Yes, I had 2.1 GB free disk space on my internal system memory.
First time I had problem with fingerprint reader on 10 with 4.5.0.16. With previous release never had issue. Whatâs worse is that fingerprint restart form sfos utilities didnt help. Only reboot worked.
What was the time between âearly birdâ OTA and ânormal userâ OTA-update in the past?
At what point of time could the OTA for 4.5.0.16 as normal user be estimated at the moment?
Itâs a known issue that connecting X10III to certain docks causes it to reboot. This confirms that the issue still exists with 4.5.0, which I was wondering about.
I can try to get some logs about the issue, but I donât really want to cause a hard crash to my daily driver
If there is no urgent fix for a new version itâs about one week.
thanks, then I am happy.
I had the same problem and the following fixed it:
systemctl restart aliendalvik
I waited about 30 seconds to a minute, ctrl+c in terminal
systemctl stop aliendalvik
I noticed some of my apps were showing up, but a lot were still missing so. Ctrl+c, then one more time
All Android apps are now there and the data has been retained.
i just reinstalled. didnât find any way to fix.
just make sure to make a backup.
and maybe take a screenshot of your app drawer.
I just tried it. But unfortunaly it did not work for me. Nevertheless thank you for your advise.
Ok. I assume that was a lot of work. Do you have a description for a reinstallation? I do not know how to install 4.4.0.72 over 4.5.0.16? Do you know a manual for that. Thanks a lot.
What is the app drawer? Is it the apps grid?
You cannot, since 4.5.0 is a stop release. You need to reflash 4.4.0.72.
When Jolla deems it to be ready.
This statement is valid at any âmomentâ.
I just noticed that the flashlight disappeared from the top menu, I was able to re-enable it from settings but I donât think it should have disappeared (in general the feel of the top-menu was as if it had been reset, which was also a nice chance to revisit all the available options for the top menu).
Also one of the buttons in gPodder disappeared which seems to be because image://icon-m-download no longer exists.
for reinstallation you need to reflash your phone. depending on what computer you have its more or less easy (i can help you tho).
that thing with the stop release is not the reason. (more about those over here)
as 4.5 is currently still in EA, you cannot download it from shop.jolla.com directly. you have to reflash .72 and then you can upgrade to 4.5 if you want. after that you can install stuff and restore your backups.
and yes, the app drawer is the grid
very good advice.
also tried it before giving up yesterday, but it didnât want to.
actually i looked up, what
systemctl status aliendalvik
gave me, and it gave me some stuff. but i was too tired to investigate.
maybe try that before reflashing, maybe it can help others too. @tmindrup
just post the output here
Thanks attah. It had slipped past my radar. Done.
Yes indeed. Your sentence states it better.
Yes, exactly, it is the kind of feedback I wanted. Thanks for those convincing reasons. I have removed the bullet point for Storeman.
i see there are many issues,
is it possible to skip this update and wait for the following one?
Please note that 4.5 is still in Early Access, and i would suggest you wait for the final release. It is quite common and expected to have such hickups on early releases.
