Low volume on Bluetooth headphones? Try this
So Bluetooth volume control is a bit of a compound matter, and the device volume control doesn’t always (ever?) seem to want to talk to the peripheral. So this means you’re stuck with whatever the headphones shipped with or that the last other device set.
After i a bit of experimentation, i figured out how to change headphone-internal volume from my device.
(This should really be automated/appified, but i’m too lazy now)
Step 0
Be connected (obviously)
Step 1 find the mac address of the thing you want to configure
bluetoothctl devices
Step 2 call the VolumeUp method (repeatedly), after having substituted in the mac address to the command
dbus-send --print-reply --system --dest=org.bluez /org/bluez/hci0/dev_AA_BB_CC_DD_EE_FF org.bluez.MediaControl1.VolumeUp
I made some kind of a working Draft for a control App for this. It is called harbour-btvol (Show sailfishos:chum / harbour-btvol - SailfishOS Open Build Service) and can be installed from CHUM. It has it little Bugs and Issues (does not list current volume level, list of devices is not filtered nicely, no Icon, i wanted to get the BT battery level as well but does not work yet, etc.) and moste of the code is “stolen” from @piggz amazfish connection dialog - so credits to him. :stuck_out_tongue_winking_eye:
Nevertheless, if you accidentally or while connected to another device reduced your BT devices “internal” volume you can now check out this GUI to increase it again.
Also @attah’s dbus command up there I use (credits to him!) is listed as deprecated. So I don’t know if it will work forever :stuck_out_tongue_winking_eye:
Btw: This is not more then a Workaround, the feature needs to be in SFOS. And probably it is all controllable by pulseaudio or something like that…
Neither of them work for me on WE small speaker and Jabra headphones.
Error msg is something like this: Method “VolumeUp” with signature “” on interface “org.bluez.MediaControl” doesn’t exist
Any ideas?
EDIT: Xperia 10 with 4.4.0.64
For me
pactl set-sink-volume 3 200%
(or 150% or whatever or 100% to go back to the original volume) works just fine as Bluetooth appears to be always using sink 3 in my case.
One can check which sink no. to use (while the audio is playing) with
pactl list sinks short
If I find the time and a API interface for pactl probably I could check to build that option in the GUI as well. Let’s see!
For some time I’ve been thinking about making such simple app for my own needs to boost various volumes as not only Bluetooth but also the loudspeaker volume is that sh**ty, and I’ll probably simply use QProcess to execute the command. In the GUI there will be just a dropdown to select the sink/device and a slider for the desired volume.
Good Idea, we could also extend that in https://github.com/fridlmue/harbour-btvol.
I’ll not be able to do and check much until next week, but if you want to have a look and add something, feel free! :wink:
Thanks! That worked. In my test case it was sink 12.
But wouldn’t that reduce the resolution, and even clip the waveform?
Or where do you get the dynamic range to get away with doing that? (And why don’t we already have it?)
If you indeed have this version problem and not a different one, it sounds like the wrong solution.
What happened to bluetoothctl in 4.4.0.68?
It probably does. But acceptably small with low boosts.
[quote=“attah, post:9, topic:11488”]
Because I didn’t make it yet :slight_smile:
Oh, forget it, I didn’t have bluez5-tools installed on that unit.
Let’s see if I manage to pair it with my car from the command line, as all attempts to do it via the UI have failed.
@fridlmue, once again thanks for creating this utility when i was too lazy.
I was trying the AAS Bluetooth support - and it broke this functionality by adapter no longer being hci0.
So here is a fix that at least works for me: Use Ubi instead of split-joined address and assumed adapter by attah · Pull Request #9 · fridlmue/harbour-btvol · GitHub
Hey attah,
thank for checking that out and creating the PR! I’ll not have time to review the commit before the weekend as im on travel, but hope to not forgett to do so on the weekend. :smiling_face: Thanks again!
Update: Your Change is merged and released as V1.3.0 to CHUM.
There seems to be no more bluetoothctl on the new Jolla 2026. I never had BT headphones before but my new Bose in ears are ok for phone calls but miss the punch they have got with Android under SFOS. Bluez seems not to be there afaik.
Do you have an idea how to handle this?
Install the app above, or bluez5-tools which provides bluetoothctl. Also note the adapter name change with AAS BT.
I tried btvol and it listed my device but the first click stopped the sound although the device kept paired.
Restarting Bluetooth, audio and the media player helped after I lost the device totally and could not even pair it to Android devices anymore, which is for sure due to the proprietary bullshit these devices a built on instead of being a bloody bt headset.
Sadly after finally reconnecting after some reboots volume was back to normal.
Due to the excellent ANC of the Boses I can live with the low volume. I did not try the dbus command which should work until the next reboot. I will as soon as I need more volume.
Thank you very much, @attah.
(I miss the times when one just edited /etc/bluetoothd/devices/headset/volume.conf or something along that line in vi…)
Glad I found this. Worked perfectly on my JP26. It shouldn’t need an app to do this though, if you have a bluetooth audio device connected the volume buttons should control it.
I just got the Galaxy Buds3, and the volume is really low. Same thing happened with my wireless headphones, BTVol is able to fix that one.
When I tried with the galaxy buds, the volume actually went way down and the earbuds indicate they’re on max volume. I do hear the actual volume changing up and down through BTVol when I turn the system volume way up. After a reconnect the volume is still way lower than it was on initial pairing.
My first thought was that this is on the system side, but I don’t know enough about the bluetooth stack to actually verify this. Can anyone help?
Edit:
pactl reports the volume of sink 3 is at 100%
