REPRODUCIBILITY (% or how often): ?%
BUILD ID: 3.4.0.22
HARDWARE (Jolla1, Tablet, XA2,…): XA2 dual sim
UI LANGUAGE: English
Installation of 3.4.0.22 went smoothly and after loading in 3.4.0.22 the phone was super hot. So after a while I decided to shutdown in order to restart. The phone is stuck with red LED on and does not respond to button presses. Plugging-in the USB cable triggers the “charging” notification sound so I believe the phone hasn’t shutdown fully/properly.
Shutdown
Black screen, Red LED constantly on. Phone does not shutdown and is bricked in some corrupt state and is still warm trying to shutdown.
You can try to reboot to recovery and enable permanent logs (see man journald.conf), restart try to boot for a while and then reboot into recovery. After that chroot into your rootfs and see what happens to debu further by running journalctl
I have the same issue. The phone neither reboots nor shuts down and I cannot ssh into it (ssh_exchange_identification: read: Connection reset by peer).
Any ideas?
EDIT: Phone rebooted on itself after a while and UI loaded correctly this time.
Yes, that happened to me too after a while, but if you try to reboot once more it seems that it won’t recover… it’s been hours now that the phone is stuck in this state…
JP1 - installation completed successfully, but after rebooting, only the Jolla logo appears, followed by a black screen. Recovery Mode does not work - phone is not properly recognized by computers (I checked on several) and forcing installation of needed drivers (NDIS) does not change anything.
XA2+ Dual - the same as above, with the difference that there was an error at about 50% and phone rebooted itself. Recovery Mode as above.
My 2 went to bottom - 1 was spare, 1 was used every day. . .
Somebody can help
I also experience that my X Compact gets stuck while powering off, and it runs super hot. Waiting around five minutes doesn’t seem to help, so I have to force reboot with power and vol+ buttons. Also noticed that systemd (PID 1 and one other systemd process) were using a lot of CPU before it happened. Some other processes (don’t remember which right now) also contributed to high CPU use, but PID 1 was worst. This doesn’t start directly after a reboot, but comes after a while. Haven’t yet seen any correlation with anything else I do on the phone, or if it just starts spontaneously after some time. If I don’t wait for those processes to havoc, rebooting works just fine without getting stuck.
Thanks for this, Vol up + power successfully restarted my phone more than once and then I can boot as usual, go through security code and use the phone as usual. So at the moment I will not be rebooting… Let’s see if there is a fix for this. I will be monitoring CPU usage and phone temperature.
Still can’t using Recovery Mode, but now I have normal SSH connection (192.168.2.15), but all commands like pkcon refresh/remove and version --dup only makes errors, ie:
pkcon refresh
Failed to contact PackageKit: Error calling StartServiceByName for org.freedesktop.PackageKit: Failed to activate service 'org.freedesktop.PackageKit': timed out (service_start_timeout=25000ms)
[root@Sailfish nemo]# version --dup
REFRESHING CACHE AND DOWNLOADING PACKAGES
Error: Failed to activate service 'org.freedesktop.PackageKit': timed out (service_start_timeout=25000ms)
Finished transaction (status=2, runtime=0ms)
UPGRADE NOT COMPLETE - Retry 1 of 9
Waiting 1 seconds before retry.
Same here. The packagekit.service fails to load, also on a restart attempt. The journal tells me
Sep 30 18:20:12 Sailfish packagekitd[5805]: /usr/libexec/packagekitd: error while loading shared libraries: libicui18n.so.63: cannot open shared object file: No such file or directory
When I logged in via ssh there was a similar line of output:
flatpak: error while loading shared libraries: libicui18n.so.63: cannot open shared object file: No such file or directory
I had the flatpak parts installed, but also removed since. Seems like there are some leftovers though.
In my case I found what caused the problem. When I start Pure Maps, it tries to get map tiles from OSM Scout Server, but that apparently was uninstalled due to missing libicuuc.so.63, and systemd keeps trying to start it. The journal is full of the following lines over and over:
systemd[2115]: osmscout-server.service: Main process exited, code=exited, status=203/EXEC
systemd[2115]: osmscout-server.service: Unit entered failed state.
systemd[2115]: osmscout-server.service: Failed with result 'exit-code'.
systemd[2115]: Started OSM Scout Server.
# and
systemd[23709]: osmscout-server.service: Failed at step EXEC spawning /usr/bin/harbour-osmscout-server: No such file or directory
~/.config/systemd/user/osmscout-server.service is still left, even if OSM Scout Server has been uninstalled. I will remove this service file and use some other maps until a new OSM Scout Server is available.
Thank you so much for this investigation and the post, I can confirm after removing the osmcout-server.service my phone is now “fixed”. Let me elaborate a bit, I was only using the Phonebook app that introduces overlays and have removed it before the updating after seeing the posts.
Symptoms I saw after the upgrade:
Phone doesn’t shutdown, gets stuck with red LED, only solution was vol UP + power
Jolla App store informed me that I have no apps installed - there was a critical error accessing app registry
OpenRepos was not starting at all
SSH wasn’t working
Setting changes were not applied, the default values remained
After deleting the osmscout-server.service file (via the File Browser) and restarting the phone with the VolUP+power button all of the problems seem to have gone so far (apart from OpenRepos not opening). I can even shutdown the phone properly. Therefore I have accepted your answer as a solution. Thank you for saving me from a re-flash…
I’ve also had a hard time upgrading my Xperia XA2 from 3.3.0.16 to 3.4.0.22 today. The usual update via the settings aborted, leaving the phone in an unusable state. The phone booted, but the screen stayed blank after the warning about unlocked boot loader and the SONY logo. Fortunately I had ssh access enabled and knew the password, so via devel-su I could try to fix things.
lipstick didn’t start, so that’s the reason for the blank screen.
First I had to upgrade the PackageKit packages like this:
cd /home/.pk-zypp-dist-upgrade-cache/jolla/mw/armv7hl
rpm -U Pack*
systemctl start packagekit
ssu re 3.4.0.22
version --dup
-> Error: Medium not attached: plugin:/ssu?repo=adaptation0
I copied the “ssu” file from /usr/lib/zypp/plugins/urlresolver to /usr/libexec/zypp/plugins/urlresolver.
Then I played around a long time upgrading most packages via rpm using the .rpm files in the mentioned directory. Finally, version --dup started working, even though it took a long time.
Not everything is back to normal, but at least the phone is usable again. Well, that cost me a lot of time and nerves.
storeman doesn’t work yet.
The screen blanks when I try to modify the name of a folder on the home screen, and when entering the password for ownKeepass (fortunately, the on screen keyboard remains visible and usable), and in other apps as well. This can be fixed by disabling OKboard.
My Xperia X failed during the upgrade and and only gave me the option to reboot. After reboot I had no GUI, just a blank screen.
SSH-ing into the phone I found that the packagekit service was not running, and therefore ssu re 3.4.0.22; version --dup would fail. To get the packagekit service to start I manually upgraded rpm packages through use of the local cache: [root@Sailfish home]# rpm -Uvh ./.zypp-cache/packages/jolla/mw/armv7hl/PackageKit-zypp-1.1.13+git9-1.14.4.jolla.armv7hl.rpm ./.zypp-cache/packages/jolla/mw/armv7hl/PackageKit-1.1.13+git9-1.14.4.jolla.armv7hl.rpm
Then I could start the daemon: systemctl start packagekit
And the above did the trick along with a few more rounds of ssu re 3.4.0.22; version --dup and reboots.
