Is there a way I can mount the Luks encrypted SD-Card automatically after reboot?
I was reading about fstab but not sure if this applies also to luks partitions on a cellphone.
Definitely not fstab, and using systemd’s crypt services may not be the answer either as Sailfish expects it to be mounted by the user via udisks2.
I couldn’t find an easy way myself, but happy to try again if anybody has a good strategy.
@olf made a package for this, but unfortunately it doesn’t work on sfos 4.2
For more info:
https://openrepos.net/node/10496
Changes in SailfishOS 4 broke crypto-sdcard in (at least) three ways. Two breakages have been fixed, for the third one I have an idea what could be the cause.
But In became tired of this, because there seem to be only about 5 users of crypto-sdcard and such breakages are regularly happening lately with new SailfishOS releases (that was not the case with SailfishOS 2.x and early 3.x releases).
As long as I see no incentive to upgrade my “production-phone” to SailfishOS 4.x (there are too many things broken for me), I rather care about things which are more fun (e.g., Patchmanager).
But I can assure you, that crypto-sdcard is (still) designed correctly (i.e., there is no easier, proper way of achieving this, even though it may seem complicated on first sight) and I am sure willing to review and integrate contributions.
BTW, years ago Jolla stated they have auto-mounting encrypted (partitions on) SD-card on their ToDo list and to me the manual mounting was only an intermediate step to achieve this (IMO manual mounting is useless), but … it is Jolla.
They also have the ability to use their mechanisms to unlock and mount the encrypted home partition using a user-supplied passphrase (which is a proper solution); but this code is proprietary, so crypto-sdcard cannot use these mechanisms. Only with a self-compiled SailfishOS (i.e., a “community port”) one can change these things for the better by completely re-designing and re-writing this functionality, as rinigus did.
So either wait for Jolla to provide a solution or contribute a fix for crypto-sdcard on SailfishOS 4.
Only 5 downloads? I propose a name change for crypto-sdcard | OpenRepos.net — Community Repository System into SDCard LUKS Automounter or similar as through online search I never found the tool.
I wish I could help fix the issue but I lack some knowledge. What I could do is make a donation to your favourite charity in your name when you complete the new release
Only 5 downloads?
No, this is not what I wrote. Please read more thoroughly. BTW, it has a few hundred downloads.
Please improve your skills using common internet search machines, then: For the search terms “sailfish os sd card encryption” and similar ones, it is always among the first five hits.
Well, one’s knowledge is something one can improve by learning and doing. ![]()
But In became tired of this, […]
So either wait for Jolla to provide a solution or contribute a fix for crypto-sdcard on SailfishOS 4.What I could do is make a donation to your favourite charity in your name when you complete the new release
LOL. ![]()
I have a systemd unit to do this if you’re interested. It’s DIY though and used on SFOS 4.1.
ThenI would be the 6th user. But unfortunately for this case, I am on SFOS 4.4.0.64.
I am tinkering an entire /home auto-backup thing on an encrypted uSD card.
So what’s the best way now to auto-mount an encrypted uSD at boot now?
A system service launching a terminal who asks for a password?
Just a notification to remind the user doing it manually?
“show me what you gooot”
a systemd-userunit triggering cryptsetup with a keyfile from within an encrypted user-home plus a triggred sudo-cmd to remount the sd would be sufficient, i guess
I sidestepped udev completely and created a semi-flexible solution involving two systemd services:
To whom it may concern.
