Patches by nephros
I created/maintain a handful of patches on both the Patchmanager Web Catalog [1] and partially as RPMs on Openrepos [2].
This thread shall serve as a discussion/support thread for those, and especially please report issues you may have as I don’t always update to the newest SFOS versions.
Here’s an (possibly incomplete] list, see [1] for the definitive version:
  • Glass Popups
  • Custom SIM Names
  • Email Account in Folder header
  • Finer Volume Control
  • Dimmed Launcher Icons
  • Glass Handles
  • Improved App Chooser
  • Quickddit: Accounts on top of Settings
  • Return old button style 4.x
  • Topmenu Favorite Ambiences Only
  • Fuzzy Time
  • Restart BT in SF Utilities
  • Remove cross icon from remorse timer [3.3]
[1] Web Catalog: nephros projects
[2] Fuzzy Time: Patch: Fuzzy Time | OpenRepos.net — Community Repository System
old button style fails for me:
PM APPLY Sat Oct  9 13:49:09 CEST 2021
return-old-pulley-menu-iv
  contains text patch
Test if already applied patch
can't find file to patch at input line 3
Perhaps you used the wrong -p or --strip option?
The text leading up to this was:
|--- /usr/lib/qt5/qml/Sailfish/Silica/ContextMenu.qml
|+++ /usr/lib/qt5/qml/Sailfish/Silica/ContextMenu.qml
File to patch:
Skip this patch? [y]
Skipping patch.
1 out of 1 hunk ignored
The next patch, when reversed, would delete the file usr/lib/qt5/qml/Sailfish/Silica/ContextMenu.qml.orig,
which does not exist!  Ignore -R? [n]
Apply anyway? [n]
Skipping patch.
can't find file to patch at input line 480
|--- /usr/lib/qt5/qml/Sailfish/Silica/HighlightBar.qml
|+++ /usr/lib/qt5/qml/Sailfish/Silica/HighlightBar.qml
File to patch:
Skipping patch.
3 out of 3 hunks ignored
The next patch, when reversed, would delete the file usr/lib/qt5/qml/Sailfish/Silica/HighlightBar.qml.orig,
Apply anyway? [n]
Skipping patch.
can't find file to patch at input line 665
|--- /usr/lib/qt5/qml/Sailfish/Silica/PullDownMenu.qml
|+++ /usr/lib/qt5/qml/Sailfish/Silica/PullDownMenu.qml
File to patch:
Skipping patch.
2 out of 2 hunks ignored
The next patch, when reversed, would delete the file usr/lib/qt5/qml/Sailfish/Silica/PullDownMenu.qml.orig,
Apply anyway? [n]
Skipping patch.
can't find file to patch at input line 905
|--- /usr/lib/qt5/qml/Sailfish/Silica/PushUpMenu.qml
|+++ /usr/lib/qt5/qml/Sailfish/Silica/PushUpMenu.qml
File to patch:
Skipping patch.
The next patch, when reversed, would delete the file usr/lib/qt5/qml/Sailfish/Silica/PushUpMenu.qml.orig,
Apply anyway? [n]
Skipping patch.
can't find file to patch at input line 1108
|--- /usr/lib/qt5/qml/Sailfish/Silica/private/PulleyMenuBase.qml
|+++ /usr/lib/qt5/qml/Sailfish/Silica/private/PulleyMenuBase.qml
File to patch:
Skipping patch.
The next patch, when reversed, would delete the file usr/lib/qt5/qml/Sailfish/Silica/private/PulleyMenuBase.qml.orig,
Apply anyway? [n]
Skipping patch.
Dry running patch
File to patch:
Skipping patch.
checking file usr/lib/qt5/qml/Sailfish/Silica/ContextMenu.qml.orig
File to patch:
Skipping patch.
checking file usr/lib/qt5/qml/Sailfish/Silica/HighlightBar.qml.orig
File to patch:
Skipping patch.
checking file usr/lib/qt5/qml/Sailfish/Silica/PullDownMenu.qml.orig
File to patch:
Skipping patch.
checking file usr/lib/qt5/qml/Sailfish/Silica/PushUpMenu.qml.orig
File to patch:
Skipping patch.
checking file usr/lib/qt5/qml/Sailfish/Silica/private/PulleyMenuBase.qml.orig
*** FAILED ***
Return old button style 4.x works for me on 4.2.
I think you meant old pulley menu?
Yes, sorry. Of course I meant old pulley
Is that a 64bit (xperia x10Ii) system?
Because there’s a general problem about library path with 64bit systens.
Yes exactly, its on a X10ii.
Alright, the underlying problem is that on x86 and arm, 32bit systems, many things that are manipulated by patches are located in /usr/lib while in aarch64 (which the X10ii uses) in /usr/lib64.
No big deal, except patches written for one platform will not apply on the other because patch can’t find the files, even though they will be exactly the same.
For any patch that doesn’t apply for this reason, you will have to edit the patch file and find all lines that look like this:
--- /usr/lib/qt5/qml/Sailfish/Silica/...
+++ /usr/lib/qt5/qml/Sailfish/Silica/...
and replace the /usr/lib by /usr/lib64.
Then it should apply.
I have decided against distributing a separate patch for 64bits, for one it’s useless duplication and generates more maintenance work, and also we’re looking into a general solution over at Patchmanager’s Issue #71 .
Thanks for the effort. The solution via patchmanager is definitely better than quirking around with each patch.
Added Email Plaintext view
Hello nephros - could you make in the future a patch mix with Sandbox Indicator and Always show close icon in app-switcher please? I cannot activate both and I love the always show close icons. What I also missed is the patch Notifications count in Switcher. I will try also to build a patch for all tree, but I’m afraid I don’t have enough experience with this.
Thanks for the suggestion!
I can try though to be frank in the coming days or couple of weeks I will probably not find the time.
Thanks! I really missed this and really hate html mail.
Just to note here that this issue was resolved with version 3.2? of patch manager. I had to check https://github.com/sailfishos-patches/patchmanager/pull/109
Please try: Project: patch-sandbox-indicator-combined
relatively untested - this needs Ancelad’s patch activated and goes on top.
Thanks you are faster like me. It works. for me.
Here are a screenshot for the patch description.
Just replying to bump this, and:
I don’t actively use all of my patches myself. I have updated the compatability with 4.4.x on Web Catalog for those I was able to test.
If you have tried one of my patches and found that it’s working with 4.4, but it is not marked compatible please notify me here.
NB: compatibility does not update if youhave already installed the patch. For the information to update you have to re-install from Web Catalog.
By popular demand (i.e. two people asked about it :D), I have added Powerdrain on Statusbar to the Web Catalog.
I had forgotten this thread! Yeah, patches by @nephros! Could go live on a gaming site! Powerdrain! at Twenty to Two! Or One Forty where I come from :slight_smile:
Thanks!
Maybe offtopic, but out of curiosity what’s that droid icon?
Does it indicate ‘Android support on/running’?
