Cellmon was written to try and help diagnose this issue.
See if cellmon gives you any clues
I noticed that Cellmon does not update when it loses the network, for long or short periods.
i.e. it appears that the software stack (OFONO) stops responding/returning callbacks when the signal drops out.
It should be responding and telling you that the status is unconnected, or that the signal is zero etc. Instead the values just don’t change, and no callbacks happen.
This tells me that there is a bug in OFONO. It may not be the root cause, but even if the root cause is (say) in the cellular modem, OFONO should still be responding to dbus, and returning callbacks.
I also noticed that signal often drops dramatically at the moment when it has changed 3G<->4G. Then after a little while the strength climbs up. If signal was weakish (e.g 30%) then immediately after the change it might be 10%, then climb back up again.
However that drop seems to make the signal drop out sometimes, and then OFONO stops responding.
I’m starting to have problems with this as well: the phone silently looses all contact with the network, but indicates no problem whatsoever. It’s not until I try to make a call myself, that I realize I’ve been disconnected (sometimes the whole day). Though BT and WiFi still might work, the phone should indicate that it has lost all cellular network contact. I’m on a 4,5 year old Xperia X with 4.3.
It reminds me the GPS issue (which is not yet found out if SW and/or HW).
Antenna contacts are fragile and IMHO not really durable if one intends to carry the phone in the pocket.
They get smashed and dirty. Contact may become bad.
If the cell antenna is on the same board as the GPS antenna, this could be a reason.
Try to open, clean and fix. I’d be curious if someone else can confirm.
I have this same problem in my nokia x20 running android. Where I work there is basically no signal, and every time when I get to my car and signal is great it is still hibernating in no connection mode. Once I didn’t check the phone and it was still not connected the next morning. For that problem, flight mode switch doesn’t work - only "use sim card “off - on”. But that is probably irrelevant - just wanted to say that hey it’s not only sailfish issue.
Same with a very weak reception quality on my N900 years ago.
Cleaning the contacts between the motherboard and the antennas solved it.
Again, these reports don’t exclude SW issues but bring perspectives.
(Xperia 10 II) I have the same issue since I started with the suomenlina version, still have it in the latest update (Vanha Rauma version). When are they going to fix this? I am in places where everybody using the same carrier has a strong signal and my phone is just dead for phone calls and sms. I know WiFi is important, but I still need my phone for calls and texts. Unacceptable.
