Sorry @attah , I just clarified your last question – more like if there’s interest towards Sailfish Maps. And all location related low-level components have been already open sourced long time back.
My bet is that there is no need for Sailfish Maps per se – that could be there as well. A-GPS is the thing that we’re all wanting.
I think the better design compared to a dedicated collector app would be a daemon which does the collecting and submitting in the background, and UI to enable/disable that.
IIRC one of the involved backends (was it GeoClue (2?!!)) has a plugin which already does that. This could be adapted (backported) for SFOS.
This IMO allows for tighter coupling between the collector, and ofono, connman, than an app could.
If you have the rights, then please do it. I always thought the reason for getting rid of the Maps was contract ending between Jolla and Appello, and them holding copyrights to some key parts, preventing you from moving on with it by yourself.
@rainemak out of curiosity, is there any reason why all of the native apps couldn’t be open sourced? Email, calendar, camera, gallery, clock, calculator, media, notes etc?
We have pure maps i don’t see a need for sailfish maps. Maybe jolla can adopt it and make any changes necessary to polish it or whatever but all in all its a great app.
What helps with GPS lock is regularly downloading the ephemeris from a server when a data connection is available (e.g. once a day), so that it is immediately available when the GPS starts up.
Skyhook or BeaconDB does not generally help with getting a GPS lock. It is a red herring, and should be a far lower priority for effort than making the SF GPS work properly and the A-GPS work reliably.
Even though BeaconDB is not a replacement for SUPL, it still should be able to inject ephemeris data so definitely worth including into next SFOS update. Moreover, based on geoclue change log:
*2.8.0
New features:
Add URL and API key for the Positon location service to default config comments
Include the SSID in queries to the Ichnaea server to support BeaconDB
Set User-Agent in web source queries and add OS info to it
Allow disabling WiFi source and static source during compilation
Show default Wifi URLs set on compile time in default config comments
Add BeaconDB URLs to to default config comments
Add a separate GeoIP location source:
Add an ‘ip’ config section with selectable backend methods: ichnaea, gmaps and reallyfreegeoip
Allow overriding URL and accuracy in ip methods with values from config
Use BeaconDB as the backup GeoIP URL, if URLs are not defined in ip or web source configs
Remove the GeoIP functionality from the web source, it now only handles queries with Wifi and 3G data
Install sysusers.d file for the geoclue user
Use BeaconDB as the compiled-in default server for locate and submit queries in the web source*
.. BeaconDB is already integrated into recent release, so hopefully it will not consume too much efforts from SFOS devs to upgrade geoclue.
Oh no, GPL3 again… I wish Jolla focused on paid ports / clouds / additional services and just open-sourced everything. Current situation is just continuous decaying long-term…
Geoclue2 is quite a different thing than the older geoclue and it has architecture which doesn’t fit our needs. So backporting is unlikely possible, but we have anyway our own MLS provider which is switching to beacondb by default. And we’re unlikely to move to geoclue2 not even considering licensing or resources.
We’ll try to write separate announcements from upcoming apps / components. As we write them, we probably have other tips aside. Let’s focus Notes app related comments to the Notes topic, thanks.
