[Release notes] Finlayson 5.2.0.18 - Jolla Phone first
Nice work Keto and Team! Most of the problems I’ve encountered are fixed with this release, improving my overall experience by a lot.
Huge update for a seemingly minor release, thank you!
One small suggestion maybe.
The phone asked me to connect a charger because it had 42% battery. Most phones today shortened that percentage closer to 20% because most batteries today can hold a charge, and especially j2 in this case.
Not a dealbreaker, but maybe worth considering!
Oh yeah. AAS definitely feels more smooth. I can also watch up to 2160p video streams on YouTube (which I couldn’t before). What a nice update, I am very happy with it!
True, but I remember this decision was made when the Jolla C2 was released, and 20% on some Jolla C2 devices means: “Search for the next charger within the next few minutes.” I have no problem with this new rule because my JP26 performed the update right after I plugged in the USB-C charger, so I didn’t have to wait for it to charge.
Spectacular work all around
I can actually watch videos in Grayjay now, it’s great!
Looking forward to the AAS lockscreen setup fix now :partying_face:
No issues with updating. Pretty much on-par with every update I did since I started using SFOS.
EDIT: Oh wow, Discord through AAS is hella smooth. Nice!
Updated but still had BT turn itself off again.
Small issue: After Version Upgrade the Device didnt boot - Display stayed Black, also same result as i pressed the power key - i waited some time and pressed the power key for a Long time until the status LED went RED, then it booted successfully - no issues since then
What I also noticed: After Upgrade the Status-LED Next to the Front Camera stayes on, Even if there are no new Events on Event Screen - it Turns Off if I Unlock Phone only and turns On again when I lock it
EDIT: Bug could be solved with turn Off the phone for 30 mins and start again.
Still at 5.2.0.17. J2 is closed off because I can not charge it. Battery has just 20% charge now after unsuccessfull charging tests.
Thank you for staying on topic.
Bohahaa :laughing: I love this wording.. “garbage”
What a juicy surprise! :partying_face:
Many nice fixes and small updates!
Didn’t expect that call volumes would have been fixed this fast :racing_car:
Have to try the BT if my car and phone can now speak civilized together :upside_down_face:
Thank you for the new update :dizzy:
Fernschreiber doesn’t launch for me. :confused:
Otherwise update went fine! :slight_smile:
library "libselinux.so" not found
Could not open module param file '/sys/module/mali_kbase/parameters/large_page_conf'
[  540.319393] (harbour-fernsch) [MEMPROF] Memory instrumentation via debugfs enabled
[ 3][t 4][1790785901.622489452][Td1.cpp:220][#1][!MultiTd]      Create Td with layer 166, database version 14 and version 51
on 4 threads
[ 3][t 4][1790785901.622611999][Td15.cpp:259][#1][!Td][&td_requests]    Sending update: updateOption {
name = "version"
value = optionValueString {
value = "1.8.21"
[ 3][t 4][1790785901.622648477][Td15.cpp:259][#1][!Td][&td_requests]    Sending update: updateOption {
name = "commit_hash"
value = "ec788c7505c4f2b31b59743d2f4f97d6fdcba451"
[ 3][t 4][1790785901.622684955][Td15.cpp:259][#1][!Td][&td_requests]    Sending update: updateAuthorizationState {
authorization_state = authorizationStateWaitTdlibParameters {
[ 3][t 0][1790785901.812816381][Client.cpp:280][&td_requests]   Begin to wait for updates with timeout 5.000000
[ 3][t 0][1790785901.813223838][Client.cpp:293][&td_requests]   End to wait for updates, returning object 0 0x7a88001bf0
[ 3][t 4][1790785901.835403680][Td27.cpp:308][#1][!Td][&td_requests]    Receive request 1: setLogVerbosityLevel {
new_verbosity_level = 2
[ 0][t 4][1790785902.402419805][LogEvent.h:153][#1][!Td][&version() < static_cast<int32>(Version::Next)]        Wrong version
61
EDIT: reinstalling the (experimental!) rpm of harbour-fernschreiber-0.19-1.aarch64.rpm fixed that.
After downloading and reboot the phone stayed black. Hitting the power button revealed the numeric pad to enter security code and the update continued smoothly.
Thank you for a great update. Everything went smooth. I still miss the :peace_symbol: icon on the emoji keyboard and there still is no fruit when booting the phone up. Otherwise I am happy.
Somebody already tried Here Wego? I am so happy with Pure Maps, I don’t bother.
0.1.8 works here. Retry it?
Afyer update Can pair a BT keyboard now successfully. ( and use it) :slight_smile: Keyboard in question fuj:tech bt 5.0 tkl. ( basically ultra cheap generic one )
works here too. 0.18 version
Thank you. I just paired my Samsung Trio 500 successfully. Great.
Update went smoothly. But a few minutes ago, I put my phone on a table only to find out that it had chrashed with red led flashing… That’s a first since August.
