Pdx225 or XQ-CC54
Hello,
Cant flash my xperia 10 iv because in flash-config product name is XQ-CC54 but when flashing device says his name is pdx225. Anybody can help ? Thank you !
Flash utility v1.2
Detected Linux
Searching device to flash..
PRODUCT_RAW=[pdx225]
Found pdx225, serial:HQ62621EE3, baseband:, bootloader:xboot
COMPARE: [pdx225] vs [XQ-CC54]
No valid devices found.
did you try this? Fastboot flashing of Xperia 10 IV and 10 V
Thank you, I must try this. Do you think I should first
fastboot --disable-verity --disable-verification flash vbmeta vbmeta.img ?
Solved, thank you very much !
