Thx! Also good to know the reason.
Maybe you should post this problem in the Whisperfish thread - usually you get fast help and a fix there
Easypark (Android App) works again in SFOS 5.0.0.55.
Easypark could not send or reseive confirmation SMS for setup the account. This is now solved.
Xperia 10III O2 Germany.
What does this mean? You got another update? You found a way to solve the problem? How?
Note that some apps are even pickier than that; not only they require having an Android browser as default, but it has to be Chromium-based too. So if login doesn’t work with Firefox, try Vivaldi for example.
I am experiencing a huge power drain with the phone running hot above the 40C. Is there some monitoring app to find the culprit?
I’ve reported the issue : Avatars contacts from Nextcloud can't syncing
tnx, I reinstalled the whole phone… and it did fix the problem
The app has not worked for me for over a year. It wasn’t important enough for me to open a post for it. I tried again and again with every update of the easypark app, without success. After the sfos update to 5.0.0.55 it now works again. I put this down to changes in AlienDalvik. Maybe solved is not the right term. I just wanted to let the community know in case anyone else has the problem.
Hello everyone, we are so excited to try it, where to download the image for the Xperia 10 V please ?
I have exactly the same problem, i.e. since 5.0.0.55 Whisperfish cannot receive messages anymore. Whisperfish is set up as a primary client on the Xperia 10 ii
Thank you but the 4.6 is not in this thread, I was asking about the version of this thread, the 5.0.0.55. Do you know where to download it please ?
It is still in early access so there isn’t downloadable images out yet. You have to enable EA in your account in order to get the OTA-updates to these EA-versions.
only update from 4.6…to 5…via ota…
There are no downloadable or flashable images of 5.0.0.55, as the original topic says (emphasis mine):
2025-01-30: OS version 5.0.0.55 “Tampella” was released for Early Access subscribers of all supported Sailfish OS devices as an over-the-air update.
Thank you, I didn’t understand that “as an over-the-air update” means “only as an over-the-air update” sorry about that.
The key here is not the OTA is the Early Access. Once a release becomes generally availalbe the images will be available too.
Great, I’ll keep crossing fingers, hoping to have the image for the DC72 variant instead of tweaking the DC54 and flash it like the 4.6 version
