I bought a 400 GB MoveSpeed card for my XA2 Plus after searching the web and finding this page.
It worked fine but later got write-protected and I had to contact the seller and got an exchange…
Anyway I don’t see it senseless to ask for clarification before buying an SD card just for the device.
Unless you count the 32/64GB era, which is now 10+ years ago - and was a filesystem-only thing anyway, there simply are no relevant SD card size limitations anywhere. This makes it senseless to try and insert support specifications when there can’t be any. I don’t understand why Sony lists a made-up “spec”, and a rare size at that.
Hello, new here. My iPhone 8 is starting to have issues and I´m interested if Jolla C2 is for me. My main aim is to have a phone which will provide me banking services and HSL (Helsinki area public transport) app. I´m also interested about IT development but don´t know much about coding, would be nice to work with development here and then. So, do these apps I need work in this phone in general, or do I need to do coding first, how does this development thing works?
The HSL app works on AAS, as does MobilePay as well, if you want to use that to pay for the tickets.
But be mindful, that any of these might break at any time temporarily, or even permanently, because of bad updates on the apps or on AAS. So, if you want to be careful, don’t update your banking app, if it is working.
