To provide more context:
10iii - went fine - but Android App support still needs to be manually started on device restart!
XA2 Plus - went fine (inc Android App support)
X - went fine (inc Android App support)
Just to clarify this one. Did you upgrade from 4.4.0.x (or older) or from 4.5.0.21?
If you updated from 4.4.0x (or older), did you follow this one AppSupport upgrade notes
I came from 5.0.21. i had the same problem in that one too, and possibly older 4.5.x versions too.
But iâm not really seeing anything in the link that could explain the problem - or anything that i noticed when i did the 5.0.21update a few months back.
What am i missing?
Thank you @rainemak , this explains why the update of my 3rd X10 failed. I didnât wait patiently but fiddled around and rebooted the phone while update was not ready yet.
I think it is rather a lack of the feature than not functioninh
If you implemented individual ringtone for dual sim models, why didnât you implement individual ringtones for calls in general? As there already is a third party app doing so it shouldnât be that hard to implement⌠Thanks for the update anyway!
No update was found on XA2 Dual SIM
The current version is 4.5.0.21, checked multiple times for updates since the release, to no avail. It always says âUp to dateâ. Also removed and re-added the Jolla Account, got the same result.
I like this frequent small updates. Keep up with the developmente of core feature of OS
Did you by any chance transfer the licence to this device? Could be the original imei is still linked to your account. It happened to me, I contacted Jolla and it was fixed in 24hrs.
was the Bluetooth issue fixed?(XA2)
an example:
Thatâs a good tip. But I see the correct IMEI on Jolla | Login as one of the (three) devices.
Happy Jolla Tablet user here
The update went well and Iâm greatful that the device still gets regular updates. Thanks a lot, Jolla!
Did this update break lock screen controls for Android apps? (Xperia 10 III)
In the previous update, I was (usually) able to control e.g. the Audible app when the phone was lockedâmeaning there was a play/stop button on the lock screen for it.
EDIT:
Never mind. Powering off and back on seems to have fixed it.
for me on 10III, 4.5 bluetooth is the same in 4.5.0.16 and 4.5.0.24. on some boots, it doesnt work unless i do:
rfkill unblock all && systemctl restart bluetooth && sleep 2 && systemctl restart bluebinder
once its working, it stays working until reboot.
BT seems totally broken now, so I totally regret upgrading
This worked fine before, now it doesnât and restarting BT doesnât help at all.
Update from .21 to .24 was approx. 50 MB and went well on X, XA2. Thank you for another update!
Did you reboot? What device are you using?
Xperia 10
Unfortunately I have to report that the hotspot (tethering) does assign the same IP address to two clients that are connected do the hotspot at the same time. This is not 0.24 only but since the update to 4.5.0.x generally .
Could this happen if the devices have the same mac address?
I never changed a MAC address and also I wouldnât know how to do this. The two clients are a Volla phone and another Xperia 10, while the first Xperia 10 from which I tell ist my general internet access for everything in the house, with VPN, and nothing else installed on it.
A Volla and a Xperia 10 should IMHO have different MAC addresses.
Also I checked right now in settings/product information and found different MAC addresses.
Volla begins with 58:9eâŚ
Xperia 10 begins with 38.78âŚ
