A few weeks ago, when I said that a feature like this was needed and agreed with him, some people got worried and started saying things like, “No, do you think this keyboard stuff is easy?”
And then, I think about a week later, there was a post on the forum about the FUTO keyboard. If this guy managed to put in the work and pull it off, then Jolla could also develop something like this in a relatively short time and release it for us. They don’t necessarily have to make FUTO Keyboard the default.
The same thing here, but you swipe very slow the quote go up to 70%. Typing and Suggestion are good.
No matter how i swipe the suggestion is way off.
Suggestion:
In the regular Settings/Emoji/Emoji style in drop down list it should be also some example not just text. That would minify possibility to chose unavailable type.
Observations:
it’s hard/impossible to choose suggested word on the right as list keeps jumping to the beginning on left side.
When switching language before inputing the whole word, the suggestion starts at that break as new word and not whole word as expected.
Double space doesn’t always return dot despite setting.
Typing dot often doesn’t clear the space before.
Yes, swiping “Danke” (german thanks) without touching the letter “E” always produces “Denke”.
Nevertheless, I am very glad to have the opportunity to swipe again! So thank you for this work @HtheB !
You do realize that even the “last” copied clipboard needs the history.
No history means no clipboard.
You can delete the clipboard manually or set a timer for the clipboard to be cleared in the FUTO settings
That’s not how a clipboard works. It’s just a simple buffer where you can store and read text. So the current selection (if any) is always available. Only if you want to know anything other than the current buffer, would you need any kind of history.
It’s open source, feel free to add that option and do a PR.
I might if I get the time.
I was wondering about one thing though. If the keyboard requires clipboard history to read the current entry, how come the normal paste shortcut does work without history enabled? It’s only in password fields that it disappears.
This does make me wonder, did you use an LLM to generate the code? I’m getting the impression that you don’t actually know what your app is doing or how clipboards work for example.
htheb ported an existing proprietary (but source-available) keyboard. that is a wildly different beast, and is not an option for jolla.
edit: htheb’s efforts and the results are AWESOME and i already love this keyboard experience. its just not viable for commercial purposes
I get it. I don’t really know much about that side of things, while you seem to know more about the licensing part. So basically, I guess what you mean is something like this: we have Android App Support, but could Jolla, for example, take Android 13 and customize it however they want? Short answer: no, because that code belongs to someone else.
Thank you for this! Really appriciated!
The normal Paste button reads the current clipboard directly, but in password fields the suggestion bar is hidden and the paste button accidentally disappears with it. So that’s a bug. I’ll fix it in the next update so pasting the current clipboard works without enabling history.
I tried OKBoard. It worked.
Then I switched to FUTO, which also worked.
Then I uninstalled OKBoard.
Now I have no keyboard at all, even when I select one of SfOS’ default layouts.
I rebooted.
I uninstalled FUTO.
I rebooted.
No keyboard.
The solution is here. If ~/.config/maliit.org/server.conf only refers to OKboard and nothing else, it is safe to delete it completely.
And Utilities now features a Restart Keyboard button.
OP can ignore this. It only affects people who previously used OKBoard.
edit: and of course I reinstalled FUTO keyboard.
there is another model with machine learning the android version is using, which needs pytorch and go. i compiled it and made an rpm and installed it and it’s way better that way. i created a server service in systemd like your voice input is using. then words are recognized only if the first and last letter is reached exactly. and also do you use ccache, or what is your setupand workflow? and should i do a pull request for the machine learning model and one for the first and last letter? in the pull request i could include the cloning of only the needed dependencies of pytorch and not the whole. i also made the German dictionary a bit better. for that icould also make apull request. the disadvantage of the machine learning model is that the dictionaries are not enough, one needs one or two other files which i only created for English, German and Hungarian, but if you want i can create them for all the other languages too and include them in the pull request. just tell me how you want it.
Great question! I was asking about this earlier and I don’t think we got an answer yet.
Judging based on the pace of development and the output, it certainly seems that LLM’s are involved, but it would be good to know how much. Honestly it’s a bit shocking to see everyone jump on something so new so quickly.
@HtheB, could you clarify things for us?
They already ignored the LLM/AI question at least two times I remember, so I’d say it’s pretty clear that this app is either completely - or at least heavily - vibe-coded.
I could be wrong with that assumption, and even if not, that would be fine. As long as a developer is open and transparent about their AI usage, everybody can decide for themselves if they want to trust it, or not. I just unsettles me when someone does not want to “confess” their reliance on those tools.
But hey, at least the app is source available. That’s already an upside compared to other candidates on this forum.
Exactly. I won’t be telling people to stop using LLMs for development or vibe-coded apps for their everyday tasks, but I’d like to see more demand for AI declarations alongside the code, even if it’s open.
I’ve been thinking of making a poll or something about this to hear what everyone thinks.
yea it seems clear that this port is at least heavily AI-assisted, if not outright vibe-coded. i didn’t realize that HtheB was keeping silent about that. i agree that this is, er, sub-optimal from a transparency perspective.
provenance matters, @HtheB, so please indicate this.
…but yea the port is source-available, and the base project is source-available and widely used. the functionality is great (though the swipe-gesture completion is MUCH less accurate/useful compared to OKBoard). this keyboard is currently the best input experience on sailfish, and it’s faairly low risk.
