I think there is more than one reason someone might want to try SFOS beyond just privacy. For example hating the direction of development that Android is going in (dumbing it down, restricting what you can do & removing freedom). Or wanting to try something different. Or wanting something not developed/controlled by the USA.
I have noticed my Jolla Phone (2026) is not getting emergency messages, even though I have enabled this functionality through settings, subscribed to every emergency channel listed, and others who use the same network provider around me get them (although they dont use Jolla Phone). How could I troubleshoot this? Thank you.
That’s tricky because you need to know when the alarm arrives, but in general follow this guide:
Thank you. But as far as I understand this doesn’t work retrospectively, so that’s unlucky :smiley: I guess I have to wait for scheduled test messages!
I actually am here because of these reasons too. But the amount of friction I encountered while learning something new, and the issues I had to overcome (and that I still do) and the things I had to give up in order to use this, made me wonder if I couldn’t have gotten better by getting another Android device and flashing Graphene and Lineage OS instead, for these reasons (or any European based custom ROM for that matter?). Thankfully the Tutorial app and the hints made wonders in helping me get along with the navigation, and from what I understood, installing MicroG was much harder than it is now, so I can tell there is some progress in making the device/the OS more accessible to everyone.
I am not in the proper financial situation to purchase another phone right now, and I managed to get my phone working properly so far (except that I have this issue with the Android apps) - by only giving up of 3 Android apps so far due to AAS issues, so that’s a good sign too. But I don’t recall encountering this amount of friction while setting up my previous Android devices. Probably I’m a bit subjective maybe? Or maybe I did not buy the said devices at launch directly? Idk. I still so far do not see myself getting through all of this again if I were to start all over.
Part of it is definitely because you’re an early adopter. Quite a few bugs on the new phone are brand new to people who’ve been using Sailfish for years and so equally annoying for us as they are for you, and seem to be either things that didn’t get caught in testing or weren’t important enough to fix straight away. That isn’t to say all bugs are exclusive to the new phone or to Sailfish 5.2, many, big and small, have existed for a long time, although in many cases it’s also because they’re hard to debug or hard to fix.
Part of it is for sure that you’ve been using Android for a long time and you’ve grown accustomed to having certain things that “we” (long-time Sailfish users) have grown accustomed to not having. And “we” have naturally also grown accustomed to those long(er)-standing bugs.
But of course, another part of it is that Sailfish doesn’t have thousands of developers and billions of currency to throw at whatever problem presents itself, and by definition it always has to play catch-up to whatever big telco comes up with.
By the way, the issue you were experiencing with the mobile internet connection details being filled in with just “internet” is because the credentials are pulled from a database, but if there are no credentials for that exact carrier in the database, they get filled in with “internet”. Same things always happens to me with a minor MVNO carrier in Belgium. But I forgot which database it is, where it is, and how mere mortals such as us can contribute the correct login details so others don’t run into the same issues in the future. Hopefully someone else can chime in with a link. In any case, big telco aren’t the ones filling in the database, so it again relies on volunteers doing the work.
10 posts were split to a new topic: Other mobile OSes debate
Another observation. Rarely, the phone spontaneously shuts down. In this state, connecting a charger does not show the offline charging screen. But the power button turns the phone back on normally.
EDIT: This might be some variation of Complete crash when charging.
Isn’t that a desktop-only browser? I did not check it, tbh. If they release an Android app, then URLCheck should handle it just fine.
Thanks for the link! That’s indeed the one I was thinking of.
You’ve probably tried it already, but did you check if changing the option “Treat mobile data as WLAN”, at the bottom of the settings for AppSupport, helped? Every time you change it, you have to restart AppSupport before the change goes into effect.
Didn’t quite think of it, but it looks like it was already enabled. I tried disabling it and then enabling it back, still nothing, either with it disabled or enabled.
Issue raised and Jolla team is working on imprivements :
Not sure, if that is known thing.
I miss the option to switsch off the mobile connection (sim) with the private switch. Why only WLAN can be switched off?
You will have to be patient for some time more. I’m at the end of batch 1 (1900- to 2000), and had my phone delivered today.
My order in Batch 1 was just under 2,100 and is on its way to Germany. Batch 2 is due to start soon.
Because WLAN is a surveillance thing all over the world.
Wouldn’t mind also switsch off the mobile connection though. Maybe that is an option in Ambiences? At least that is how I use it since the very beginning of SFOS.
Not sure if I really understand you. Mobile connection can be also used for surveillance too.
Of course, but that could always be turned off via top menu or settings, right?
To be completely honest, I don’t even get this hype about the hardware power button. I mean… what does it do that the software didn’t already do in the first place?
Please, I really need to be enlightened.
it’s not a hardware switch, it functions the same as turning things off via software.
i think it’s just for convenience, quickness, and personalization. you could do the same by tapping the settings on screen but with button it’s just 1 action vs potentially lots of taps.
i too wish the switch could change more settings, right now it seems kinda limited. maybe we can set more behaviours via terminal?
i’d also like if it could be possible to make an app that advances its functionality, letting it do more. i studied as a programmer but i’m new to jolla, qt etc and don’t have so much spare time
Thanks, I’m starting to get to the heart of the matter.
What I still don’t understand is why I need a hardware button that does exactly the same thing I’ve always been doing with my custom ambience? What’s the use of double commands?
