[localisation] Translation strings for the Sailfish OS release 5.0.0
That would be cool, I don’t mind having a look at all the Spanish and try to complete things up :slight_smile:
Excellent! If you want to add me as second for Spanish Spain I’m happy to help as well, slightly different but should be good enough to support both.
希望有各位大佬推进中文翻译谢谢,I hope someone can complete the translation of the Chinese language, thank you!누군가 중국어 번역을 완료할 수 있기를 바랍니다, 감사합니다!誰か中国語の翻訳を完成してくれることを願っています、ありがとう!
better late than never, sorry i’ve been busy.
Just finished reviewing the French translations, thanks @pherjung for doing most of the work! :slight_smile:
Couple of new strings were added in jolla-settings-system for the home screen orientation setting. And one new ambience in sailfish-content-ambiences-default.
Can you give a hint which kind of “Flare” that is? There are several meanings in English, and also in other languages.
Or do we just leave Ambience names untranslated/same translation?
I would suggest… do not translate if your uncertain.
Only applied to ambiences, of course.
I am interpreting that as an emergency flare.
Hehe, spoilers…
But yeah, ambience names are translated.
And this is a fire/flame kind of flare, or solar flare. Not lens flare.
Of course leaving it as is also an option, as it might be difficult to pick a fitting word without seeing the picture.
@ljo Can you please keep up and review? As you do not translate your self, it’s getting hard to keep up with Jolla’s time limits.
So, can you post a picture?
I forgot my password for translation and also the username I had there to log in! how can I restore it? Can’t find any ‘forgot password’ button and also forgot with what mail address the account is linked! What can I do?
It’s the same as your Jolla account (which is also true for this Forum).
Do you have that info still?
Yes I have, so I’ll try again. Password manager of the browser showed me things that confused me.
edit: works, Thank’s for your hint!
@eson Yes, sorry, it has been two crazy weeks with conferences, workshops and articles. But it is done.
Thanks! I made one more correction and one new translation that needs to be reviewed.
Sorry, this is most likely wrong place for this but wanted to report a translation bug in Finnish translation. Should there be a general thread to report small bugs in translations?
Well, anyhow, at Settings;
Apps tabselect any Android app;
Allow background services to start on bootup” is translated to “Salli sovellusten taustapalveluiden käynnistyä laitteen käynnistyksen yhteydessä”.
So, the “sovellusten” is wrongly in plural here, should be in singular; i.e.;
Salli sovelluksen taustapalveluiden käynnistyä laitteen käynnistyksen yhteydessä”.
On the other hand one could skip the whole word “sovelluksen” here if wanting to make it shorter.
For swedish translation there is an “s” missing for the same sentence;
Tillåt appbakgrundtjänster att starta vid uppstart” - shoud be;
Tillåt appbakgrundstjänster att starta vid uppstart” I would say…
Here maybe same thing? Skip the word “app”, because “appbakgrundstjänster” is quite a monster of a word… :crazy_face: → bakgrundstjänster just simply?
Login to your Jolla account and make your suggestion directly to the corresponding string, should be the best way to handle these matters… and you are right about the Swedish.
I’ll try to navigate to the right place :relaxed:
Try search! and 20 chars…
