Let’s just say the whole SFOS UI/UX needs overhaul by a professional design team.
Currently it is just applying patches on top of patches on top of original UI that is 12 years old.
PS BTW, I use SFOS since 2017 (after 6 years with N9) and I still struggle distinguishing between the default apps’ icons. They’re horrible
Unlike N9, for example, or any competitor.
Agreed. But in the meantime, try this: If the bottom of the phone is closer to you, swipe up is like “go away”, while swipe down is like “stay with me”…
I upgraded my Sony Xperia X to 3.4.0.22 successfully. However, after downloading 3.4.0.24 (RC9) I got a message saying gnupg2 must be uninstalled before proceeding with the update. I tried doing so but got the error “Error: This request will break your system”
I got that error message about a whole bunch of packages. I could still select ‘Install’ and go ahead without removing any of those packages, though. I’m not sure what the warning was all about, because the packages it warned about didn’t really make sense, e.g. opus or libjpg, or in your case gnupg2.
bluetooth connectivity improved. my sony car radio now connects with x10 within 10-20 seconds. before it took minutes, jumping between audio sources etc.
after reconnection sound may stutter but pause , 5 seconds play fixes that.
so for me, great improvement
if only xperia 10 were a better device. camera is dead now (autofocus), screen stopps to work now an then and case is broken too.
It seems I didn’t check properly and the issue is with OSM server, which has its own version of zlib. When I try to run it it errors out with the following message:
harbour-osmscout-server: /usr/share/harbour-osmscout-server/lib/libz.so.1: version ZLIB_1.2.9’ not found (required by /usr/lib/libpng16.so.16)`
I only just now noticed that it uses a local libz library for no apparant reason.
Edit: Was managed to fix it by removing the local library and symlinking it to the version in /usr/lib.
This is not a problem but the intended way. We will follow our convention to publish the flashable images at the same time with the roll out of the OTA update to all users. If everything goes well this should happen in a week or so.
My XA2 update has been installing at about 95% for two hours now. Should I still wait or what?
Update: Never mind, fixed it with
ssu re 3.4.0.22
version --dup
New buttons in email app look ugly to me, and hate that call answer UI change. What’s the point of fixing stuff that isn’t broken? Pulley menu is one of the key features of Sailfish OS UI, and now it’s being replaced by tiny buttons? I don’t think that that was the idea of Sailfish OS swipe UI.
Please note, that this only true for upgrading SFOS at the GUI.
At the command line, sfos-upgrade takes care about unapplying all Patchmanager-Patches before upgrading, but when upgrading manually at the command line (e.g., per ssu re a.b.c.d && version --dup) one shall unapply all PM-Patches before doing that.
While other safety measures in PM3 should prevent major damage to the SFOS installation when upgrading SFOS manually at the command line with PM-Patches applied (in contrast to PM2), you should avoid trying this.
The email app also lost good ambiance support, especially for plaintext emails that are now displayed with an ugly white background, rather than the usual translucent background of the ambiance, resulting in a bad integration rendering.
I really hope the dev team listens to the user feedback here and rollbacks the changes on the email app at least.
