Added “app store” apps: Jolla, Storeman, Chum
Willkommen auf der Darknight Coffee Mastodon-Instanz ☕️🦣
https://carrabelloy.darknight-coffee.org/blog/datenschutzerklaerung/
that one doesn’t work unfortunately
You need to use the upper pulley and select display all applications. Appearantly it is still marked as a library
edit: make me an application · Issue #1 · sailfishos-chum/kasts · GitHub created an issue
Added kasts as antennapod, hydrogen as element and rclone as nextcloud alternative. Maybe we should split this a bit in sections…
Made a note about this in the op/wiki.
edit: changed random pile of words into a sentence
Halfway done, left some unassorted apps at the top. Also added some links to docs for built-in apps.
Added a table of contents
Hello Sailfish OS / Jolla team,
first of all: thank you for Sailfish OS.
I recently installed Sailfish OS on my Fairphone 4 after experimenting with postmarketOS and Ubuntu Touch on other devices. I really like the overall concept, the UI, gestures, and especially the idea of creating web apps directly from the browser (similar to Ubuntu Touch, but in some ways even better).
However, during daily use I ran into several serious limitations of the Sailfish Browser that currently make the device only partially usable for me.
A concrete example:
From forum posts and documentation, it seems that this is related to missing or incomplete JavaScript features (WebCrypto, modern JS APIs, storage handling, etc.). There is no option in the browser settings to adjust or enable missing JS capabilities.
This becomes a real limitation when essential services (password managers, banking, documentation, forums) are affected.
There is no browser add-on system and no reliable built-in page translation feature. This makes it hard for non-English speakers to read documentation, forums, or report issues.
The problem is not the concept, but missing web compatibility.
It would be helpful to clarify:
Conclusion:
I am happy with Sailfish OS and I installed it intentionally as a privacy-respecting, alternative system. But at the moment, due to browser JavaScript limitations, I can realistically only use the device for:
I hope this feedback helps document real-world browser issues and maybe contributes to future improvements.
Thank you for your work and for listening.
My english is not good. Mey Handy is FP4
Welcome carrabelloy. Please use proper topic or more then one next time.
Hello Sailfish OS / Jolla team, thank you for the warm welcome! After spending more time with Sailfish OS, I wanted to share a short positive update. I am really happy with the overall system. E-mail works perfectly, telephony and SMS are rock solid, and I now run almost everything directly from my own server infrastructure. From a daily-use perspective, Sailfish OS feels fast, clean and focused. I especially want to highlight the browser concept: The ability to turn any website into a dedicated “web app” (similar to Ubuntu Touch, but more polished) is excellent. One-handed usage via the right-side menu is very well designed. Features like saving content, creating PDFs, selecting and extracting parts of a page – all of this works great and feels modern. This is exactly the direction mobile computing should go. What I am still missing, and what would make the browser almost perfect for me, is a reliable built-in page translation (English → German). Many forums and documentation pages are in English, and an integrated, stable translation option would greatly improve accessibility. I would gladly accept this as a high-priority browser enhancement. I am very satisfied overall and I am also willing to support development via the Sailfish OS license. I do not need Android app support – I mainly need a strong browser with good web compatibility and translation support. I will publish a more detailed blog post about my Sailfish OS experience soon, including screenshots and daily-use impressions. Thank you again for this unique and privacy-respecting operating system.
If you’re interested, there’s a native Sailfish client for Mastodon, called ‘Tooter’.
No alternative browser available
You did not look very hard. There is Angelfish. Instructions Packaging Qt6 (6.7.2) for Sailfish OS - #73 by mive
Who is tis? Aim have mey instanz
Thanks for the help ![]()
Can someone please advise me? I thought that, without making a change, we could not use standard android apps. However I assumed we could installed apps from f-droid which don’t require google services. Based on the list of alternatives above, it seems to suggest that f-droid apps such as QR Code Reader and Antenna Pod are not possible to install on SFOS. Can anyone tell me which is true?
It a list of alternatives, it generally says nothing about whether the Android app that it compares to works nor not. Don’t read more into it than there is.
Thanks attah, that’s a fair point.
I even made some wiki pages about it : Qt 6 experimental | SailfishOS community wiki ![]()
Early access to Qt 6 libraries and apps
Currently (January 2026) the repositories need to be added “manually” from a terminal session either from the Terminal
and then you describe the process to install angelfish, which I performed 100% through Chum. No terminal.
Isn’t it an older Qt5 version of Angelfish you installed from Chum ?
No
(just adding some chars)
