Thanks, it’s works in 2G only but not very useful.
I’ve discovered a other abnormal behavior,
When i’m trying to send a message directly by the number starting by 07… Message apps automatically add a other 0 at the beginning of the number. The number become 007… and the message is well marked as sent but never recieved by the recipient.
For only some people it would seem.
No issues for me at all. Though I don’t use an android layer
EDIT:
One issue I have found with Xperia 10 III update to OS 5 - likely related to Pure Maps crashing and map dependancy with OS 5, Rainviewer crashes on startup and cannot display maps.
First install attempt failed.
I started over (download, upgrade) - no more message to remove anything and all went fine. I’ll probably never know what happened .
Same here on the 10 V: OSM and Rainviewer not running with OS .55
Thank you for the feedback. Glad to hear it. The configuration file is not too easy to understand at first but I hope this wg-quick(8) - Linux manual page can shed some more light on it.
I have to ask, was the "DNS = " set in [Interface] section? And not [Peer]. Codewise it looks like there is no error but need to verify this and see if it needs a fix.
The config file is not so complicated. Even is helpful https://www.wireguardconfig.com/.
The DNS entry is in the interface section.
Anyone here who also gets the same message in GUI on C2. “Problem with Store” Could not update Sailfish os?
Hm strange I reainstalled threema libre and its still not working. instagram eg. gets mobile data.
Thank you Jolla! I downloaded Tampella on my XA2 plus et voilà: Wire voice calling works! That was one of my wishes.
I’m not sure if that could help but I remember installing Threema first and only after a few months I heard about the libre version and installed it afterwards. Eventually you might want to try the non-libre version first and see if that works?
Telia Finland sms works.
Nitpicking perhaps; but a small suggestion:
replace “old” with “supported”.
Gives a better feeling to the user
Yea, but maybe it helps Jolla to fix this problem.
I also had problems with android mobile data after the upgrade but fixed it with complete removal of AAS as described here
I have performed both clean and brutal way at the same time which included removing /home/.appsupport and /home/appsupport-root
After reboot and reinstallation from Jolla Store it works perfectly. Thank you!
Still no Android mobile data on my C2 after the upgrade, so I tried the soft way of removing AAP via Jolla Store and then reinstalling it while keeping all the apps (except F-Droid and Aurora Store).
Did not work unfortunately, but the hard way is too hard for me atm
Try to change the SIM Slot
10v tampella, Now find “funny” problem. Pushed Flight mode-that went red and stayed, not changing mode on icon. Booted. Try power on pushing looong etc. Dark, nothing happened. Only after using usb power cable and pushing started ok, but flight mode staying red…off text and icon on the corner…wlan worked…hmm…
10v tampella,continue… Now went to settings and there picked Fligh Mode off, icon on desktop disappeared and fligh mode icon via swapping on desktop is ok…a bit strange …
I already tampered with SIM slots, flight mode, 4G/3G before deleting/reinstalling AAS. No mobile data on Android side, Android settings show no SIM cards, Sailfish side works.
Good day! Any hope in “Blocking numbers” new function on 5.0.0.55 to block group of numbers by * at end? Not 1 by 1, as now.
For example: +3967* - block all numbers with the +3967 at the beginning.
As done for now - only full number for block is useless against spam calls.
