Old roaming bug still around?
BUILD ID = OS VERSION (Settings > About product): 4.1.0.24
HARDWARE (XA2, X10, X10 II, …): XA2
UI LANGUAGE: ENG
https://together.jolla.com/question/198960/bug-did-the-roaming-bug-return/
I had this bug before, went abroad and see that it’s back (or has always been around?).
Mobile Data switches constantly between ‘Enabled’ and ‘Connecting’. Have set all the connection settings manually, and also tried default. Have tried the usual trouble shooting and also installed Ofono log, according to the zendesk article.
https://jolla.zendesk.com/hc/en-us/articles/115011240387-Fixing-the-settings-of-mobile-data
https://jolla.zendesk.com/hc/en-us/articles/115011870727
Any tips or help very much appreciated, annoying with no data.
Had the same problem recently (also XA2), found this thread and will try the tips the next time when I go abroad. (if it is not fixed yet by the upcoming update.
