[Release notes] Finlayson 5.2.0.22
10iii and 10ii upgrades went fine.
p.s. is there a reason why the downloadable images are still 5.1.0.xx?
Two more attempts failed but after enabling persistent journald logging it suddenly worked :slight_smile:
Quote from post 15 above.
looks like it was some network issues, probably package was downloaded not fully or something like that. after 4 try updated completed successfully/
I finally had the time to test everything and, since the update, the stock browser doesn’t open.
Perhaps some package wasnt installed correctly. Search for manual SFOS-update and if you think your knowledge is big enough for this, make a manual update.
@nephros’s guide is excellent, although I think for many people, just checking for the largest installed applications could be sufficient:
But I agree that the tiny root partitions continue to be disastrous. They should really be set to 10-15% of the total storage size. I think anyone who needs more than that is in the “can manually resize the root partition” camp.
I also have that 20% crash issue on my C2 and phone needs to be charged every day.
I followed a guide on the docs for manual update but it didn’t found any update. i also reset the browser but it still doesn’t open
indeed. it is annoying. what i find much more annoying is that the signal is part of the problem. i have a JP2026 and the only way i can make decent calls is with the earphones (moreover, when bluetooth, i need to pair every time i use the otherwise it gives error).
so, is it a signal issue or an antenna issue? if i keep the phone close to the ear, people can’t understand a word, if i use the headset than magically the signal is no longer a problem, no matter where i am. i really convinced that the hardware is quite bad (it reminds me the antenna gate which affected the iphone 3 when apple suggested to use it with the headset)
or the way the software manages the quality of the signal is as bad, and for a phone, this should have been the FIRST improvement to release with the upgrade
any though on that?
My JP2026 works just fine. Mostly 5 or 4G, Vodafone, urban environment. Perfect sound using the phone in an exotic old school way. You know, that ear and mouth technique. Still good with speaker phone and ok’ish with Bose BT in ears. With the BT in ears my voice is rather low even with noise cancellation turned of.
I use SFOS as a daily driver since the first day of Xperia X in 2017.
Whenever I had problems with telephony it was in rural areas with bad reception.
I believe this is the issue you’re talking about, which is being fixed:
In the meantime, this is the workaround:
Ifollowed the “free up space on root partition” thread instruction - I mentioned that in an earlier post. When I checked what the biggest files are, 2 libraries of xulrunner popped out. This is Firefox stuff, but I don’t use Firefox itself (I have one of the fork apps). Anyway, the file endings -next-153 and -next-140 matched exactly 2 versions of next-browser, that you can download from Storeman, and I remembered that yes, I’ve been playing with them in the past.
Uninstalled 2 whole RPMs, as they somehow were still on disk - I don’t know how exactly, maybe storeman uninstall failed to do its job and deleted only the icons and stuff.
Ah now I understand what you meant - they might have been dependencies that weren’t uninstalled. I first thought you needed to delete files with rm instead of rpm. Thank you for the explanation!
Just casually waiting for the new image for Xperia 10 V, so I could resize the root in hybris-recovery and finally upgrade. The recovery from the latest 5.0.0.78 release does not appear to work with 5.1.0.11, unfortunately.
Upgraded my Xperia XA2 and that new browser is such an improvement. Previous version was often crashing on a particular website which I always thought was due to limited memory on my phone. Browser generally seems a lot faster too. Very nice!!
Update went fine and many bugs got fixed with my JP2026, but got new problem with normal phone calls.
When somebody calls me or I call somebody, the audio works fine for first 1-2min then it get crackling noise on my side and on the other side they say I sound like robot metallic sound that is very hard to understand. This problem did not exists in the previous version.
Now it’s useless to use normal phone calls :sleepy_face:
Someone said toggling the loudspeaker on and off stops this
Time to time, mostly when typing sms got black screen like lipstick or whole GUI crash , sometime can wakeup screen in few seconds sometime it took longer so i put phone in pocket and after while it is ok
no Andoid support installed , first noticed after update to .20 but on .22 it happens ± every second day
10 days in and all still working good. Just a couple if Android services restarts required so far.
