Today I walked a few kilometers with my Jolla 2026 in my pocket. When I took it out it was “permanently locked” due to “too many attempts” at unlocking it. A couple days ago I set the max number of attempts to 5, without considering the accidents the double-tap-wake-up feature would cause in my pocket.
Anyway, I am seeing a number of posts from people with the same issue, but on an Xperia or a C2, not a Jolla 2026. I am trying to access Recovery Mode by holding Vol Up and then pressing and holding the Power button, but that just initiates a normal startup. Does anyone know if there actually exists a Recovery Mode on the Jolla 2026 and how to access it? Or how to release the phone from the permanent lock? A factory reset would also be fine. Thanks.
That helped, thank you. The key bit was this: “When starting JP26, when the Jolla logo appears, hold the volume up button.” (I was trying by holding the two buttons simultaneously, but the sequence matters.)
I was able to enter Recovery Mode and to release my Jolla from the “permanent lock” as explained here: Recovery Mode | Sailfish OS Documentation . Thanks!
Last weekend I was at a party and I had the same issue. Phone (Jolla 2026) was permanently locked due to movement in my pocket. Pretty nasty as my eletric bike only works when phone is on (bluetooth), so I couldn’t go home or reach anyone. The day after I recovered the phone via the recovery shell. To prevent this in the future I increased the number of attempts and disabled the ‘double tap to wake‘ function via the Developer mode/Terminal.
How to disable Double Tap to Wake on the Jolla 2026
Go to Settings → Developer tools.
Enable Developer mode.
Open the Terminal app.
Enter devel-su and provide your developer password to gain root access.
Install the required tool: pkcon install mce-tools
Disable Double Tap to Wake: mcetool --set-doubletap-mode=disabled
Test: Lock your phone and double-tap the screen. It should remain black. You can still wake the phone using the side power button or your registered fingerprint.
Finally: Disable Remote connection (if enabled) and Developer mode when you’re finished.
There is something to be said for the phone reacting too easily to touches. Almost 50% of the time when I take it out of my pocket, the screen is on and it’s suddenly inside some application that was running (as a cover), or it’s on a different ambience (not the TOH ambience, which might be caused by a different bug).
