Hello, as the title suggest, plex is not working anymore, it just launch the loading screen then close it
It should be a regression, since it was working with 4.5 and downgrading to an older version gave the same results, except downgrading to a very very old version made for android 4 devices, and on 4.5 i was using latest one from aurora
Are you referring to the Android Plex app ? If so, I use the latest version (10.20.0.1427) from Aurora store on SailfishOS 4.6 without issues.
I have the behavior you describe for other apps (i.e. banking app), and I need to launch them from Android settings, or from Aurora, as previously stated by @Edz.
