This version works much smoother!
Do you know how big the Linux Devision was at Nokia?
That SailfishOS matured to Version 5 is Miracle and pure Enthusiasmus of the team.
I am not a Manager, but if i were in the Jolla Management - i doubt i would change something.
if you have low ressources, you need to look where you send them.
Just wait a couple more update. I am prety sure it will be much better experience in the End. My Xperia 10 III is butter-smooth now, anything works!
And in 2022 it was the same mess like C2 now. We are all beta-testers, but without our input it couldn’t grow till the version 5!
I know it’s totally unrelated, but what will happen to first Jolla C? Will it ever see the new browser ESR? Will come a new update for 4.6 Sauna?
Thank you
I think that it was announced that it won’t be SailfishOS 5 released for C1.
Dear community members,
There are quite many posts in this category of Release Notes 5.0.0.29 that do not belong here. If you cannot find a dedicated category for your posts, please write them under “General”.
Thank you!
Well you can just switch to another project, like AOSP, PinePhone Linux, whatever…
Jolla is a very small company, and what they did with very limited resources and with help of the great community is simply amazing!
Of course, when you compare Jolla with Apple or Samsung, or Google - Jolla would look not serious.
But this is not the key here. /me personally love the Geek Linux on a Phone.
And the second argument, which many forget to mention - if SailfishOS would be as known as Android - it would has the same 100000 Apps in the Store, which nobody need…
I am happy with the way they go. But everybody need to decide for himself here…
After try the search I found this for you:
@jovirkku - You are absolutely right. Personally i dont found an option to remove posts and place them on another category, but if you can do it - please move it.
Thanks
The update went pretty smoothly, although I had to start again for a couple of times because I had some broblems with my wifi-connection (in general, not related to this particular device). Writing this with a Voxicon bluetooth keyboard, which I love. Too bad it does not work with Android apps at the moment. Tried with my Xperia 10 II, same thing.
Haven’t tested C2 with a sim-card yet, since there is only 2G available in my area.
Is “Hydrogen” as native matrix client a possibillity for you?
