Thank you jolla for this update. I’ve been waiting a looong time for an update to the native browser. Soo many sites thar I’ve missed being able to read now works (always preferred native apps over android ones). Also, cell broadcast support is a welcome addition.
The update went smooth and I haven’t found any new issues yet (C2).
My JP 2026 is finally working again. I had to put it in the drawer because of serious black screen and shutdown issues. It basically was unusable since updating to 5.2.0.18. The update to 5.2.0.20 didn’t fixed it either and the dead on disk issue I had remained.
But since updating to Finlayson 5.2.0.22 my Jolla seems to be fully working again. No shutdowns, no apps crashing immediately after opening, no black-screen-lipstick resprings, everything I tested so far is working smooth and stable.
Two small hiccups occured right after the update though. LPM wasn‘t working reliably but restarting sensorfwd brought it back and there was a situation where there was no reaction when hitting any app icons in the launcher, but 10 to 20 seconds later all apps I touched before opened suddenly like in one batch. It didn‘t happened again though.
On Sony Xperia 10 iv. Native browser got very stable and very usable. I love it now and almost no need to use other ones. Android app support is super, please, so not kill that feature with subscription on community ports, because there’s one of few things that removes incomforability of switching from other os’s to sailfish. Or leave soon room for piracy. Because piracy boosts popularity of any software. I have red that camera was fixed for Corri’s 10 V (both photo and video) - hope fixes will be compatible with 10 IV. As i was investigating fixes for my 10 IV - and i discovered same things that were fixed for 10 V, so i believe in near future those fixes will be included into next update. 5.2.0.22 feels solid. Bluetooth feels to be working better after update.
Updated my C2 and started to have weird battery behaviour.
I keep the phone unused, in flight mode and nothing else running. After roughly half a day, suddenly the battery drains from ~95% to almost 20% and phone will crash if I dont plug it (the 20%/crash issue already existed before the update, not the draining).
Using SysMon App, I can see that there is no sudden CPU usage (stays below 5%) and RAM is used at~15%.
Thinking about running “device reset” now that OP-mobilii no longer work on SO. I havent seen this on my new JP26.
You don’t need to switch to the Jolla store version. That exists to bundle permission files and default settings so it can be completely set up from the Startup Wizard instead of having to configure F-Droid and all the self-check. It’s the same version with the same signature - you should be able to upgrade that from F-Droid even (though not tested this).
If you’ve already installed it from F-Droid, there’s no reason to switch. You’ve already put in the effort that it’s supposed to save you.
In the app for System settings there is a page to see how much storage is used by different types of files. Hereto will discover that many apps are stored in this limited space. The solution is to delete apps until you get the necessary1,3 GB of free storage.
As if there weren’t more important things for Jolla to spend their so severely limited time on, like e.g. finally fixing the network signal strength indicator that’s been broken (on all devices but the Jolla2) for almost 9 months now.
Honestly IMO there’s bigger fish to fry than even that.
I’ve either got signal or I haven’t, it doesn’t really matter to me if I have one bar or four. The current indicator, broken as it may be, still tells me whether or not I have cell service.
Not at all true for someone who lives or works in a place with challenging signal level conditions, who often needs to look for a good spot in order to avoid distorded voice quality beyond comprehension (when CRC gives up due to too many erroneous frames) or call getting dropped. And that’s exactly when properly working signal level indicator is of great help, letting one simply walk around the place and visually locate a spot with the best signal level, just by observing the indicator rather than keeping the other party waiting and repeatedly asking ‘Can you now hear me more clearly?’.
It definitely isn’t true that you either have signal or not. Between not having a signal at all and having a good signal there are signal levels (e.g. around -100 dBm) too weak to sustain comprehensible voice quality and avoid calls being interrupted. And no, it doesn’t take being in the middle of desert to face such conditions, they’re quite often to be found e.g. in modern thickly insulated and shielded buildings.
Yes, I do have such challenging signal levels where I now live and hence I do miss very much a correctly working signal level indicator, which has been broken for nearly a year while they prefer to spend time on such gimmicks.
Maybe the people whose responsibility the signal level indicator is, hasn’t had time to work on this, while the person who made this “gimmick” has had time, but no know-how on the indicator, so they chose to work on these small side projects instead?
All going well so far. Usually I have given up and gone back to my Android phone by now, but with this latest release the phone has been very reliable.
Bluetooth is working well with Android apps.
The only problem I have had is that, yesterday morning, no Android apps would start, they just showed the icon on the home screen but would not maximise when tapped. I restarted the phone and it has been fine since.
Xperia 10 III user here. Once the update is done, it’s a nice experience. Happy to announce that most of Bluetooth problems are gone, and I was even able to connect a watch via Gadgetbridge+Rockbridge combo (earlier on, it did connect for the first time and few minutes only, it was impossible to get it working permanently). Camera quality is visibly better, though default app is still poor(ish) - but I do appreciate the ability to scan QR codes, finally.
But before that happened… You already heard your share about 4 GB on root partition. This can’t go on like this. Deleting the apps you use is not the solution. How does SFOS want to compete with anything on the market with such approach?
Also, even if it has to be done such way for now, it’d be nice to publish a, you know, official guideline. Were it not for this thread on the forum, I’d have failed miserably. The correct way to do it is somewhat counterintuitive, because the first thought for most people (myself included) would be to delete/move music and pictures to SD.
Sure, this post is super helpful, but you shouldn’t leave everything to the community. Especially when you know you have some shortcomings.
A notice to turn off developer mode for upgrade would not hurt either. I figured this out myself, but somebody else may not be so lucky
XPeria 10 III Dual Sim here with 1.4G free in root. The update seems to download correctly but when rebooting into the update, the LED is showing a red light after entering the security code and immediately rebooting back into 5.1.0.11 - just looking for some upgrade logs that will give some insight into what happened.
In my case the culprits were 2 packages of next-browser, that despite being uninstalled via Storeman still were laying around on root partition. Yea, I could have checked that earlier, but I uninstalled (or I thought so) and forgot about that after a few months.
Nevertheless, my case illustrates the typical user’s reasoning line quite well, I think
I don’t claim to be the wisest, I started thinking and checking around only after a moment.
