settings-1.15.5-1.8.1.jolla.armv7hl volume_key-libs-0.3.9+git3-1.6.4.jolla.armv7hl vpnc-0.5.3.r526+git3-1.6.2.jolla.armv7hl wayland-1.22.0+git1-1.7.1.jolla.armv7hl wayland-egl-1.22.0+git1-1.7.1.jolla.armv7hl wireless-regdb-2020.04.29+git5-1.6.2.jolla.noarch wpa_supplicant-2.11+git4-1.14.1.jolla.armv7hl xdg-dbus-proxy-0.1.2+git4-1.6.4.jolla.armv7hl xdg-user-dirs-0.17+git2-1.6.3.jolla.armv7hl xdg-utils-1.2.1+git1-1.9.1.jolla.noarch xkeyboard-config-2.37+git2-1.7.1.jolla.noarch xl2tpd-1.3.16+git1-1.6.3.jolla.armv7hl xulrunner-qt5-78.15.1+git39-1.19.1.jolla.armv7hl xz-5.6.2+git1-1.5.1.jolla.armv7hl xz-libs-5.6.2+git1-1.5.1.jolla.armv7hl xz-lzma-compat-5.6.2+git1-1.5.1.jolla.armv7hl yaml-cpp-0.6.3+git1-1.5.5.jolla.armv7hl zlib-1.3.1+git1-1.9.1.jolla.armv7hl zstd-1.5.0+git2-1.2.5.jolla.armv7hl zxing-cpp-2.0.0+git1-1.8.3.jolla.armv7hl zypper-1.14.68+git1-1.7.2.jolla.armv7hl
LIST SUCCESS STATE
``` abseil-cpp-20230801.1+git1-1.2.2.jolla.armv7hl acl-2.3.1+git2-1.6.20.jolla.armv7hl aliendalvik-2.1.0-1.7.1.jolla.armv7hl aliendalvik-configs-11.0.168-1.37.1.jolla.armv7hl all-translations-pack-0.8.2-1.5.3.jolla.noarch alsa-lib-1.2.8+git1-1.6.2.jolla.armv7hl amber-mpris-1.2.9-1.9.2.jolla.armv7hl amber-qml-plugin-mpris-1.2.9-1.9.2.jolla.armv7hl ambienced-0.29.37-1.12.1.jolla.armv7hl apkd8-11.0.0.134-1.41.1.jolla.armv7hl apkd8-android-settings-11.0.0.134-1.41.1.jolla.armv7hl apkd8-l10n-all-translations-1.88.2-1.12.1.jolla.noarch apkd-plugin-geo-qtpositioning-1.0.1-1.2.1.jolla.armv7hl apkd-plugin-launchers-fdo-ext-1.4.2-1.4.1.jolla.armv7hl apkd-plugin-media-mpris-1.0.3-1.3.1.jolla.armv7hl apkd-plugin-notifications-fdo-ext-1.0.7-1.3.1.jolla.armv7hl apkd-plugin-permissions-sfos-1.3.0-1.4.1.jolla.armv7hl apkd-sharing-sfos-1.4.2-1.4.1.jolla.armv7hl appsupport11-system-privileged-11.0.0.76.53-1.16.1.jolla.armv7hl appsupportaudio-1.33.0-1.5.1.jolla.armv7hl appsupportaudio-plugin-pulseaudio-1.25.1-1.2.1.jolla.armv7hl appsupportaudio-plugin-sailfish-1.7.0-1.1.1.jolla.armv7hl appsupport-config-generator-1.12.5-1.21.1.jolla.armv7hl appsupportkeyboardservice-1.0.2-1.3.1.jolla.armv7hl archivemount-0.9.1+git2-1.6.4.jolla.armv7hl audiosystem-passthrough-1.3.1-1.5.1.jolla.armv7hl audiosystem-passthrough-dummy-af-1.3.1-1.5.1.jolla.armv7hl audit-libs-3.1.2+git1-1.9.2.jolla.armv7hl audit-libs-python3-3.1.2+git1-1.9.2.jolla.armv7hl augeas-libs-1.12.0+git4-1.6.4.jolla.armv7hl basesystem-11+git1-1.5.3.jolla.noarch binder-utils-1.0.7-1.4.1.jolla.armv7hl bindfs-1.13.10+git1-1.2.1.jolla.armv7hl bind-utils-9.11.19+git2-1.2.2.jolla.armv7hl binutils-2.42+git1-1.8.3.jolla.armv7hl bluebinder-1.0.18-1.3.2.jolla.armv7hl bluez5-5.76+git2-1.11.1.jolla.armv7hl bluez5-libs-5.76+git2-1.11.1.jolla.armv7hl bluez5-obexd-5.76+git2-1.11.1.jolla.armv7hl bluez5-tools-5.76+git2-1.11.1.jolla.armv7hl bluez5-tools-hciattach-5.76+git2-1.11.1.jolla.armv7hl boost-atomic-1.81.0+git2-1.8.3.jolla.armv7hl boost-chrono-1.81.0+git2-1.8.3.jolla.armv7hl boost-date-time-1.81.0+git2-1.8.3.jolla.armv7hl boost-filesystem-1.81.0+git2-1.8.3.jolla.armv7hl boost-system-1.81.0+git2-1.8.3.jolla.armv7hl boost-thread-1.81.0+git2-1.8.3.jolla.armv7hl busybox-1.36.1+git6-1.13.1.jolla.armv7hl busybox-symlinks-coreutils-1.36.1+git6-1.13.1.jolla.armv7hl busybox-symlinks-dhcp-1.36.1+git6-1.13.1.jolla.armv7hl busybox-symlinks-diffutils-1.36.1+git6-1.13.1.jolla.armv7hl busybox-symlinks-dosfstools-1.36.1+git6-1.13.1.jolla.armv7hl busybox-symlinks-findutils-1.36.1+git6-1.13.1.jolla.armv7hl busybox-symlinks-grep-1.36.1+git6-1.13.1.jolla.armv7hl busybox-symlinks-gzip-1.36.1+git6-1.13.1.jolla.armv7hl busybox-symlinks-procps-1.36.1+git6-1.13.1.jolla.armv7hl busybox-symlinks-psmisc-1.36.1+git6-1.13.1.jolla.armv7hl busybox-symlinks-sed-1.36.1+git6-1.13.1.jolla.armv7hl busybox-symlinks-tar-1.36.1+git6-1.13.1.jolla.armv7hl busybox-symlinks-which-1.36.1+git6-1.13.1.jolla.armv7hl buteo-mtp-qt5-0.9.10-1.10.1.jolla.armv7hl buteo-syncfw-qt5-0.11.6-1.24.9.jolla.armv7hl buteo-syncfw-qt5-msyncd-0.11.6-1.24.9.jolla.armv7hl buteo-sync-plugin-caldav-0.3.12-1.14.3.jolla.armv7hl buteo-sync-plugin-carddav-0.1.10-1.11.4.jolla.armv7hl buteo-sync-plugin-nextcloud-backup-1.0.12-1.13.1.jolla.armv7hl buteo-sync-plugin-nextcloud-images-1.0.12-1.13.1.jolla.armv7hl buteo-sync-plugin-nextcloud-posts-1.0.12-1.13.1.jolla.armv7hl buteo-sync-plugins-email-0.1.10-1.9.3.jolla.armv7hl buteo-sync-plugins-social-0.4.27-1.18.3.jolla.armv7hl buteo-sync-plugins-social-dropbox-0.4.27-1.18.3.jolla.armv7hl buteo-sync-plugins-social-facebook-0.4.27-1.18.3.jolla.armv7hl buteo-sync-plugins-social-google-0.4.27-1.18.3.jolla.armv7hl buteo-sync-plugins-social-onedrive-0.4.27-1.18.3.jolla.armv7hl buteo-sync-plugins-social-twitter-0.4.27-1.18.3.jolla.armv7hl buteo-sync-plugin-webcal-0.1.12-1.9.1.jolla.armv7hl bzip2-1.0.8+git2-1.6.6.jolla.armv7hl bzip2-libs-1.0.8+git2-1.6.6.jolla.armv7hl ca-certificates-2023.2.62_v7.0.401-1.6.1.jolla.noarch cairo-1.18.0+git1-1.8.3.jolla.armv7hl calligra-components-3.2.1+git5-1.12.2.jolla.armv7hl calligra-data-3.2.1+git5-1.12.2.jolla.armv7hl calligra-filters-3.2.1+git5-1.12.2.jolla.armv7hl calligra-kf5-3.2.1+git5-1.12.2.jolla.armv7hl calligra-libs-3.2.1+git5-1.12.2.jolla.armv7hl calligra-plugins-3.2.1+git5-1.12.2.jolla.armv7hl calligra-sheets-core-3.2.1+git5-1.12.2.jolla.armv7hl calligra-stage-core-3.2.1+git5-1.12.2.jolla.armv7hl calligra-words-core-3.2.1+git5-1.12.2.jolla.armv7hl checkpolicy-3.1+git2-1.4.5.jolla.armv7hl commhistory-daemon-0.9.5-1.17.2.jolla.armv7hl connectionagent-qt5-0.12.5-1.10.1.jolla.armv7hl connectionagent-qt5-declarative-0.12.5-1.10.1.jolla.armv7hl connman-1.38+git12-1.31.1.jolla.armv7hl connman-configs-sailfish-0.11.17-1.15.1.jolla.noarch connman-network-monitor-0.0.0+git3-1.6.1.jolla.armv7hl connman-plugin-vpn-l2tp-1.38+git12-1.31.1.jolla.armv7hl connman-plugin-vpn-openconnect-1.38+git12-1.31.1.jolla.armv7hl connman-plugin-vpn-openvpn-1.38+git12-1.31.1.jolla.armv7hl connman-plugin-vpn-pptp-1.38+git12-1.31.1.jolla.armv7hl connman-plugin-vpn-vpnc-1.38+git12-1.31.1.jolla.armv7hl connman-qt5-1.4.11-1.19.1.jolla.armv7hl connman-qt5-declarative-1.4.11-1.19.1.jolla.armv7hl connman-tools-1.38+git12-1.31.1.jolla.armv7hl connman-vpn-scripts-1.38+git12-1.31.1.jolla.armv7hl contactsd-1.4.14-1.17.4.jolla.armv7hl cor-0.1.21-1.4.8.jolla.armv7hl cpio-2.15+git1-1.8.3.jolla.armv7hl crda-4.14+git5-1.6.7.jolla.armv7hl cryptsetup-2.4.3+git1-1.5.3.jolla.armv7hl cryptsetup-libs-2.4.3+git1-1.5.3.jolla.armv7hl csd-0.16.50-1.15.1.jolla.armv7hl curl-8.9.1+git1-1.11.2.jolla.armv7hl db4-4.8.30-1.6.6.jolla.armv7hl db4-utils-4.8.30-1.6.6.jolla.armv7hl dbus-1.14.10+git1-1.7.1.jolla.armv7hl dbusextended-qt5-0.0.3-1.2.1.jolla.armv7hl dbus-glib-0.100.2-1.4.6.jolla.armv7hl dbus-libs-1.14.10+git1-1.7.1.jolla.armv7hl dconf-0.40.0+git5-1.9.2.jolla.armv7hl declarative-transferengine-qt5-1.1.11-1.7.1.jolla.armv7hl deltarpm-3.6.3+git1-1.6.12.jolla.armv7hl desktop-file-utils-0.26+git4-1.7.4.jolla.armv7hl device-mapper-2.02.177+git6-1.7.4.jolla.armv7hl device-mapper-event-2.02.177+git6-1.7.4.jolla.armv7hl device-mapper-event-libs-2.02.177+git6-1.7.4.jolla.armv7hl device-mapper-libs-2.02.177+git6-1.7.4.jolla.armv7hl dirmngr-1.0.3+git3-1.7.2.jolla.armv7hl droid-config-i4113-0.0.78-1.12.1.jolla.armv7hl droid-config-i4113-bluez5-0.0.78-1.12.1.jolla.armv7hl droid-config-i4113-flashing-0.0.78-1.12.1.jolla.armv7hl droid-config-i4113-policy-settings-0.0.78-1.12.1.jolla.armv7hl droid-config-i4113-preinit-plugin-0.0.78-1.12.1.jolla.armv7hl droid-config-i4113-pulseaudio-settings-0.0.78-1.12.1.jolla.armv7hl droid-config-i4113-sailfish-0.0.78-1.12.1.jolla.noarch droid-hal-kirin-0.0.59-1.10.5.jolla.armv7hl droid-hal-kirin-detritus-0.0.59-1.10.5.jolla.armv7hl droid-hal-kirin-img-boot-4.9.210.20240702.1-1.4.10.jolla.armv7hl droid-hal-kirin-img-recovery-4.9.210.20240702.1-1.4.10.jolla.armv7hl droid-hal-kirin-tools-0.0.59-1.10.5.jolla.armv7hl droid-hal-kirin-users-0.0.59-1.10.5.jolla.armv7hl droid-hal-version-i4113-1.0.0-1.4.25.jolla.armv7hl droidmedia-0.20240905.0-1.9.1.jolla.armv7hl droid-system-kirin-0.1.0-1.2.1.jolla.armv7hl droid-system-kirin-i4113-0.1.0-1.2.1.jolla.armv7hl droid-system-vendor-kirin-0.1.0-1.2.1.jolla.armv7hl droid-system-vendor-kirin-i4113-0.1.0-1.2.1.jolla.armv7hl dsme-0.84.4-1.11.1.jolla.armv7hl duktape-2.7.0-1.1.1.jolla.armv7hl e2fsprogs-1.47.0+git2-1.6.3.jolla.armv7hl e2fsprogs-libs-1.47.0+git2-1.6.3.jolla.armv7hl elfutils-0.190+git1-1.7.5.jolla.armv7hl elfutils-libelf-0.190+git1-1.7.5.jolla.armv7hl elfutils-libs-0.190+git1-1.7.5.jolla.armv7hl embedlite-components-qt5-1.25.3-1.30.1.jolla.armv7hl eventsview-extensions-0.1.11-1.4.1.jolla.armv7hl eventsview-extensions-nextcloud-1.0.12-1.13.1.jolla.armv7hl eventsview-extensions-twitter-posts-0.1.11-1.4.1.jolla.armv7hl exempi-2.5.2+git1-1.8.7.jolla.armv7hl expat-2.6.1+git1-1.7.4.jolla.armv7hl farstream-0.2.9+git2-1.6.1.jolla.armv7hl feature-alien-0.5.1-1.3.1.jolla.armv7hl feature-jolla-0.3.0-1.7.10.jolla.noarch feature-sailfish-eas-0.1.1-1.3.1.jolla.armv7hl feature-xt9-0.1.1-1.3.1.jolla.armv7hl ffmpeg-5.1.6+git1-1.10.3.jolla.armv7hl file-5.41+git1-1.6.7.jolla.armv7hl file-libs-5.41+git1-1.6.7.jolla.armv7hl filesystem-3.16+git1-1.8.2.jolla.armv7hl fingerterm-1.4.13-1.15.1.jolla.armv7hl firejail-0.9.72+git3-1.10.1.jolla.armv7hl flac-1.4.3+git1-1.6.2.jolla.armv7hl fontconfig-2.13.96+git3-1.5.3.jolla.armv7hl fontpackages-filesystem-1.44-1.5.2.jolla.noarch freetype-2.13.1+git1-1.6.3.jolla.armv7hl fribidi-1.0.12+git1-1.7.3.jolla.armv7hl fuse-2.9.9+git3-1.6.2.jolla.armv7hl fuse-common-3.16.2+git1-1.6.1.jolla.armv7hl fuse-libs-2.9.9+git3-1.6.2.jolla.armv7hl gawk-3.1.5-1.5.6.jolla.armv7hl gdb-gdbserver-12.1.0+git2-1.9.2.jolla.armv7hl gecko-camera-0.1.7-1.5.3.jolla.armv7hl gecko-camera-droid-plugin-0.1.7-1.5.2.jolla.armv7hl geoclue-0.12.99.8+git2-1.6.4.jolla.armv7hl geoclue-provider-hybris-binder-0.2.38-1.7.1.jolla.armv7hl geoclue-provider-mlsdb-0.2.2-1.6.3.jolla.armv7hl geoclue-provider-mlsdb-agreements-0.2.2-1.6.3.jolla.armv7hl giflib-5.2.2+git1-1.8.2.jolla.armv7hl glib2-2.78.4+git4-1.8.1.jolla.armv7hl glibc-2.30+git12-1.10.3.jolla.armv7hl glibc-common-2.30+git12-1.10.3.jolla.armv7hl glib-networking-2.78.0+git1-1.5.2.jolla.armv7hl gmime-3.2.14+git1-1.8.3.jolla.armv7hl gmp-droid-0.8-1.4.2.jolla.armv7hl gnu-bash-5.0.18+git2-1.6.6.jolla.armv7hl gnupg2-2.0.4+git5-1.7.5.jolla.armv7hl gnutls-2.12.24+git2-1.6.11.jolla.armv7hl gpgme-1.2.0+git9-1.8.2.jolla.armv7hl graphite2-1.3.14+git2-1.5.5.jolla.armv7hl grilo-0.3.15+git1-1.6.3.jolla.armv7hl grilo-plugins-0.3.15+git1-1.8.3.jolla.armv7hl grilo-plugin-tracker-0.3.15+git1-1.8.3.jolla.armv7hl grilo-qt5-0.4.3-1.12.1.jolla.armv7hl grilo-qt5-qml-plugin-0.4.3-1.12.1.jolla.armv7hl gstreamer1.0-1.24.6+git1-1.12.1.jolla.armv7hl gstreamer1.0-droid-0.20240806.0-1.6.1.jolla.armv7hl gstreamer1.0-libav-1.24.6+git1-1.11.1.jolla.armv7hl gstreamer1.0-plugins-bad-1.24.6+git1-1.11.2.jolla.armv7hl gstreamer1.0-plugins-base-1.24.6+git1-1.11.1.jolla.armv7hl gstreamer1.0-plugins-good-1.24.6+git1-1.12.1.jolla.armv7hl harbour-barcode-1.0.55-1.armv7hl harbour-fahrplan2-2.0.31-1.armv7hl harbour-foilauth-1.0.21-1.armv7hl harbour-foilnotes-1.0.28-1.armv7hl harbour-foilpics-1.0.23-1.armv7hl harbour-qrclip-1.0.12-1.armv7hl harbour-screen-message-0.3.1-1.armv7hl harbour-scribble-0.6-2.armv7hl harbour-simplecrop-1.2.3-1.noarch harbour-tasklist-1.8.14-1.armv7hl harbour-unplayer-2.1.1-1.armv7hl harfbuzz-8.1.1+git1-1.5.2.jolla.armv7hl htop-3.2.0+git1-1.2.4.jolla.armv7hl htop-desktop-3.2.0+git1-1.2.4.jolla.noarch hunspell-1.7.1+git1-1.7.2.jolla.armv7hl hwdata-0.387+git2-1.6.1.jolla.noarch hybris-libsensorfw-qt5-binder-0.15.0-1.11.1.jolla.armv7hl info-6.3+git1-1.6.3.jolla.armv7hl iproute-6.9.0+git1-1.7.1.jolla.armv7hl iptables-1.8.10+git1-1.7.2.jolla.armv7hl iptables-ipv6-1.8.10+git1-1.7.2.jolla.armv7hl iw-5.0.1+git2-1.6.3.jolla.armv7hl jolla-actdead-charging-0.13.13-1.2.3.jolla.armv7hl jolla-alarm-ui-0.2.24-1.11.1.jolla.armv7hl jolla-alarm-ui-all-translations-pack-0.8.2-1.5.3.jolla.noarch jolla-ambient-sound-theme-0.1.0-1.2.2.jolla.noarch jolla-ca-0.11-1.3.2.jolla.noarch jolla-calculator-1.0.11-1.6.1.jolla.armv7hl jolla-calculator-all-translations-pack-0.8.2-1.5.2.jolla.noarch jolla-calendar-1.1.17-1.13.1.jolla.armv7hl jolla-calendar-all-translations-pack-0.8.2-1.5.3.jolla.noarch jolla-camera-1.2.30.3-1.17.1.jolla.armv7hl jolla-camera-lockscreen-1.2.30.3-1.17.1.jolla.armv7hl jolla-camera-settings-1.2.30.3-1.17.1.jolla.armv7hl jolla-clock-1.1.26-1.11.1.jolla.armv7hl jolla-clock-all-translations-pack-0.8.2-1.5.3.jolla.noarch jolla-common-configurations-0.11.17-1.15.1.jolla.noarch jolla-contacts-0.6.42-1.11.1.jolla.armv7hl jolla-contacts-settings-0.6.42-1.11.1.jolla.armv7hl jolla-developer-mode-0.6.23-1.4.7.jolla.armv7hl jolla-developer-mode-preload-0.6.23-1.4.7.jolla.armv7hl jolla-developer-mode-profile-0.6.23-1.4.7.jolla.armv7hl jolla-email-1.1.50.1-1.19.2.jolla.armv7hl jolla-email-all-translations-pack-0.8.2-1.5.3.jolla.noarch jolla-email-crypto-gnupg-1.1.50.1-1.19.2.jolla.armv7hl jolla-email-settings-1.1.50.1-1.19.2.jolla.armv7hl jolla-gallery-1.1.10-1.12.1.jolla.armv7hl jolla-gallery-ambience-0.2.41-1.8.1.jolla.armv7hl jolla-gallery-extension-nextcloud-1.0.12-1.13.1.jolla.armv7hl jolla-gallery-extensions-0.2.17-1.3.1.jolla.armv7hl jolla-gallery-extensions-dropbox-0.2.17-1.3.1.jolla.armv7hl jolla-gallery-extensions-onedrive-0.2.17-1.3.1.jolla.armv7hl jolla-gallery-facebook-0.1.16-1.5.1.jolla.armv7hl jolla-handwriting-0.1.7-1.3.3.jolla.armv7hl jolla-keyboard-0.9.10-1.13.1.jolla.armv7hl jolla-keyboard-hwr-0.9.10-1.13.1.jolla.armv7hl jolla-keyboard-layout-all-0.9.10-1.13.1.jolla.armv7hl jolla-keyboard-layout-chinese-0.9.10-1.13.1.jolla.armv7hl jolla-keyboard-layout-indian-0.9.10-1.13.1.jolla.armv7hl jolla-keyboard-layout-kazakh-0.9.10-1.13.1.jolla.armv7hl jolla-keyboard-layout-russian-0.9.10-1.13.1.jolla.armv7hl jolla-keyboard-layout-tatar-0.9.10-1.13.1.jolla.armv7hl jolla-keyboard-layout-western-0.9.10-1.13.1.jolla.armv7hl jolla-keyboard-settings-xt9-0.9.10-1.13.1.jolla.armv7hl jolla-mediaplayer-1.3.19-1.11.1.jolla.armv7hl jolla-mediaplayer-all-translations-pack-0.8.2-1.5.2.jolla.noarch jolla-messages-1.1.74-1.13.1.jolla.armv7hl jolla-messages-settings-1.1.74-1.13.1.jolla.armv7hl jolla-notes-1.0.25-1.7.1.jolla.armv7hl jolla-notes-all-translations-pack-0.8.2-1.5.1.jolla.noarch jolla-notes-settings-1.0.25-1.7.1.jolla.armv7hl jolla-rnd-device-0.5.2-1.1.9.jolla.armv7hl jolla-sessions-qt5-1.4.24-1.5.1.jolla.armv7hl jolla-settings-1.2.0-1.13.1.jolla.armv7hl jolla-settings-accounts-0.4.86-1.17.1.jolla.armv7hl jolla-settings-accounts-extensions-0.4.86-1.17.1.jolla.armv7hl jolla-settings-accounts-extensions-3rd-party-all-0.4.86-1.17.1.jolla.armv7hl jolla-settings-accounts-extensions-dropbox-0.4.86-1.17.1.jolla.armv7hl jolla-settings-accounts-extensions-email-0.4.86-1.17.1.jolla.armv7hl jolla-settings-accounts-extensions-email-crypto-0.4.86-1.17.1.jolla.armv7hl jolla-settings-accounts-extensions-facebook-0.4.86-1.17.1.jolla.armv7hl jolla-settings-accounts-extensions-fruux-0.4.86-1.17.1.jolla.armv7hl jolla-settings-accounts-extensions-google-0.4.86-1.17.1.jolla.armv7hl jolla-settings-accounts-extensions-jabber-0.4.86-1.17.1.jolla.armv7hl jolla-settings-accounts-extensions-jolla-0.4.86-1.17.1.jolla.armv7hl jolla-settings-accounts-extensions-memotoo-0.4.86-1.17.1.jolla.armv7hl jolla-settings-accounts-extensions-onedrive-0.4.86-1.17.1.jolla.armv7hl jolla-settings-accounts-extensions-onlinesync-0.4.86-1.17.1.jolla.armv7hl jolla-settings-accounts-extensions-twitter-0.4.86-1.17.1.jolla.armv7hl jolla-settings-accounts-extensions-webcal-0.4.86-1.17.1.jolla.armv7hl jolla-settings-accounts-extensions-yahoo-0.4.86-1.17.1.jolla.armv7hl jolla-settings-bluetooth-0.2.19-1.6.1.jolla.armv7hl jolla-settings-homescreen-1.2.50.1-1.35.1.jolla.armv7hl jolla-settings-layout-1.2.0-1.13.1.jolla.armv7hl jolla-settings-networking-1.0.52-1.28.1.jolla.armv7hl jolla-settings-networking-cellular-1.0.52-1.28.1.jolla.armv7hl jolla-settings-networking-multisim-1.0.52-1.28.1.jolla.armv7hl jolla-settings-networking-plugin-vpn-l2tp-1.0.52-1.28.1.jolla.armv7hl jolla-settings-networking-plugin-vpn-openconnect-1.0.52-1.28.1.jolla.armv7hl jolla-settings-networking-plugin-vpn-openvpn-1.0.52-1.28.1.jolla.armv7hl jolla-settings-networking-plugin-vpn-pptp-1.0.52-1.28.1.jolla.armv7hl jolla-settings-networking-plugin-vpn-vpnc-1.0.52-1.28.1.jolla.armv7hl jolla-settings-networking-tethering-1.0.52-1.28.1.jolla.armv7hl jolla-settings-networking-vpn-1.0.52-1.28.1.jolla.armv7hl jolla-settings-sailfishos-0.3.1-1.9.1.jolla.armv7hl jolla-settings-system-1.2.50.1-1.35.1.jolla.armv7hl jolla-settings-system-about-eula-sailfish-1.2.50.1-1.35.1.jolla.armv7hl jolla-settings-system-about-product-license-jolla-1.2.50.1-1.35.1.jolla.armv7hl jolla-settings-system-about-product-trademark-jolla-1.2.50.1-1.35.1.jolla.armv7hl jolla-settings-system-brightness-1.2.50.1-1.35.1.jolla.armv7hl jolla-settings-system-developermode-1.2.50.1-1.35.1.jolla.armv7hl jolla-settings-system-flashlight-1.2.50.1-1.35.1.jolla.armv7hl jolla-settings-system-location-1.2.50.1-1.35.1.jolla.armv7hl jolla-settings-system-nfc-1.2.50.1-1.35.1.jolla.armv7hl jolla-settings-system-orientation-1.2.50.1-1.35.1.jolla.armv7hl jolla-settings-system-presence-1.2.50.1-1.35.1.jolla.armv7hl jolla-settings-system-reset-1.2.50.1-1.35.1.jolla.armv7hl jolla-settings-system-sideloading-1.2.50.1-1.35.1.jolla.armv7hl jolla-settings-transferui-qt5-1.1.11-1.7.1.jolla.armv7hl jolla-signon-ui-0.2.13-1.3.5.jolla.armv7hl jolla-startupwizard-0.6.5-1.20.1.jolla.armv7hl jolla-vault-1.1.46-1.5.2.jolla.armv7hl jolla-vault-units-1.1.46-1.5.2.jolla.armv7hl jolla-xt9-0.5.22-1.6.3.jolla.armv7hl jolla-xt9-cp-0.2.15-1.4.2.jolla.armv7hl json-c-0.15+git1-1.4.5.jolla.armv7hl json-glib-1.6.0+git1-1.4.6.jolla.armv7hl kcalcore-qt5-4.10.2+9git28-1.4.1.jolla.armv7hl kf5bluezqt-bluez5-5.112.0+git2-1.9.3.jolla.armv7hl kf5bluezqt-bluez5-declarative-5.112.0+git2-1.9.3.jolla.armv7hl kf5-calendarcore-5.94+git2-1.10.1.jolla.armv7hl kmod-29+git2-1.6.3.jolla.armv7hl kmod-libs-29+git2-1.6.3.jolla.armv7hl libaccounts-glib-1.24+git5-1.4.5.jolla.armv7hl libaccounts-glib-tools-1.24+git5-1.4.5.jolla.armv7hl libaccounts-qt5-1.16+git3-1.6.5.jolla.armv7hl libacl-2.3.1+git2-1.6.20.jolla.armv7hl libapkd-1.18.2-1.9.1.jolla.armv7hl libappsupportaudio-1.26.0-1.1.1.jolla.armv7hl libarchive-3.7.4+git1-1.10.1.jolla.armv7hl libasyncns-0.8-1.5.4.jolla.armv7hl libattr-2.5.1+git1-1.7.3.jolla.armv7hl libblkid-2.38.1+git6-1.13.1.jolla.armv7hl libblockdev-2.26+git1-1.5.4.jolla.armv7hl libblockdev-crypto-2.26+git1-1.5.4.jolla.armv7hl libblockdev-fs-2.26+git1-1.5.4.jolla.armv7hl libblockdev-loop-2.26+git1-1.5.4.jolla.armv7hl libblockdev-part-2.26+git1-1.5.4.jolla.armv7hl libblockdev-swap-2.26+git1-1.5.4.jolla.armv7hl libblockdev-utils-2.26+git1-1.5.4.jolla.armv7hl libcanberra-0.30+git2-1.6.3.jolla.armv7hl libcap-2.69+git1-1.7.4.jolla.armv7hl libcap-ng-0.8.3+git1-1.7.2.jolla.armv7hl libcgroup-0.41+git2-1.5.2.jolla.armv7hl libcom_err-1.47.0+git2-1.6.3.jolla.armv7hl libcommhistory-qt5-1.12.15-1.20.1.jolla.armv7hl libcommhistory-qt5-declarative-1.12.15-1.20.1.jolla.armv7hl libcommhistory-qt5-tools-1.12.15-1.20.1.jolla.armv7hl libcontentaction-qt5-0.4.8-1.10.1.jolla.armv7hl libcurl-8.9.1+git1-1.11.2.jolla.armv7hl libdbusaccess-1.0.20-1.7.2.jolla.armv7hl libdbuslogserver-dbus-1.0.22-1.5.6.jolla.armv7hl libdbuslogserver-gio-1.0.22-1.5.6.jolla.armv7hl libdbus-qeventloop-qt5-1.32.0-1.9.3.jolla.armv7hl libdres-1.1.18-1.5.5.jolla.armv7hl libdrm-2.4.122+git1-1.7.1.jolla.armv7hl libdsme-0.67.0-1.8.1.jolla.armv7hl libexif-0.6.24+git1-1.5.2.jolla.armv7hl libfdisk-2.38.1+git6-1.13.1.jolla.armv7hl libffi-3.4.4+git1-1.7.2.jolla.armv7hl libgbinder-1.1.40-1.11.1.jolla.armv7hl libgbinder-radio-1.6.0-1.9.1.jolla.armv7hl libgcc-10.3.1-1.8.6.jolla.armv7hl libgcrypt-1.10.3+git1-1.7.2.jolla.armv7hl libglibutil-1.0.79-1.17.1.jolla.armv7hl libgofono-2.1.6-1.8.3.jolla.armv7hl libgofonoext-1.0.14-1.6.3.jolla.armv7hl libgomp-10.3.1-1.8.6.jolla.armv7hl libgpg-error-1.42+git2-1.7.3.jolla.armv7hl libgrilio-1.0.44-1.6.5.jolla.armv7hl libgrilio-binder-1.2.7-1.4.6.jolla.armv7hl libgsf-1.14.52+git1-1.8.2.jolla.armv7hl libgsupplicant-1.0.27-1.8.3.jolla.armv7hl libgudev-237+git1-1.6.5.jolla.armv7hl libhybris-0.0.5.55-1.11.1.jolla.armv7hl libhybris-libEGL-0.0.5.55-1.11.1.jolla.armv7hl libhybris-libGLESv2-0.0.5.55-1.11.1.jolla.armv7hl libhybris-libhardware-0.0.5.55-1.11.1.jolla.armv7hl libhybris-libsync-0.0.5.55-1.11.1.jolla.armv7hl libhybris-libwayland-egl-0.0.5.55-1.11.1.jolla.armv7hl libical-3.0.16+git1-1.6.4.jolla.armv7hl libicu-70.1+git1-1.6.2.jolla.armv7hl libiodata-qt5-0.19.14-1.8.2.jolla.armv7hl libiphb-1.2.7-1.4.4.jolla.armv7hl libiptcdata-1.0.5+git1-1.4.4.jolla.armv7hl libjollamediaplayer-1.3.19-1.11.1.jolla.armv7hl libjollasettingssailfishos-0.3.1-1.9.1.jolla.armv7hl libjollasignontrampolineservice-qt5-0.4.22-1.7.1.jolla.armv7hl libjollasignonuiservice-qt5-0.4.22-1.7.1.jolla.armv7hl libjollasignonuiservice-qt5-plugin-0.4.22-1.7.1.jolla.armv7hl libjpeg-turbo-3.0.3+git1-1.8.1.jolla.armv7hl libkeepalive-1.8.11-1.9.2.jolla.armv7hl libkeepalive-glib-1.8.11-1.9.2.jolla.armv7hl libkf5archive-5.75.0+git1-1.4.9.jolla.armv7hl libksba-1.6.3+git1-1.8.2.jolla.armv7hl liblua-5.4.6-1.7.3.jolla.armv7hl libmce-glib-1.1.0-1.7.2.jolla.armv7hl libmce-qt5-1.5.1-1.7.2.jolla.armv7hl libmce-qt5-declarative-1.5.1-1.7.2.jolla.armv7hl libmediaart-1.9.5+git1-1.6.4.jolla.armv7hl libmlocale-qt5-0.7.8-1.9.1.jolla.armv7hl libmount-2.38.1+git6-1.13.1.jolla.armv7hl libmpg123-1.32.5+git1-1.9.2.jolla.armv7hl libncicore-1.1.28-1.5.1.jolla.armv7hl libnciplugin-1.2.0-1.8.1.jolla.armv7hl libnemotransferengine-qt5-2.1.0-1.15.2.jolla.armv7hl libnfcdef-1.0.0-1.1.1.jolla.armv7hl libngf-0.28-1.4.5.jolla.armv7hl libngf-qt5-0.9.0-1.14.1.jolla.armv7hl libngf-qt5-declarative-0.9.0-1.14.1.jolla.armv7hl libngf-qt5-qtfeedback-0.9.0-1.14.1.jolla.armv7hl libnghttp2-1.58.0+git1-1.5.2.jolla.armv7hl libnice-0.1.21+git1-1.6.3.jolla.armv7hl libnl-3.7.0+git1-1.7.2.jolla.armv7hl libogg-1.3.5-1.5.4.jolla.armv7hl libopenconnect5-9.12+git2-1.8.6.jolla.armv7hl libpcap-1.10.3+git2-1.7.1.jolla.armv7hl libphonenumber-8.13.27+git1-1.10.2.jolla.armv7hl libphonenumber-geocoding-8.13.27+git1-1.10.2.jolla.armv7hl libpng-1.6.40+git1-1.5.3.jolla.armv7hl libprofile-qt5-0.35.6-1.8.2.jolla.armv7hl libprolog-1.2.2-1.5.4.jolla.armv7hl libpsl-0.21.5+git1-1.7.1.jolla.armv7hl libpython3_7m1_0-3.7.2+git9-1.6.2.jolla.armv7hl libqapk-0.5.1-1.2.3.jolla.armv7hl libqmfclient1-qt5-4.0.4+git146-1.11.2.jolla.armv7hl libqmfclient1-qt5-cryptoplugins-4.0.4+git146-1.11.2.jolla.armv7hl libqmfmessageserver1-qt5-4.0.4+git146-1.11.2.jolla.armv7hl libqofonoext-1.0.32-1.8.1.jolla.armv7hl libqofonoext-declarative-1.0.32-1.8.1.jolla.armv7hl libqofono-qt5-0.124-1.11.1.jolla.armv7hl libqofono-qt5-declarative-0.124-1.11.1.jolla.armv7hl libqt5sparql-0.3.9-1.9.1.jolla.armv7hl libqt5sparql-tracker-0.2.22+git1-1.3.2.jolla.armv7hl libqt5sparql-tracker-direct-0.3.9-1.9.1.jolla.armv7hl libquillmetadata-qt5-2.0.0-1.5.3.jolla.armv7hl libresource-0.25.2-1.6.1.jolla.armv7hl libresourceqt-qt5-1.32.0-1.9.3.jolla.armv7hl libsailfishapp-1.2.15-1.7.3.jolla.armv7hl libsailfishapp-launcher-1.2.15-1.7.3.jolla.armv7hl libsailfishcrypto-0.2.41-1.13.2.jolla.armv7hl libsailfishcryptoplugin-0.2.41-1.13.2.jolla.armv7hl libsailfishcryptopluginapi-0.2.41-1.13.2.jolla.armv7hl libsailfishkeyprovider-1.0.9-1.5.3.jolla.armv7hl libsailfishkeyprovider-data-jolla-0.1.0-1.2.2.jolla.armv7hl libsailfishsecrets-0.2.41-1.13.2.jolla.armv7hl libsailfishsecretsplugin-0.2.41-1.13.2.jolla.armv7hl libsailfishsecretspluginapi-0.2.41-1.13.2.jolla.armv7hl libsbc-2.0+git1-1.7.2.jolla.armv7hl libseccomp-2.5.2+git1-1.5.4.jolla.armv7hl libselinux-3.1+git3-1.5.8.jolla.armv7hl libselinux-utils-3.1+git3-1.5.8.jolla.armv7hl libsemanage-3.1+git2-1.4.15.jolla.armv7hl libsepol-3.1+git3-1.5.4.jolla.armv7hl libshadowutils-0.0.5-1.6.4.jolla.armv7hl libsigc++20-2.10.4+git1-1.5.4.jolla.armv7hl libsignon-glib-1.15+git1-1.5.5.jolla.armv7hl libsignon-qt5-8.61.0+git1-1.10.1.jolla.armv7hl libsmartcols-2.38.1+git6-1.13.1.jolla.armv7hl libsndfile-1.2.2+git1-1.7.2.jolla.armv7hl libsocialcache-0.2.1-1.7.2.jolla.armv7hl libsocialcache-qml-plugin-0.2.1-1.7.2.jolla.armv7hl libsolv-0.7.20+git2-1.6.4.jolla.armv7hl libsolv-tools-0.7.20+git2-1.6.4.jolla.armv7hl libsoup-2.74.3+git1-1.6.4.jolla.armv7hl libsrtp-2.3.0+git1-1.5.4.jolla.armv7hl libss-1.47.0+git2-1.6.3.jolla.armv7hl libstdc++-10.3.1-1.8.6.jolla.armv7hl libtasn1-4.19.0+git1-1.7.3.jolla.armv7hl libtheora-1.2.0alpha1+git4-1.6.3.jolla.armv7hl libtiff-4.6.0+git1-1.7.4.jolla.armv7hl libtool-ltdl-2.4.7-1.5.3.jolla.armv7hl libtrace-1.1.8+git4-1.6.4.jolla.armv7hl libudisks2-2.9.4+git5-1.10.4.jolla.armv7hl libusb-0.1.7+git2-1.5.4.jolla.armv7hl libusb1-1.0.26+git2-1.8.1.jolla.armv7hl libusb-moded-qt5-1.13-1.9.1.jolla.armv7hl libuser-0.62+git5-1.6.5.jolla.armv7hl libutempter-1.1.5+git3-1.6.12.jolla.armv7hl libuuid-2.38.1+git6-1.13.1.jolla.armv7hl libvorbis-1.3.7-1.4.4.jolla.armv7hl libvpx-1.14.1+git1-1.7.1.jolla.armv7hl libwbxml2-0.11.6+git2-1.6.4.jolla.armv7hl libwebp-1.4.0+git1-1.11.1.jolla.armv7hl libwspcodec-2.2.6-1.5.4.jolla.armv7hl libxcrypt-4.4.23+git2-1.2.4.jolla.armv7hl libxkbcommon-1.3.1+git1-1.6.6.jolla.armv7hl libxml2-2.13.4+git2-1.10.1.jolla.armv7hl libxslt-1.1.42+git1-1.10.1.jolla.armv7hl libzstd-1.5.0+git2-1.2.5.jolla.armv7hl libzypp-17.31.28+git1-1.7.3.jolla.armv7hl lipstick-jolla-home-qt5-1.26.59-1.38.1.jolla.armv7hl lipstick-jolla-home-qt5-components-1.26.59-1.38.1.jolla.armv7hl lipstick-qt5-0.36.41.2-1.22.4.jolla.armv7hl lsof-4.94.0+git2-1.6.9.jolla.armv7hl lvm2-2.02.177+git6-1.7.4.jolla.armv7hl lvm2-libs-2.02.177+git6-1.7.4.jolla.armv7hl lxc-5.0.2+git1-1.7.5.jolla.armv7hl lxc-libs-5.0.2+git1-1.7.5.jolla.armv7hl lz4-libs-1.9.4+git1-1.1.2.jolla.armv7hl lzo-2.10-1.6.3.jolla.armv7hl make-4.2.1-1.5.5.jolla.armv7hl maliit-framework-wayland-2.3.0+git2-1.12.1.jolla.armv7hl maliit-framework-wayland-inputcontext-2.3.0+git2-1.12.1.jolla.armv7hl mapplauncherd-4.2.13-1.11.3.jolla.armv7hl mapplauncherd-booster-browser-0.2.2-1.2.2.jolla.armv7hl mapplauncherd-booster-silica-qt5-0.5.6-1.1.2.jolla.armv7hl mapplauncherd-booster-silica-qt5-media-0.5.6-1.1.2.jolla.armv7hl mapplauncherd-qt5-1.1.22-1.8.4.jolla.armv7hl mce-1.116.0-1.20.1.jolla.armv7hl mce-plugin-libhybris-1.14.5-1.3.1.jolla.armv7hl mce-tools-1.116.0-1.20.1.jolla.armv7hl mkcal-qt5-0.7.26-1.21.1.jolla.armv7hl mlite-qt5-0.4.3-1.11.1.jolla.armv7hl mlsdb-data-eastern-europe-0.2.1-1.11.1.jolla.armv7hl mlsdb-data-northern-europe-0.2.1-1.11.1.jolla.armv7hl mlsdb-data-southern-europe-0.2.1-1.11.1.jolla.armv7hl mlsdb-data-western-europe-0.2.1-1.11.1.jolla.armv7hl mms-engine-1.0.82-1.7.1.jolla.armv7hl mobile-broadband-provider-info-20131125+git89-1.10.1.jolla.noarch mpris-qt5-1.0.6-1.4.6.jolla.armv7hl mpris-qt5-qml-plugin-1.0.6-1.4.6.jolla.armv7hl mtdev-1.1.6+git1-1.6.3.jolla.armv7hl mtp-vendor-configuration-sailfish-0.11.17-1.15.1.jolla.noarch ncurses-base-6.5+git1-1.8.1.jolla.armv7hl ncurses-libs-6.5+git1-1.8.1.jolla.armv7hl nemo-gstreamer1.0-interfaces-0.20211122.0-1.5.4.jolla.armv7hl nemo-password-manager-0.1.5-1.5.5.jolla.armv7hl nemo-qml-plugin-alarms-qt5-0.3.13-1.7.2.jolla.armv7hl nemo-qml-plugin-calendar-qt5-0.7.6-1.17.1.jolla.armv7hl nemo-qml-plugin-calendar-qt5-lightweight-0.7.6-1.17.1.jolla.armv7hl nemo-qml-plugin-calendar-qt5-tools-0.7.6-1.17.1.jolla.armv7hl nemo-qml-plugin-configuration-qt5-0.2.8-1.9.3.jolla.armv7hl nemo-qml-plugin-connectivity-0.2.22-1.15.1.jolla.armv7hl nemo-qml-plugin-contacts-qt5-0.3.30-1.17.2.jolla.armv7hl nemo-qml-plugin-contacts-qt5-tools-0.3.30-1.17.2.jolla.armv7hl nemo-qml-plugin-contentaction-0.4.8-1.10.1.jolla.armv7hl nemo-qml-plugin-contextkit-qt5-2.0.2-1.6.2.jolla.armv7hl nemo-qml-plugin-dbus-qt5-2.1.35-1.10.2.jolla.armv7hl nemo-qml-plugin-devicelock-0.4.3-1.13.1.jolla.armv7hl nemo-qml-plugin-email-qt5-0.6.37-1.16.1.jolla.armv7hl nemo-qml-plugin-filemanager-0.1.45-1.16.1.jolla.armv7hl nemo-qml-plugin-messages-internal-qt5-0.1.31-1.7.4.jolla.armv7hl nemo-qml-plugin-models-qt5-0.2.8-1.10.1.jolla.armv7hl nemo-qml-plugin-notifications-qt5-1.2.32-1.14.2.jolla.armv7hl nemo-qml-plugin-policy-qt5-0.1.5-1.7.2.jolla.armv7hl nemo-qml-plugin-social-qt5-0.1.4-1.7.2.jolla.armv7hl nemo-qml-plugin-systemsettings-0.10.13-1.17.1.jolla.armv7hl nemo-qml-plugin-thumbnailer-qt5-1.0.9-1.7.3.jolla.armv7hl nemo-qml-plugin-time-qt5-0.1.7-1.8.2.jolla.armv7hl nemo-qtmultimedia-plugins-gstvideotexturebackend-0.1.4-1.5.4.jolla.armv7hl nemo-transferengine-qt5-2.1.0-1.15.2.jolla.armv7hl net-tools-1.60-1.5.4.jolla.armv7hl nfcd-1.2.0-1.13.1.jolla.armv7hl nfcd-binder-plugin-1.1.9-1.2.3.jolla.armv7hl nfcd-dbuslog-plugin-1.0.3-1.5.2.jolla.armv7hl nfcd-mce-plugin-1.0.2-1.4.8.jolla.armv7hl ngfd-1.4.6-1.12.1.jolla.armv7hl ngfd-plugin-native-vibrator-1.4.1-1.7.1.jolla.armv7hl ngfd-settings-sailfish-0.11.17-1.15.1.jolla.noarch nspr-4.35.0+git2-1.6.2.jolla.armv7hl nss-3.101+git1-1.8.2.jolla.armv7hl nss-softokn-3.101+git1-1.8.2.jolla.armv7hl nss-softokn-freebl-3.101+git1-1.8.2.jolla.armv7hl nss-sysinit-3.101+git1-1.8.2.jolla.armv7hl nss-util-3.101+git1-1.8.2.jolla.armv7hl obex-capability-0.0.5-1.7.1.jolla.armv7hl obexd-calldata-provider-0.1.5-1.3.3.jolla.armv7hl obexd-contentfilter-helper-0.0.2-1.1.11.jolla.noarch ofono-1.29+git11-1.15.2.jolla.armv7hl ofono-alien-binder-plugin-0.3.3-1.6.1.jolla.armv7hl ofono-ril-binder-plugin-1.2.7-1.4.6.jolla.armv7hl ofono-ril-plugin-1.0.7-1.3.1.jolla.armv7hl ohm-1.3.2-1.6.1.jolla.armv7hl ohm-plugin-accessories-1.10.0-1.9.3.jolla.armv7hl ohm-plugin-core-1.3.2-1.6.1.jolla.armv7hl ohm-plugin-mdm-1.10.0-1.9.3.jolla.armv7hl ohm-plugin-media-1.10.0-1.9.3.jolla.armv7hl ohm-plugin-profile-1.10.0-1.9.3.jolla.armv7hl ohm-plugin-resolver-1.1.18-1.5.5.jolla.armv7hl ohm-plugin-route-1.10.0-1.9.3.jolla.armv7hl ohm-plugin-ruleengine-1.1.14-1.4.4.jolla.armv7hl ohm-plugins-dbus-1.10.0-1.9.3.jolla.armv7hl ohm-plugin-signaling-1.10.0-1.9.3.jolla.armv7hl ohm-plugins-misc-1.10.0-1.9.3.jolla.armv7hl ohm-plugin-telephony-1.10.0-1.9.3.jolla.armv7hl oneshot-0.6.12-1.6.2.jolla.noarch openconnect-9.12+git2-1.8.6.jolla.armv7hl openjpeg-2.5.0+git1-1.7.4.jolla.armv7hl openssh-9.8p1+git1-1.10.2.jolla.armv7hl openssh-clients-9.8p1+git1-1.10.2.jolla.armv7hl openssh-server-9.8p1+git1-1.10.2.jolla.armv7hl openssl-1.1.1v+git1-1.12.1.jolla.armv7hl openssl-libs-1.1.1v+git1-1.12.1.jolla.armv7hl openvpn-2.6.12+git1-1.12.1.jolla.armv7hl opus-1.5.1+git1-1.6.2.jolla.armv7hl orc-0.4.39+git1-1.9.1.jolla.armv7hl os-update-service-1.4.0-1.16.1.jolla.armv7hl p11-kit-0.23.22+git1-1.6.6.jolla.armv7hl p11-kit-nss-ckbi-0.23.22+git1-1.6.6.jolla.armv7hl p11-kit-trust-0.23.22+git1-1.6.6.jolla.armv7hl PackageKit-1.2.5+git3.2-1.8.1.jolla.armv7hl PackageKit-glib-1.2.5+git3.2-1.8.1.jolla.armv7hl PackageKit-Qt5-1.0.2+git1-1.5.5.jolla.armv7hl PackageKit-zypp-1.2.5+git3.2-1.8.1.jolla.armv7hl pacrunner-0.18+git2-1.7.3.jolla.armv7hl pam-1.6.1+git1-1.8.1.jolla.armv7hl pango-1.51.1+git1-1.7.2.jolla.armv7hl passwd-0.80+git2-1.6.3.jolla.armv7hl patch-2.7.6+git2-1.6.3.jolla.armv7hl patterns-sailfish-api-3-3.0.2-1.5.2.jolla.noarch patterns-sailfish-app-blacklist-1.1.32-1.14.1.jolla.noarch patterns-sailfish-applications-1.1.32-1.14.1.jolla.noarch patterns-sailfish-cellular-apps-1.1.32-1.14.1.jolla.noarch patterns-sailfish-consumer-generic-1.1.32-1.14.1.jolla.noarch patterns-sailfish-core-1.1.32-1.14.1.jolla.noarch patterns-sailfish-core-device-1.1.32-1.14.1.jolla.noarch patterns-sailfish-customer-content-default-1.1.32-1.14.1.jolla.noarch patterns-sailfish-device-adaptation-kirin-0.0.78-1.12.1.jolla.armv7hl patterns-sailfish-device-configuration-common-i4113-0.0.78-1.12.1.jolla.armv7hl patterns-sailfish-device-configuration-i4113-0.0.78-1.12.1.jolla.armv7hl patterns-sailfish-mw-1.1.32-1.14.1.jolla.noarch patterns-sailfish-ui-1.1.32-1.14.1.jolla.noarch patterns-sailfish-xt9-0.1.1-1.3.1.jolla.armv7hl pcre2-10.42+git1-1.1.2.jolla.armv7hl pcre-8.45+git2-1.7.4.jolla.armv7hl perl-5.16.3-1.7.6.jolla.armv7hl perl-Filter-1.40-1.7.6.jolla.armv7hl perl-libs-5.16.3-1.7.6.jolla.armv7hl perl-macros-5.16.3-1.7.6.jolla.armv7hl perl-Module-Pluggable-4.00-1.7.6.jolla.noarch perl-parent-0.225-1.7.6.jolla.noarch perl-Pod-Escapes-1.04-1.7.6.jolla.noarch perl-Pod-Parser-1.51-1.7.6.jolla.noarch perl-Pod-Perldoc-3.17.00-1.7.6.jolla.noarch perl-Pod-Simple-3.20-1.7.6.jolla.noarch perl-Scalar-List-Utils-1.25-1.7.6.jolla.armv7hl perl-Socket-2.001-1.7.6.jolla.armv7hl perl-threads-1.86-1.7.6.jolla.armv7hl perl-threads-shared-1.40-1.7.6.jolla.armv7hl pixman-0.42.2+git1-1.7.3.jolla.armv7hl pkgconfig-0.29.2+git1-1.5.4.jolla.armv7hl policycoreutils-3.1+git3-1.5.7.jolla.armv7hl policy-settings-common-0.13.0-1.9.2.jolla.armv7hl polkit-125+git1-1.8.1.jolla.armv7hl poppler-24.08.0+git2-1.10.1.jolla.armv7hl poppler-glib-24.08.0+git2-1.10.1.jolla.armv7hl poppler-qt5-24.08.0+git2-1.10.1.jolla.armv7hl popt-1.18+git1-1.4.4.jolla.armv7hl ppp-2.4.9+git2-1.6.4.jolla.armv7hl ppp-libs-2.4.9+git2-1.6.4.jolla.armv7hl pptp-1.10+git1-1.6.3.jolla.armv7hl profiled-1.0.14-1.6.2.jolla.armv7hl prolog-resourcepolicy-extensions-1.1.14-1.4.4.jolla.armv7hl protobuf-lite-25.1+git1-1.8.3.jolla.armv7hl provisioning-service-0.1.8-1.7.6.jolla.armv7hl pth-2.0.7-1.6.3.jolla.armv7hl pulseaudio-14.2+git9-1.10.2.jolla.armv7hl pulseaudio-module-keepalive-1.1.0-1.6.4.jolla.armv7hl pulseaudio-modules-droid-hidl-1.5.0-1.3.4.jolla.armv7hl pulseaudio-modules-droid-jb2q-14.2.102-1.5.1.jolla.armv7hl pulseaudio-modules-droid-jb2q-common-14.2.102-1.5.1.jolla.armv7hl pulseaudio-modules-nemo-common-14.2.31-1.5.3.jolla.armv7hl pulseaudio-modules-nemo-mainvolume-14.2.31-1.5.3.jolla.armv7hl pulseaudio-modules-nemo-parameters-14.2.31-1.5.3.jolla.armv7hl pulseaudio-modules-nemo-stream-restore-14.2.31-1.5.3.jolla.armv7hl pulseaudio-policy-enforcement-14.2.47-1.7.3.jolla.armv7hl pyotherside-qml-plugin-python3-qt5-1.5.9+git4-1.5.4.jolla.armv7hl python-2.7.17+git8-1.1.1.jolla.armv7hl python3-base-3.8.18+git1-1.9.5.jolla.armv7hl python3-imaging-9.0.0+git2-1.5.4.jolla.armv7hl python3-IPy-0.83+git4-1.4.3.jolla.noarch python3-libs-3.8.18+git1-1.9.5.jolla.armv7hl python3-libselinux-3.1+git3-1.5.8.jolla.armv7hl python3-libsemanage-3.1+git2-1.4.15.jolla.armv7hl python3-sqlite-3.8.18+git1-1.8.2.jolla.armv7hl python-libs-2.7.17+git8-1.1.1.jolla.armv7hl qmf-notifications-plugin-0.2.15-1.8.1.jolla.armv7hl qmf-notifications-plugin-all-translations-pack-0.8.2-1.7.2.jolla.noarch qmf-oauth2-plugin-0.1.0-1.1.18.jolla.armv7hl qmllive-1.0.0+git8-1.4.3.jolla.armv7hl qmllive-sailfish-0.3.2-1.5.7.jolla.armv7hl qr-filter-qml-plugin-1.1.2-1.7.1.jolla.armv7hl qt5-plugin-bearer-connman-5.6.3+git55-1.18.1.jolla.armv7hl qt5-plugin-generic-evdev-5.6.3+git55-1.18.1.jolla.armv7hl qt5-plugin-geoservices-here-5.4.2+git3-1.6.3.jolla.armv7hl qt5-plugin-imageformat-gif-5.6.3+git55-1.18.1.jolla.armv7hl qt5-plugin-imageformat-ico-5.6.3+git55-1.18.1.jolla.armv7hl qt5-plugin-imageformat-jpeg-5.6.3+git55-1.18.1.jolla.armv7hl qt5-plugin-platform-minimal-5.6.3+git55-1.18.1.jolla.armv7hl qt5-plugin-position-geoclue-5.4.2+git3-1.6.2.jolla.armv7hl qt5-plugin-sqldriver-sqlcipher-0.2.41-1.13.2.jolla.armv7hl qt5-plugin-sqldriver-sqlite-5.6.3+git55-1.18.1.jolla.armv7hl qt5-qpa-hwcomposer-plugin-5.6.2.24-1.4.2.jolla.armv7hl qt5-qtconcurrent-5.6.3+git55-1.18.1.jolla.armv7hl qt5-qtcore-5.6.3+git55-1.18.1.jolla.armv7hl qt5-qtdbus-5.6.3+git55-1.18.1.jolla.armv7hl qt5-qtdeclarative-5.6.3+git25-1.8.2.jolla.armv7hl qt5-qtdeclarative-import-folderlistmodel-5.6.3+git25-1.8.2.jolla.armv7hl qt5-qtdeclarative-import-localstorageplugin-5.6.3+git25-1.8.2.jolla.armv7hl qt5-qtdeclarative-import-location-5.4.2+git3-1.6.3.jolla.armv7hl qt5-qtdeclarative-import-models2-5.6.3+git25-1.8.2.jolla.armv7hl qt5-qtdeclarative-import-multimedia-5.6.2+git31-1.11.5.jolla.armv7hl qt5-qtdeclarative-import-particles2-5.6.3+git25-1.8.2.jolla.armv7hl qt5-qtdeclarative-import-positioning-5.4.2+git3-1.6.3.jolla.armv7hl qt5-qtdeclarative-import-qtquick2plugin-5.6.3+git25-1.8.2.jolla.armv7hl qt5-qtdeclarative-import-qttest-5.6.3+git25-1.8.2.jolla.armv7hl qt5-qtdeclarative-import-sensors-5.6.3+git4-1.6.1.jolla.armv7hl qt5-qtdeclarative-import-window2-5.6.3+git25-1.8.2.jolla.armv7hl qt5-qtdeclarative-import-xmllistmodel-5.6.3+git25-1.8.2.jolla.armv7hl qt5-qtdeclarative-plugin-qmlinspector-5.6.3+git25-1.8.2.jolla.armv7hl qt5-qtdeclarative-qtquick-5.6.3+git25-1.8.2.jolla.armv7hl qt5-qtdeclarative-qtquickparticles-5.6.3+git25-1.8.2.jolla.armv7hl qt5-qtdeclarative-qtquicktest-5.6.3+git25-1.8.2.jolla.armv7hl qt5-qtdocgallery-5.3.0+git6-1.9.1.jolla.armv7hl qt5-qtfeedback-5.2.0+git7-1.4.8.jolla.armv7hl qt5-qtgraphicaleffects-5.6.2+git4-1.5.3.jolla.armv7hl qt5-qtgui-5.6.3+git55-1.18.1.jolla.armv7hl qt5-qtimageformats-plugin-tiff-5.6.3+git4-1.5.3.jolla.armv7hl qt5-qtimageformats-plugin-webp-5.6.3+git4-1.5.3.jolla.armv7hl qt5-qtlocation-5.4.2+git3-1.6.3.jolla.armv7hl qt5-qtmultimedia-5.6.2+git31-1.11.5.jolla.armv7hl qt5-qtmultimedia-gsttools-5.6.2+git31-1.11.5.jolla.armv7hl qt5-qtmultimedia-plugin-audio-pulseaudio-5.6.2+git31-1.11.5.jolla.armv7hl qt5-qtmultimedia-plugin-mediaservice-gstcamerabin-5.6.2+git31-1.11.5.jolla.armv7hl qt5-qtmultimedia-plugin-mediaservice-gstmediacapture-5.6.2+git31-1.11.5.jolla.armv7hl qt5-qtmultimedia-plugin-mediaservice-gstmediaplayer-5.6.2+git31-1.11.5.jolla.armv7hl qt5-qtmultimedia-plugin-resourcepolicy-resourceqt-5.6.2+git31-1.11.5.jolla.armv7hl qt5-qtnetwork-5.6.3+git55-1.18.1.jolla.armv7hl qt5-qtopengl-5.6.3+git55-1.18.1.jolla.armv7hl qt5-qtpim-contacts-5.6.0+git15-1.5.5.jolla.armv7hl qt5-qtpim-versit-5.6.0+git15-1.5.5.jolla.armv7hl qt5-qtpositioning-5.4.2+git3-1.6.3.jolla.armv7hl qt5-qtprintsupport-5.6.3+git55-1.18.1.jolla.armv7hl qt5-qtquickcontrols-layouts-5.2.1+git4-1.4.5.jolla.armv7hl qt5-qtsensors-5.6.3+git4-1.6.1.jolla.armv7hl qt5-qtsensors-plugin-sensorfw-5.6.3+git4-1.6.1.jolla.armv7hl qt5-qtsql-5.6.3+git55-1.18.1.jolla.armv7hl qt5-qtsvg-5.6.2+git3-1.4.8.jolla.armv7hl qt5-qtsvg-plugin-imageformat-svg-5.6.2+git3-1.4.8.jolla.armv7hl qt5-qttest-5.6.3+git55-1.18.1.jolla.armv7hl qt5-qtwayland-wayland_egl-5.6.3+git4-1.9.2.jolla.armv7hl qt5-qtwidgets-5.6.3+git55-1.18.1.jolla.armv7hl qt5-qtxml-5.6.3+git55-1.18.1.jolla.armv7hl qt5-qtxmlpatterns-5.6.3+git4-1.6.3.jolla.armv7hl qtcontacts-sqlite-qt5-0.3.20-1.8.1.jolla.armv7hl qtmozembed-qt5-1.55.4-1.27.1.jolla.armv7hl qtscenegraph-adaptation-0.8.0-1.3.3.jolla.armv7hl quazip-1.2+git2-1.5.6.jolla.armv7hl quota-minimal-4.05+git3-1.6.2.jolla.armv7hl quota-nld-4.05+git3-1.6.2.jolla.armv7hl readline-8.1+git1-1.6.3.jolla.armv7hl rootfiles-8.1+git3-1.5.3.jolla.noarch rpm-4.16.1.3+git17-1.12.1.jolla.armv7hl rpm-build-4.16.1.3+git17-1.12.1.jolla.armv7hl rsync-3.2.7+git1-1.6.3.jolla.armv7hl sailfish-access-control-0.0.8-1.7.1.jolla.armv7hl sailfish-access-control-qml-plugin-0.0.8-1.7.1.jolla.armv7hl sailfish-account-nextcloud-1.0.12-1.13.1.jolla.armv7hl sailfish-account-nextcloud-features-all-1.0.12-1.13.1.jolla.armv7hl sailfish-aml-1.0.5-1.2.1.jolla.armv7hl sailfish-aml-data-1.0.5-1.2.1.jolla.noarch sailfish-archive-0.1.2-1.1.13.jolla.armv7hl sailfish-audiorecorder-0.1.10-1.5.1.jolla.armv7hl sailfish-audiorecorder-l10n-all-translations-1.25.2-1.9.1.jolla.noarch sailfish-browser-2.3.3-1.19.3.jolla.armv7hl sailfish-browser-settings-2.3.3-1.19.3.jolla.armv7hl sailfish-ca-0.2-1.2.2.jolla.noarch sailfish-components-accounts-qt5-0.4.6-1.2.1.jolla.armv7hl sailfish-components-accounts-qt5-tools-0.4.6-1.2.1.jolla.armv7hl sailfish-components-bluetooth-qt5-0.2.31-1.9.2.jolla.armv7hl sailfish-components-calendar-qt5-1.1.17-1.13.1.jolla.armv7hl sailfish-components-contacts-qt5-0.4.56-1.15.1.jolla.armv7hl sailfish-components-email-qt5-0.1.5-1.3.1.jolla.armv7hl sailfish-components-filemanager-0.2.27-1.1.2.jolla.armv7hl sailfish-components-gallery-qt5-1.2.23-1.4.2.jolla.armv7hl sailfish-components-media-qt5-0.9.17-1.7.1.jolla.armv7hl sailfish-components-pickers-qt5-1.0.29-1.9.2.jolla.armv7hl sailfish-components-secrets-ui-0.1.9-1.3.4.jolla.armv7hl sailfish-components-store-0.0.14-1.3.1.jolla.armv7hl sailfish-components-telephony-qt5-0.2.8-1.7.1.jolla.armv7hl sailfish-components-textlinking-0.1.6-1.2.2.jolla.armv7hl sailfish-components-timezone-qt5-0.2.5-1.5.2.jolla.armv7hl sailfish-components-weather-qt5-1.2.0-1.10.2.jolla.armv7hl sailfish-components-weather-qt5-all-translations-pack-0.8.1-1.4.1.jolla.noarch sailfish-components-webview-qt5-1.6.3-1.18.2.jolla.armv7hl sailfish-components-webview-qt5-pickers-1.6.3-1.18.2.jolla.armv7hl sailfish-components-webview-qt5-popups-1.6.3-1.18.2.jolla.armv7hl sailfish-connman-plugin-suspend-0.0.10-1.2.3.jolla.armv7hl sailfish-content-ambiences-default-1.0.14-1.5.1.jolla.noarch sailfish-content-ambiences-default-about-1.0.14-1.5.1.jolla.noarch sailfish-content-ambiences-default-airy-1.0.14-1.5.1.jolla.noarch sailfish-content-ambiences-default-community-1.0.14-1.5.1.jolla.noarch sailfish-content-ambiences-default-default-ambience-1.0.14-1.5.1.jolla.noarch sailfish-content-ambiences-default-favorites-1.0.14-1.5.1.jolla.noarch sailfish-content-ambiences-default-flow-1.0.14-1.5.1.jolla.noarch sailfish-content-ambiences-default-glacial-1.0.14-1.5.1.jolla.noarch sailfish-content-ambiences-default-origami-1.0.14-1.5.1.jolla.noarch sailfish-content-ambiences-default-party-1.0.14-1.5.1.jolla.noarch sailfish-content-ambiences-default-rolling-1.0.14-1.5.1.jolla.noarch sailfish-content-ambiences-default-sailfish3-1.0.14-1.5.1.jolla.noarch sailfish-content-ambiences-default-sailing-1.0.14-1.5.1.jolla.noarch sailfish-content-ambiences-default-salamander-1.0.14-1.5.1.jolla.noarch sailfish-content-ambiences-default-silent-1.0.14-1.5.1.jolla.noarch sailfish-content-ambiences-default-work-1.0.14-1.5.1.jolla.noarch sailfish-content-apps-default-configs-0.11.17-1.15.1.jolla.noarch sailfish-content-browser-default-0.1.7-1.3.1.jolla.noarch sailfish-content-gallery-configuration-2k-0.31.5-1.5.1.jolla.noarch sailfish-content-gallery-default-0.32.0-1.1.9.jolla.noarch sailfish-content-graphics-closed-0.7.0-1.3.1.jolla.noarch sailfish-content-graphics-closed-z1.75-0.7.0-1.3.1.jolla.noarch sailfish-content-graphics-default-1.4.2-1.8.2.jolla.noarch sailfish-content-graphics-default-z1.75-1.4.2-1.8.2.jolla.noarch sailfish-content-profiled-settings-default-0.16.2-1.2.1.jolla.noarch sailfish-content-tones-default-0.16.2-1.2.1.jolla.noarch sailfish-content-vpn-default-0.0.1-1.2.9.jolla.noarch sailfish-device-encryption-0.11.13-1.14.1.jolla.armv7hl sailfish-device-encryption-service-0.11.13-1.14.1.jolla.armv7hl sailfish-device-encryption-settings-0.11.13-1.14.1.jolla.armv7hl sailfish-device-encryption-unlock-ui-0.11.13-1.14.1.jolla.armv7hl sailfish-device-encryption-unlock-ui-resources-z1.75-0.11.13-1.14.1.jolla.armv7hl sailfish-devicelock-fpd-1.2.0-1.4.2.jolla.armv7hl sailfish-devicelock-libs-1.2.0-1.4.2.jolla.armv7hl sailfish-filemanager-0.1.4-1.4.3.jolla.armv7hl sailfish-filemanager-l10n-all-translations-1.26.1-1.6.1.jolla.noarch sailfish-fonts-0.3.1-1.1.1.jolla.noarch sailfish-fpd-1.5.6-1.5.1.jolla.armv7hl sailfish-fpd-slave-binder-1.5.6-1.3.1.jolla.armv7hl sailfish-homescreen-services-0.1.10-1.7.2.jolla.armv7hl sailfish-homescreen-services-libs-0.1.10-1.7.2.jolla.armv7hl sailfish-installationhandler-1.0.14-1.10.1.jolla.armv7hl sailfish-locale-1.0.2-1.2.4.jolla.armv7hl sailfish-maps-all-translations-pack-0.8.2-1.5.1.jolla.noarch sailfish-minui-resources-z1.75-0.1.8-1.9.1.jolla.armv7hl sailfish-office-1.6.10-1.10.1.jolla.armv7hl sailfish-office-all-translations-pack-0.8.2-1.5.3.jolla.noarch sailfish-policy-0.4.20-1.2.2.jolla.armv7hl sailfishsecretsdaemon-0.2.41-1.13.2.jolla.armv7hl sailfishsecretsdaemon-cryptoplugins-default-0.2.41-1.13.2.jolla.armv7hl sailfishsecretsdaemon-cryptoplugins-gnupg-0.2.41-1.13.2.jolla.armv7hl sailfishsecretsdaemon-secretsplugin-common-0.2.41-1.13.2.jolla.armv7hl sailfishsecretsdaemon-secretsplugins-default-0.2.41-1.13.2.jolla.armv7hl sailfish-secrets-ui-0.1.9-1.3.4.jolla.armv7hl sailfish-settings-networking-1.0.52-1.28.1.jolla.armv7hl sailfish-settings-networking-vpn-1.0.52-1.28.1.jolla.armv7hl sailfish-setup-0.3.4-1.6.2.jolla.noarch sailfishshare-components-1.1.11-1.7.1.jolla.armv7hl sailfish-silica-background-qt5-0.9.16-1.2.1.jolla.armv7hl sailfishsilica-qt5-1.2.143-1.34.1.jolla.armv7hl sailfish-tutorial-default-0.2.34-1.8.1.jolla.armv7hl sailfish-tutorial-default-data-0.2.34-1.8.1.jolla.noarch sailfish-upgrade-ui-0.1.18-1.4.1.jolla.armv7hl sailfish-upgrade-ui-resources-logo-z1.75-0.1.18-1.4.1.jolla.armv7hl sailfish-upgrade-ui-resources-z1.75-0.1.18-1.4.1.jolla.armv7hl sailfish-utilities-0.1.22-1.9.3.jolla.armv7hl sailfish-utilities-all-translations-pack-0.8.2-1.5.3.jolla.noarch sailfish-version-5.0.0-1.11.55.jolla.noarch sailfish-version-variant-5.0.0-1.11.55.jolla.noarch sailfish-wayland-libs-0.1.4-1.4.3.jolla.armv7hl sailfish-weather-1.2.0-1.10.2.jolla.armv7hl sailfish-weather-all-translations-pack-0.8.2-1.5.2.jolla.noarch sailjail-1.1.26-1.18.2.jolla.armv7hl sailjail-daemon-1.1.26-1.18.2.jolla.armv7hl sailjail-permissions-1.1.15-1.35.1.jolla.armv7hl screen-4.9.1+git1-1.9.2.jolla.armv7hl sdk-deploy-rpm-1.7-1.4.3.jolla.armv7hl SDL2-2.30.0+git2-1.9.3.jolla.armv7hl SDL2_gfx-1.0.4+git5-1.7.1.jolla.armv7hl SDL2_image-2.8.2+git1-1.8.2.jolla.armv7hl SDL2_mixer-2.8.0+git1-1.8.2.jolla.armv7hl SDL2_net-2.2.0+git1-1.7.4.jolla.armv7hl SDL2_ttf-2.22.0+git1-1.8.2.jolla.armv7hl sensorfw-qt5-0.15.0-1.14.1.jolla.armv7hl sensorfw-qt5-configs-0.15.0-1.14.1.jolla.noarch setup-2.13.6+git6-1.10.3.jolla.noarch shadow-utils-4.16+git1-1.8.1.jolla.armv7hl shared-mime-info-2.4+git2-1.9.2.jolla.armv7hl signon-plugin-oauth2-qt5-0.25+git5-1.7.3.jolla.armv7hl signon-qt5-8.61.0+git1-1.10.1.jolla.armv7hl simkit-0.4.32-1.5.1.jolla.armv7hl sound-theme-freedesktop-0.8+git1-1.6.2.jolla.noarch speex-1.2.1+git2-1.7.3.jolla.armv7hl speexdsp-1.2.1+git1-1.6.2.jolla.armv7hl sqlcipher-4.5.0+git2-1.5.7.jolla.armv7hl sqlite-3.46.1+git1-1.9.2.jolla.armv7hl sqlite-libs-3.46.1+git1-1.9.2.jolla.armv7hl ssu-1.6.0-1.13.1.jolla.armv7hl ssu-declarative-1.6.0-1.13.1.jolla.armv7hl ssu-sysinfo-1.5.0-1.9.1.jolla.armv7hl ssu-vendor-data-jolla-1.1.3-1.16.1.jolla.noarch store-client-1.4.0-1.16.1.jolla.armv7hl store-client-common-1.4.0-1.16.1.jolla.armv7hl sudo-1.9.15p4+git1-1.4.2.jolla.armv7hl swi-prolog-7.6.4+git3-1.7.3.jolla.armv7hl swi-prolog-library-core-7.6.4+git3-1.7.3.jolla.armv7hl swi-prolog-runtime-lib-7.6.4+git3-1.7.3.jolla.armv7hl systemd-238+git23-1.15.1.jolla.armv7hl systemd-config-sailfish-0.11.17-1.15.1.jolla.noarch systemd-libs-238+git23-1.15.1.jolla.armv7hl systemd-user-session-targets-0.0.2-1.6.3.jolla.noarch taglib-1.12+git2-1.5.6.jolla.armv7hl tayga-0.9.2+git3-1.1.2.jolla.armv7hl tcpdump-4.99.4+git1-1.5.1.jolla.armv7hl telepathy-accounts-signon-0.1.29-1.7.2.jolla.armv7hl telepathy-farstream-0.6.2+git1-1.4.5.jolla.armv7hl telepathy-gabble-0.18.4+git6-1.8.3.jolla.armv7hl telepathy-glib-0.24.1+git1-1.4.5.jolla.armv7hl telepathy-mission-control-5.16.6+git7-1.6.4.jolla.armv7hl telepathy-qt5-0.9.8+git5-1.9.6.jolla.armv7hl telepathy-qt5-farstream-0.9.8+git5-1.9.6.jolla.armv7hl telepathy-ring-2.5.13-1.6.14.jolla.armv7hl thumbnaild-0.1.2-1.8.2.jolla.armv7hl timed-qt5-3.6.21-1.13.1.jolla.armv7hl timed-qt5-tools-3.6.21-1.13.1.jolla.armv7hl totem-pl-parser-3.26.6+git3-1.6.5.jolla.armv7hl tracker-3.3.3+git2-1.7.4.jolla.armv7hl tracker-miners-3.3.3+git1-1.9.1.jolla.armv7hl transferengine-plugin-bluetooth-0.4.5-1.12.1.jolla.armv7hl transferengine-plugin-core-0.4.5-1.12.1.jolla.armv7hl transferengine-plugin-nextcloud-1.0.12-1.13.1.jolla.armv7hl transferengine-plugins-0.4.5-1.12.1.jolla.armv7hl tzdata-2024a+git1-1.6.1.jolla.noarch tzdata-timed-2024a+git1-1.8.2.jolla.noarch udisks2-2.9.4+git5-1.10.4.jolla.armv7hl unzip-6.0-1.5.13.jolla.armv7hl usb-moded-0.86.0+mer67-1.14.1.jolla.armv7hl user-managerd-0.8.9-1.9.2.jolla.armv7hl util-linux-2.38.1+git6-1.13.1.jolla.armv7hl vault-1.0.6-1.6.1.jolla.armv7hl vim-common-9.1.0727+git1-1.9.1.jolla.armv7hl vim-data-9.1.0727+git1-1.9.1.jolla.noarch vim-enhanced-9.1.0727+git1-1.9.1.jolla.armv7hl vim-filesystem-9.1.0727+git1-1.9.1.jolla.armv7hl vim-minimal-9.1.0727+git1-1.9.1.jolla.armv7hl voicecall-qt5-0.8.9-1.15.1.jolla.armv7hl voicecall-qt5-plugin-telepathy-0.8.9-1.15.1.jolla.armv7hl voicecall-qt5-plugin-voicecall-filter-0.8.9-1.15.1.jolla.armv7hl voicecall-ui-jolla-1.16.1-1.19.1.jolla.armv7hl volume_key-libs-0.3.9+git3-1.6.4.jolla.armv7hl vpnc-0.5.3.r526+git3-1.6.2.jolla.armv7hl wayland-1.22.0+git1-1.7.1.jolla.armv7hl wayland-egl-1.22.0+git1-1.7.1.jolla.armv7hl wireless-regdb-2020.04.29+git5-1.6.2.jolla.noarch wpa_supplicant-2.11+git4-1.14.1.jolla.armv7hl xdg-dbus-proxy-0.1.2+git4-1.6.4.jolla.armv7hl xdg-user-dirs-0.17+git2-1.6.3.jolla.armv7hl xdg-utils-1.2.1+git1-1.9.1.jolla.noarch xkeyboard-config-2.37+git2-1.7.1.jolla.noarch xl2tpd-1.3.16+git1-1.6.3.jolla.armv7hl xulrunner-qt5-91.13.1+git2-1.24.1.jolla.armv7hl xz-5.6.2+git1-1.5.1.jolla.armv7hl xz-libs-5.6.2+git1-1.5.1.jolla.armv7hl xz-lzma-compat-5.6.2+git1-1.5.1.jolla.armv7hl yaml-cpp-0.6.3+git1-1.5.5.jolla.armv7hl zlib-1.3.1+git1-1.9.1.jolla.armv7hl zstd-1.5.0+git2-1.2.5.jolla.armv7hl zxing-cpp-2.0.0+git1-1.8.3.jolla.armv7hl zypper-1.14.68+git1-1.7.2.jolla.armv7hl ```My Xperia 10 lll says Up to date (4.60.15). Tried with wlan and mobile data. Internet is working. I also can’t see update in event view. I will try tomorrow again…
And you are sure that the early access is enabled in your jolla account profile?
Yes I can see my account active.
The download graphic may appear stuck since some packages are hundreds of megabytes (around 400MB if I remember correctly) and their downloading just takes a long time. The graphic updates only when a package has been fully downloaded.
Update went well. Microg latest version works now.
Sadly there is no internet in AppSupport with mobile connection.
Account active
or
Account active + early access subscribed?
You need to enable early access in your account settings, then you can update immediately
Update went smoothly on XA2 and 10 V but now the browser refuses to pick up saved passwords on both devices.
When started from the console after re-entering the password and checking the save button, the browser logs a message JavaScript error: resource://gre/modules/LoginHelper.jsm, line 1716: NS_ERROR_FAILURE: This login already exists.. Furthermore the password doesn’t seem to be sent in that case, since I get an HTTP 401 error. Without checking the save button, login works.
Curious about these Instructions ![]()
