I didn’t find relevant info, so I am creating special thread.
4.5.0.18
- I installed OSM Scout Server from Chum.
- OSM Scout Server complained about missing fonts part. It was not found on chum, I found on Jolla store. So I installed it from there
- After that OSM Scout Server is able to run. I downloaded maps
- I installed then Pure maps. That one from Chum complains about something, so i installed it from Jolla store (yes, chaos/mess with repositories. why ? )
Now pure maps reports error HTTP status code 500
Why ? How to solve it ? Looking from help
It is in Chum, just search for it in Chum GUI app. However, you probably selected map server profile including raster tiles. Unless you have some very old map client, it is not of much use and just takes larger space on device for maps. I would suggest to select default profile instead.
Awesome bug report. Very helpful and can be surely fixed. I suggest to install Chum version. If there is some issue with install, try to run pkcon install in terminal and see error message. Act accordingly to it.
However, that said, Jolla Store version should work as well, its just limited.
Which map service are you using? Online/offline? Does it fail for all of them or something specific. Try to run Pure Maps in terminal and see what’s written in output. Write down the details and file an issue in Github repo.
Great to hear that it is sorted out now. Although, Pure Maps dependencies in Chum should have been pulled in automatically.
Re TTS: you can use picotts - that one is available at Chum and has few more languages.
I already installed picotts, but so far I haven’t find a way how to select it in the pure maps
picotts will be used automatically if you choose language that is not provided by mimic
I see now, but not all languages have TTS engine.
Thank you for your answers
Quick question
Is it possible to download whole map of let’s say europe?
I think that with OSM Scout Server, you can download the whole planet without any problem. 3 prerequisites:
- a good internet / wifi connection
- a very large µSD card
- time to spare
Currently on my phone: France + Reunion Island + Monaco = ~ 10 GB
That I know, I’ve been using it a few years now. I’m however planning few trips around europe this year and what I was asking is it possible to download a map of whole europe as the one? Downloading every single one by hand is possible but it takes a lot of effort, some knowledge about topography (Germany for example is a lot of different maps, cannot download Germany as one big map)
Also having that numer of maps present different chalenge, as searching for adresses is very slow (Takes few minutes). It is no acceptable when you need to find different route in a hurry
Edit: It is possible to download whole europe from third party recomended by open street maps. This is one .pbf file. Is it possible to add this to own OSM Scout Server?
