BUILD ID = OS VERSION (Settings > About product): 4.3.0.12
HARDWARE (XA2, X10, X10 II, …): XA2 Ultra Dual SIM
UI LANGUAGE: Polish
Missed call LED notification is shown only once. Then, as long as the missed call entry remains in the communications history in the Phone app, on following missed calls there is no LED notification whatsoever. It takes clearing missed calls from the communications history to get a missed call LED notification on next missed call. And again, only once.
- Get a missed call - LED notification (green by default) blinks.
- Interact with the device so that the LED turns off.
- Get another missed call - no LED notification.
- Delete missed call from the History tab in Phone app - only then you’ll get LED notification on next missed call.
LED notification about every missed call.
No LED notification until missed call is deleted from communications history.
A further issue is that there is also no LED notification if the incoming call takes place when the display is on. Even if the display then turns off, there’s no LED notification.
