[release notes] Kvarken 4.1.0
Things seems working quite fine on X10ii. I tested my keyboard layouts app in aarch64 and it’s a joy.
Thanks Jolla, great job :smiley:
Waiting for the update with the android layer and predictive text.
What are the chances to brick an XA2 while testing not uninstalling packages before system update? I mean, where not even reflash would work?
@amaretzek: I have never experienced myself nor heard of such a total breakage. Flashing is a powerful tool.
WhatsApp starts only once is fixed at least for me with 4.1.0 and Android 10 app support!
I (try to) maintain YTPlayer, I’ll have a look at this (not today, but soon). Thanks for the tip!
Edit: I installed it and (sigh) entered my API keys. I was able to browse categories, but couldn’t play any videos, because youtube-dl is too old (it can’t extract stream maps). I have only .so.68 libs but didn’t have to symlink the .so.66 ones. I don’t know what’s (not?) going on, and I don’t seem to be affected, so I can’t really dig deeper… Installing harbour-ytplayer did install a few dependencies, though, but I can’t recall which ones anymore.
@jovirkku can the XA2 no call audio bug please be added to the XA2 known issues section of the release notes?
So Jolla Maps is no longer available? (10ii)
Seems also I cannot log into Facebook (Facebook states this platform is not supported at the moment). Google login was also tricky as the acceptance button for stuff was rendered very small in the embedded browser.
Most of the basic stuff seems to work. I can’t figure out how to use the fingerprint reader effectively. On Android I would just hold it on the button and the device would unlock almost immediately. With SF I seem to mostly be getting the code unlock and sometimes the fingerprint seems to work. Screen side swipes are a bit finicky.
Sailfish looks gorgeous on the 10ii (my only other reference is a Jolla 1). Much nicer design than Android. I think there could be a greater niche in selling to style conscious forward thinking trend setters.
the same issue here (Xperia 10)
I dug a bit deeper… I did ldd /usr/share/harbour-ytplayer | grep libicu and got this (save a typo or two):
libicui18n.so.68 => /usr/lib/libicui18n.so.68 (0xf54fb000)
libicuuc.so.68 => /usr/lib/libicuuc.so.68 (0xf53ad000)
libicudata.so.68 => /usr/lib/libicudata.so.68 (0xf34e9000)
Are you sure you are running the Openrepos version? (It seems to have outdated harbour-ytplayer, though… Gotta update it soon.) Anyway, let’s continue this discussion over at Openrepos, so this thread stays better in topic :slight_smile:
Not sure if Jolla Maps was ever available to other devices than JollaPhone. I think if you still have your JollaPhone around, you could maybe get the app from there and install it on your other phone(s), but I’m not sure how Xperia 10II reacts to 32bit programs?
Sorry for the noise, seems like I jumped to the old Jolla store version for some reason. I could install 0.6.17 without issue.
@jovirkku
Same counts for harbour-defender.
As mentioned here
and maybe follow up here
https://openrepos.net/content/peterleinchen/defender-ii-updated-encrypted-devices-originated-nodevel
Or even here
Self tested now again with this release on a X and it boots up just fine.
So would you please think about removing this warning as well, please?
Or maybe link to those informations and put a warning that version >=0.4.1 is needed? (or is that not already blocked within some patterns-sailfish package?)
and to avoid confusion, just seen after finishing this post here
https://openrepos.net/comment/37441#comment-37441
Well, you can increase the root volume size quite easily; when using this guide not on a freshly flashed device, check explicitly that there is enough free space for shrinking the “home” LVM volume.
But I never understood why Jolla has not increased the default rootfs size long ago, it is a trivial change and already in their git (but IIRC unmerged) for long.
Looks like the issue with sd cards fixed by this update also. Thanks!
I think it cannot run 32 bit apps.
I didn’t know Jolla Maps was only on the Jolla 1. That’s a bit of a pity as I could not find any native maps application from the store. Jolla Maps was (very) far from perfect, but it did its job better than nothing.
@Setok
you can find them in open repos
https://openrepos.net/content/rinigus/pure-maps
https://openrepos.net/content/karry/osm-scout
[BUG] Not able to install/upgrade android apps via Aurora store.
I was wrong. It works, but requires reinstall.
For me it worked out of a box, but now no new window is opened after downloading.
It opens a window rather than a new screen. Which has been the standard Android behaviour for years BTW, IIRC.
