Have you put your consent to the new privacy statement in the account of yours too?
So, not much point updating then. No fixes for mediaplayer, just a few added gimmicks instead. Disappointing.
Thank you, I will try that.
Update failed on my XA2
maybe 500mb on the root partition still wasn’t enough?
The update page in settings no longer loads and ssu doesn’t work due to missing libpsl.so. Is there anything I can do?
Sorry not sure how to help, it’s finnicky still it seems to start, what steps I did: turn wlan off, toggle mobile data off/on, airplane mode on, wait 15sec, airplane mode off, turn data to prefer 3g, back to 4g, switch sim from sim2 to sim1 (physically with phone on, but then in settings), again data/airplane toggles, restart android support and then it started working and has been rock solid since, switching between mobile/wifi now without problems (have not rebooted yet, we’ll see)
Mobile internet in AppSupport does not work for me. Tried toggling and reboot. What does the Android setting in section “Network & Internet” show for you?
For me it says “no sim card”.
Does show name of my provider
[C2]
First attempt to download got stuck “waiting for network”.
Rebooted, second attempt got stuck @~95% downloading with no progress in 30 minutes.
Rebooted, phone now said “ready to install”, so proceeded doing just that. That went well, completely w/o hickups. Phone now reports running 5.0.0.55.
Holding off the update on my main device until I’ve used it on the C2 for a while.
The new browser seems to not allow, to type keywords for search into the address field?
Thanks, update went smoothly on X10III.
Nice! Yle.fi website works now well with the ESR91.
Rotating home screen is nicer than I thought.
Hopefully X10III will get AAS 13 also at some point
i flashed back my xperia 10v to android 13…
how can i flash directly tampella image to my 10v…
I’ve updated my backup device (XA2) and it all went well - no issues @all!
The device seems a bit snappier and the new rotation thing I do like.
Many 10x to Jolla!
Напред и нагоре - weiter so!
you can try to update manually via command line. Oh, SSU does not work either so maybe reflashing is the only option?
Updating of 10 V to SFOS 5.0.0.55 went fine. Nice To be back with / In Tampella, too.
One strange thing:
Chum does not show any installed apps. Perhaps someone else with 10 V has noticed this, too.
Looking forward to progress in the development of the commercial version.
Not strange, completely normal and expected after a new release.
Use the settings of the Chum GUI to select the ‘4.6’ version until Chum receives the 5.0 repo config.
The Android apps on my C2 do not complain about missing Play Services anymore and just work - very nice, thank you!
The improved UI updater will not let me apply the update because of low battery.
Which is fine and cool.
But my battery is at 46%, maybe that’s a bit conservative?
Update went fine on C2, but 2 things makes me wonder:
Browser: creating a new tab with a search fails, no matter what search engine is selected. Exapmle: tiping “test” in the adress-bar tries to open “test.com”
Although the C2 lacks a fingerprint-sensor in the settings (German “Hilfsprogramme”) there is the option to restart the fingerprint-sensor
thanks jolla team
Update went fine on Xperia V. Xperia II yet to be tested. On Xperia V the overall experience after update improved. Phone seems to work smoother/faster. Love the new Five Two Ambience. Browser update is so BRILLIANT!!! 1000 thx to @flypig
Also love landscape home.
Is that setting for text size also new? Or did I only miss that on a previous update
Now I only need the license for App support and Camera/Fingerprint. Hopefully it’s just around the corner…
Indeed, it treats “foo bar” just as an (invalid) URL
