Sorry if this was answered already, but…
Does it constantly eat power?
Does it access the internet?
Yes, this, however, requires the keyboard to be active. So I need to open an app where I can type first. But, I think after the initial setup this is just a minor inconvenience. ![]()
Per the original developments of the FUTO Keyboard re: https://docs.keyboard.futo.tech/ it only connects to the internet to download the dictionary, emoji pack or speech model, at your discretion. After that, there are no unprompted connections, everything is done locally.
I don’t see why it would use any more power than the stock keyboard; if you’re on an older device like the XA2, you might want to worry more about its memory footprint.
Wau! Very good keyboard indeed. I like very much.
If you use save passwords option and you type with some android app, e.g. Whatsapp, app is asking permission to saved passwords constantly.
Thank you!
had a lok at the site, the source - they have their own gitlab instance, the github is apparently just a mirror - it all looks very trustworthy
Installing now.
Thanks for porting this keyboard!!
Would it be possible to offer a faster way to switch languages (e.g. long press on spacebar or a language key instead of the voice input one)?
I’ll have to check this out and see if I can reproduce it
As usual, the download is available via OpenRepos.net or the OpenRepos app Storeman
AMAZING!! A saving grace for us who cant with the stock keyboard. This honestly makes my JP2026 SO much more usable. Thank you!!
i’m not an IP lawyer, but it seems very obvious that it would be a violation of the terms of the FUTO license (in particular, the non-commercial clause) for jolla/jollyboys to include futo in their commercial project, SailfishOS.
that’s what i mean when i say futo cannot be the default keyboard, it cannot be included in the base image, and it might not even be able to be added as an optional package in the jolla store. it has absolutely nothing to do with convenience or the user’s interests. that is irrelevant.
it should be fine for it to be distributed by the community non-commercially (github, chum, openrepos/storeman), but jolla cannot distribute it as part of sfos, and possibly cannot distribute it at all.
0.2.2 fixes the swipe gesture typing for me on 10 III on SFOS 5.1. thanks so much!! instant replacement of okboard. my favorite feature is that there is an option to keep it on even when a bluetooth keyboard (or UInput device like lipstick2vnc) is present.
Of course Jolla can - after coming to a business agreement with FUTO themselves (which is presumably the whole aim of the freebie license).
Can you added Arabic dictionary
I have one problem with FUTO I discovered yesterday.
I’m using Polish, German and English every day, therefore FUTO ends up with two keyboard layouts:
QWERTY - en-GB + pl-PL
QWERTZ - de-DE
The problem is, that QWERTY layout is taken from en-GB, which lacks some Polish letters, like it’s impossible to type “ą”.
I guess opt-out from this would be nice addition, so for my use case, I want layouts never merge.
Word suggestion for swiping is still totally broken in german. Swiping ‘auto’ brings up ‘Allwetterzoo’ for example. And i can not correct the words to improve it.
This is really nice, especially how you’ve included settings to make it look and feel almost exactly like the default Sailfish keyboards. Two suggestions, if possible:
Great keyboard! I’ve run into one issue so far, when focused on a password field, there is no way to paste copied text as far as I can tell. In ownKeepass for example, the paste button appears as soon as I reveal the text in the password field. On the built-in keyboard, the paste button stays available even when focused on a password field.
Have you tried goung into rhe settings with the 123 switch button and tap on clipboard?
I don’t see that option. According to the settings that option only appears if clipboard history is enabled, which I do not want.
