Customizable CoverAction-Buttons (incl. selectable icons) via Settings
Customizable CoverPage (display of max. 2 item states) via Settings
Notifications when a CoverAction or NFC command fails
NFC Tag support: Write item commands or sitemap pages to NFC tags and trigger them by laying the tag on your phone - compatible with tags written by the openHAB Android app (NFC Forum Type 2 tags like NTAG21x; Type 5 tags like ICODE SLIX are not supported by Sailfish OS)
Technical Information
QT-Version 5.6.3
Tested on Sailfish OS 5.0.0.62
Planned features
Add support for remote access (via openHAB cloud)
Add App Notifications (via openHAB cloud)
Add support for openHAB tiles (HABPanel, Basic UI, etc.)
Add support for widget-confirm-button via Sitemap
Show Item History (context menu on item in sitemap)
Bugs and Feature Requests
Please report bugs or suggest features via OpenHAB Community Forum or GitHub Issues:
Jolla AppStore (Harbour) - in progress, already submitted 15 days ago
While this first version doesn’t yet include all the features of the iOS or Android apps, we will be working hard over the coming months to achieve feature parity.
Current Features
Demo Mode: Explore the app without connecting to an openHAB server
Display your Main UI Webview
Display your sitemaps and widgets and control your devices from your mobile device
Supported widgets/element-types within sitemap: Frame, Text, Group, Switch, Switches with Button-Mappings, Selections, Slider, Rollershutter
Customizable CoverActions via Settings
QT-Version 5.6.3
Planned features
Add optional authentication for local servers
Enhance supported widgets/element-types
Management of translations via CrowdIn
Check out the release notes for a full list of changes. If you would like to contribute, please send me a PM.
A note to the developers:
As I am relatively new to QML development, I would appreciate it if someone more experienced could review the code. Any ideas, suggestions, or contributions are very welcome! Feel free to send me a PM.
We already found some bugs and fixed them with version 0.2 with help of @davodego . So every new tester which can find some bugs is welcome.
I’d also like to mention that another native app, Openhabitus has been available since 2023. I am trying to reach out to its developer to see if we can merge our efforts and code.
For the First Versions I tried to Stick to iOS Features of Openhab because Im Personally coming from there - i think I have heared the Feature from Android App? Can you explain the usecase a Little Bit more in Detail?
(Dont know if You Are familiar with coding, but i would love to have someone Else onboard which can develop the App with me together Further, as this is also a Community project )
Hi! Yes, the NFC feature is currently in the Android App only. My usecase is physical access control: I use a combination of NFC cards plus PIN numbers to allow members of a group to unlock doors / lockers within a shared space. So members can use the Openhab app to scan their NFC card (eliminating the need to put Zigbee/Wifi NFC scanners everywhere) and then enter their PIN via the app to unlock things they’re supposed to have access to. I hope that makes sense!
And sorry, I’m not very knowledgeable about coding at all… Setting up the rules and scripts in Openhab is about as far as I’m able to go - I doubt I would be much help with app development.
Oh, I’d be more than happy to help with testing or debugging, yeah! I can send you my discord or telegram alias if you’d like a more direct way of communicating for that purpose.
Changelog:
- ADDED: NFC Tag support (write and read NFC tags to trigger openHAB actions)
- CHANGED: Redesign of Coverpage provided by @ZeiP
- FIX: Nested sitemaps work correctly provided by @ZeiP
- ADDED: Icons for the cover quick actions are selectable by the user provided by @ZeiP
- ADDED: Notification error message when quick action fails to execute provided by @ZeiP
- ADDED: Notification manager implementation
- ADDED: Centralized OpenHabApi service to handle API calls centrally.
- FIX: Added missing runtime Requires
You can get it on openrepos.net – on harbour the status is QA
Deleting the values and resetting does not solve it. The cover page remains empty.
In addition, the Home page remains empty too on the way back from the settings. I need to select Home via the Burger Menu again, then it displays the page’s values.
It was my mistake that the cover page remained empty; the items were not named correctly. The items are now correctly named and the homepage is now refilled on the way back from the settings.
