Anyone noticed this problem getting worst with 4.4?
more or less the same i’d say
very rare since 4.4. But then it seems the trigger is when the device get out of known wlan-infrastructure and its switching to mobile internet and vice versa.
And it seems to occur after a reboot. When restart the process, it doesn´t seem to happen again.
I’m not sure what ofonod is, maybe I’m seeing something completely different, but I see the sudden battery drain sometimes, which seems to happen in the neighborhood of using wlan, bt and possibly change of mobile network (when traveling, for instance). I’m far from certain and I haven’t been able to pinpoint what it is, or even reproduce it in a predictable way, but I’ve experienced it since a couple of years. And the only thing I’m (rather) certain of, is that if I don’t activate bt, especially in conjunction to using wlan, Internet traffic or hotspotting, it never seems to happen - the battery drain is normal; what to expect. As said, I’m not sure if I’m speaking of the same thing here, but I’ll just delete this post if it’s irrelevant
When you experience those drains open a terminal and type top. I bet you will see offonod on top.
I too had ofono taking 100% of a cpu core this morning. Mobile was in flight mode, with wifi enabled. Don’t know when it got triggered. Restarting ofono fixed it. However, as another data point or noise: I noticed sensorfwd taking a few percent CPU time, more than normal (and more than fingerterm). That I’ve seen before. Restarting sensorfwd fixed that as well, but I noticed it took a while. journalctl showed that the restart command failed, and that the process was SIGKILLed after a 15 seconds.
I had had the impression that it was related to that as well, so as a test I’ve stuck to 4g for a while and kept wifi completely turned off.
This morning I saw ofonod was at it again, eating battery like a hungry hippo. I think it must have happened when I switched off flight mode in the morning. It was fixed by restarting ofonod.service as usual.
Lately i feel like i’ve been “fighting” with ofono more than i use the phone itself. ![]()
I am this
close to going on a rant. ![]()
Never had the problem myself, but wouldn’t it be better to first collect some evidence?
If you have gdb installed,
# gdb -p `pidof ofonod`
(gdb) generate-core-file
will dump a core file containing a lot of possibly useful information. Another option is to attach strace, e.g.:
# strace -f -p `pidof ofonod`
This will show either almost nothing (i.e. ofono or at least one thread hangs in some computation) or the deamon’s interaction with the kernel.
Well, that was a good idea. It seems ofonod starts its CPU munching when a file descriptor is closed and it just keeps trying to read from it:
[pid 30013] poll([{fd=3, events=POLLIN}, {fd=4, events=POLLIN}, {fd=6, events=POLLIN}, {fd=7, events=POLLIN}, {fd=11, events=POLLIN}, {fd=22, events=0}], 6, 2240) = 1 ([{fd=22, revents=POLLNVAL}])
[pid 30013] clock_gettime(CLOCK_MONOTONIC, {tv_sec=193881, tv_nsec=760733526}) = 0
[pid 30013] clock_gettime(CLOCK_MONOTONIC, {tv_sec=193881, tv_nsec=760828622}) = 0
These lines repeat over and over very, very quickly. epoll tells us that the file descriptor is invalid and indeed, when one checks the file descriptors for the running process:
nemo@Sailfish ~ [1]> sudo ls -l /proc/(pidof ofonod)/fd
total 0
lr-x------ 1 root root 64 May 5 22:00 0 -> /dev/null
lrwx------ 1 root root 64 May 5 22:00 1 -> socket:[11282575]
l-wx------ 1 root root 64 May 5 22:00 10 -> pipe:[11281456]
lrwx------ 1 root root 64 May 5 22:00 11 -> socket:[11283459]
lrwx------ 1 root root 64 May 5 22:00 12 -> anon_inode:[eventfd]
lrwx------ 1 root root 64 May 5 22:00 13 -> socket:[11261401]
lrwx------ 1 root root 64 May 5 22:00 14 -> anon_inode:[eventfd]
lrwx------ 1 root root 64 May 5 22:00 15 -> /dev/hwbinder
lr-x------ 1 root root 64 May 5 22:00 16 -> pipe:[11281467]
l-wx------ 1 root root 64 May 5 22:00 17 -> pipe:[11281467]
l-wx------ 1 root root 64 May 5 22:00 2 -> /dev/null
lrwx------ 1 root root 64 May 5 22:00 3 -> anon_inode:[eventfd]
lrwx------ 1 root root 64 May 5 22:00 4 -> anon_inode:[signalfd]
lrwx------ 1 root root 64 May 5 22:00 5 -> socket:[11261388]
lrwx------ 1 root root 64 May 5 22:00 6 -> socket:[11261389]
lr-x------ 1 root root 64 May 5 22:00 7 -> anon_inode:inotify
lrwx------ 1 root root 64 May 5 22:00 8 -> /dev/hwpuddlejumper
lr-x------ 1 root root 64 May 5 22:00 9 -> pipe:[11281456]
After restarting ofonod, the open file descriptors look quite similar. The socket and pipe ids are different, of course, but the number of open sockets is the same, and they are of the same type. I don’t see any socket that wasn’t there before restarting ofonod.
@flypig (or anyone else from jolla) can you tell us if there is a bug in the internal bugtracker for this issue??
Thanks for asking @ApB. I just checked now and I don’t see any open bugs related to ofono power consumption, and I don’t see any internal reports that directly reference this thread.
It doesn’t follow there aren’t bugs about this issue I’m afraid since we only have symptoms here; you’d need someone with a better understanding of ofono (e.g. @slava) to check.
Maybe it’s also worth going through the upstream changes to see if there’s anything related there. I skimmed through them, as well as our Sailfish-specific changes, but didn’t see anything obvious. Again, with my level of understanding it’s quite possible I missed something though.
We now have an internal bug report covering this, so I’ve tagged it as “tracked”.
Can someone test the below in case it triggers it for them also.
Use bluetooth earphones and listen to music through the default media player.
Close the media player.
The BT icon (on top) will disappear and reappear again
Check top for cpu usage.
Yes, it does same for me (10iii). After stopping media player ‘top’ shows ofonod using ~12% cpu. Tried couple of times with media player, always happened. Native browser+youtube or ‘nettiradio’ did not cause any problems.
During last night (6 hours) battery dropped from 70% to 9%, And ofonod was using that ~12% cpu, Phone was noticeably warm compared to XA2 beside it, so it has been clearly doing something.
Deadbeef-Player seems not to be affected by this fault. Since i use it instead of Mediaplayer, the ofonod-cpu-eating seems to be gone.
Thanks for the test people. It might not be the only way of making it guzzle the CPU but at least we know of one way and its reproducible.
@piggz put it in the internal bug tracker if you please.
I found another way to reliably reproduce this on X10III (edit: I did these steps three times with ofono restart in between, happened every time):
- Turn on Bluetooth headset
- The headset auto-connects to the phone
- Listen to some music (I used Nettiradio)
- Stop the music (I used the app cover)
- Go to Bluetooth settings
- Click the device name to disconnect it
- Ofono starts to consume one CPU core
No wonder I ran into this daily with my new headphones which I use daily: At work I disconnect if from the phone and use the PC to establish the connection - battery drainage every day…
One thing worth noting is that restarting telephony using Sailfish Utilities does not help, only restarting ofono systemd service.
PS. I use ToeTerm, and I created a quick command for restarting ofono (sans password), it’s been quite handy actually.
All we have to do now is wait for a fix. We can reliably reproduce it.
Hope it comes soon.
Interestingly it happens only when actively disconnecting the headset.
I used my Bose Quiet Comfort earbuds many times without any issues, but I rarely disconnected them. There’s no problem when I just shut them down by putting back in their case. Also when I just disable BT completely.
Thanks for finding out.
