I tried:
[root@Sailfish armv7hl]# rpm -Uvh ./home/.zypp-cache/packages/jolla/mw/armv7hl/PackageKit-zypp-1.1.13+git9-1.14.5.jolla.armv7hl.rpm ./home/.zypp-cache/packages/jolla/mw/armv7hl/PackageKit-1.1.13+git9-1.14.5.jolla.armv7hl.rpm
error: open of ./home/.zypp-cache/packages/jolla/mw/armv7hl/PackageKit-zypp-1.1.13+git9-1.14.5.jolla.armv7hl.rpm failed: No such file or directory
error: open of ./home/.zypp-cache/packages/jolla/mw/armv7hl/PackageKit-1.1.13+git9-1.14.5.jolla.armv7hl.rpm failed: No such file or directory
[root@Sailfish armv7hl]# rpm -Uvh /home/.zypp-cache/packages/jolla/mw/armv7hl/PackageKit-zypp-1.1.13+git9-1.14.5.jolla.armv7hl.rpm /home/.zypp-cache/packages/jolla/mw/armv7hl/PackageKit-1.1.13+git9-1.14.5.jolla.armv7hl.rpm
warning: /home/.zypp-cache/packages/jolla/mw/armv7hl/PackageKit-zypp-1.1.13+git9-1.14.5.jolla.armv7hl.rpm: Header V3 DSA/SHA1 Signature, key ID f2633ee0: NOKEY
error: Failed dependencies:
PackageKit = 1.1.9+git9-1.11.1.jolla is needed by (installed) PackageKit-glib-1.1.9+git9-1.11.1.jolla.armv7hl
No . before /home/….
Tried, no success. It says that another version is already installed or something… "
PackageKit = 1.1.9+git9-1.11.1.jolla is needed by (installed) PackageKit-glib-1.1.9+git9-1.11.1.jolla.armv7hl ". In your post the version of the two rpms is …1.14.1 but I have 1.14.5.
OK, the version numbers of the packages I listed are from the Early Access (EA) version. They might have changed in the final release, as it most likely is a newer build.
Tracking down dependencies with rpm instead of zypper/PackageKit is cumbersome, and your device’s state might be different from what mine was at the time of the error. So, it’s a tad difficult to guide you, but you need to track down the dependencies, search the cache for needed packages, and install them manually with rpm.
Where to search and how? The message say that "PackageKit = 1.1.9+git9-1.11.1.jolla is needed by (installed) PackageKit-glib-1.1.9+git9-1.11.1.jolla.armv7hl "
I have done a say release to the new version, does this make any trouble?
I’m not quite sure how to guide you from here, but after updating my X from Sailfish OS 3.4.0.22 (EA) to 3.4.0.24 (GA) just now, it has the following packages installed:
[nemo@Sailfish ~]$ rpm -qa 'PackageKit-*'
PackageKit-glib-1.1.13+git9-1.14.5.jolla.armv7hl
PackageKit-Qt5-0.9.6+git-1.5.1.jolla.armv7hl
Try to locate the rpm files with the same version numbers and rpm -Uvh them in.
(I need to catch some Zzz…)
I tried again to find any packadekit:
[root@Sailfish .dot]# find /home/ -name 'PackageKit-*'
/home/.zypp-cache/packages/jolla/mw/armv7hl/PackageKit-Qt5-0.9.6+git-1.5.1.jolla.armv7hl.rpm
/home/.pk-zypp-dist-upgrade-cache/packages/jolla/mw/armv7hl/PackageKit-Qt5-0.9.6+git-1.5.1.jolla.armv7hl.rpm
/home/.pk-zypp-dist-upgrade-cache/packages/jolla/mw/armv7hl/PackageKit-zypp-1.1.13+git9-1.14.5.jolla.armv7hl.rpm
/home/.pk-zypp-dist-upgrade-cache/packages/jolla/mw/armv7hl/PackageKit-1.1.13+git9-1.14.5.jolla.armv7hl.rpm
/home/.pk-zypp-dist-upgrade-cache/packages/jolla/mw/armv7hl/PackageKit-glib-1.1.13+git9-1.14.5.jolla.armv7hl.rpm
So the ones from your list are located in:
Then from there:
[root@Sailfish armv7hl]# rpm -Uvh Pack* warning: PackageKit-1.1.13+git9-1.14.5.jolla.armv7hl.rpm: Header V3 DSA/SHA1 Signature, key ID f2633ee0: NOKEY Preparing... ################################# [100%] package PackageKit-glib-1.1.13+git9-1.14.5.jolla.armv7hl is already installed package PackageKit-zypp-1.1.13+git9-1.14.5.jolla.armv7hl is already installed package PackageKit-1.1.13+git9-1.14.5.jolla.armv7hl is already installed package PackageKit-Qt5-0.9.6+git-1.5.1.jolla.armv7hl is already installed
Then I checked:
[root@Sailfish armv7hl]# systemctl start packagekit Job for packagekit.service failed because the control process exited with error code. See "systemctl status packagekit.service" and "journalctl -xe" for details.
[root@Sailfish armv7hl]# journalctl -xe
-- Logs begin at Wed 2020-10-14 11:54:01 EEST, end at Wed 2020-10-14 12:10:37 EEST. --
Oct 14 12:08:56 Sailfish systemd[4131]: booster-qt5.service: Failed with result 'exit-code'.
Oct 14 12:08:57 Sailfish systemd[4131]: booster-qt5.service: Service hold-off time over, scheduling re
start.
Oct 14 12:08:57 Sailfish systemd[4131]: booster-qt5.service: Start request repeated too quickly.
Oct 14 12:08:57 Sailfish systemd[4131]: booster-qt5.service: Unit entered failed state.
Oct 14 12:08:57 Sailfish systemd[4131]: booster-qt5.service: Failed with result 'start-limit'.
Oct 14 12:08:57 Sailfish systemd[4131]: Starting Application launch booster for Qt5...
-- Subject: Unit UNIT has begun start-up
-- Defined-By: systemd
-- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel
-- Unit UNIT has begun starting up.
Oct 14 12:08:57 Sailfish booster-qt5[8339]: /usr/libexec/mapplauncherd/booster-qt5: error while loadin
g shared libraries: libicui18n.so.63: cannot open shared object file: No such file or directory
Oct 14 12:08:57 Sailfish systemd[4131]: booster-qt5.service: Main process exited, code=exited, s
tatus=127/n/a
Oct 14 12:08:57 Sailfish systemd[4131]: Failed to start Application launch booster for Qt5.
-- Subject: Unit UNIT has failed
-- Unit UNIT has failed.
Ant then:
`[root@Sailfish armv7hl]# systemctl status packagekit.service
● packagekit.service - PackageKit Daemon
Loaded: loaded (/usr/lib/systemd/system/packagekit.service; static; vendor preset: enabled)
Drop-In: /usr/lib/systemd/system/packagekit.service.d
└─01-home-mount.conf, 01-prevent-start.conf
Active: failed (Result: exit-code) since Wed 2020-10-14 12:08:27 EEST; 4min 13s ago
Process: 8230 ExecStart=/usr/libexec/packagekitd $PACKAGEKIT_ARGS (code=exited, status=127)
Main PID: 8230 (code=exited, status=127)
Oct 14 12:08:27 Sailfish systemd[1]: Starting PackageKit Daemon…
Oct 14 12:08:27 Sailfish packagekitd[8230]: /usr/libexec/packagekitd: error while loading shared…ory
Oct 14 12:08:27 Sailfish systemd[1]: packagekit.service: Main process exited, code=exited, stat…/n/a
Oct 14 12:08:27 Sailfish systemd[1]: Failed to start PackageKit Daemon.
Oct 14 12:08:27 Sailfish systemd[1]: packagekit.service: Unit entered failed state.
Oct 14 12:08:27 Sailfish systemd[1]: packagekit.service: Failed with result ‘exit-code’.
Hint: Some lines were ellipsized, use -l to show in full.
