Do you have a solution for this unsuspected behaviour?
@davodego a bit off topic bit we should talk / discuss about AppSupport and forget aliendalvik as in practise that no longer exists.
It was already reported that the fix will come in one of the release candidates.
Some folks @ FOSDEM BoF were asking about what’s next after 5.0, please check from the FOSDEM news Sailfish Community News, 6th February - FOSDEM '25
Any news about mirroring discord discussion from Mind2 channel to the public? There were some concerns about privacy about bridging it with other protocols, but having at least a publicly viewable log of what is happening in that walled garden shouldn’t cause any? (if it’s compatible with discord tos even? Not sure EDIT: but if ‘what goes on discord stays on discord’ is their policy that would just be an even harder signal to change channels)
Oh, i wasn’t aware of this. It’s a long thread
Good to know.
For what it’s worth, my DC72 updated to 5.0.0.55 over the air after installing a tweaked DC54 4.6 image on it.
Do we have any update on that - Tampella 5.0.0.58 ?
Seems to be fixed with Whisperfish 0.6.0 beta 34
Is it possible to install Wireguard VPN? (best with config file… OpenVPN works if you disable IPv6… I would like to test Wireguard
In my case Xperia 10 iii it seems a bit faster than before. One issue I found is that some Android apps won’t open in full screen but rather stay in multitasking form . Has anyone else experienced this ?
Yes i have that also with a few apps.
Can you also confirm that with the browser you no longer able to search something from the url bar ? You can only write a website
No it still works when i type something into the bar it opens google search en look for it. on my Xperia 10 III
On Jolla C2 browser opens search normally. On Xperia 10 II feeding words tries to open website like you describe. What type of phone do you have?
I have xperia 10 iii. I m pretty sure that on the previous version it worked fine but not on sailfishos 5
Already reported that the fix will come in one of the future release candidate.
Just a question regarding the early access subscription. Will i also receive the release for all other users (stable) or only the early releases?
Yes. EA is for the brave who are a bit impatient
to get the shiniest.
Yes, I had the same problem and following your post I solved it. I had to give the shell command
pkcon install lipstick-jolla-home-qt5-weather-widget-settings
and to force Chum to select the 4.6.0.15 packages (It doesn’t load 5.0.0.55 yet), but after that (and a reboot) everything worked perfectly!
