Interesting I installed the stock “media” player and I really love it. Yes it is simple but that’s what I love. It works great with my well annotated local music library, automatically sorted by albums and artists, showing the album cover art. When opening the album it shows the cover nice and large. It also works well when turning off the screen and offers controls with a locked screen. Not much to learn either.
For browsers, if you are not intimidated by its installation process, you can give Angelfish a try. I think it is the most capable browser that runs natively, even if the notch is a bit in the way.
It seems like there are a lot of SFOS “quality of life” improvements that all the old users know about, but few of the new users have found. It would be really great if someone could make a list of all those (probably needs to be on a wiki), unless someone already has done so?
No, I think the problem is they expect it to exactly fit their needs straight away, with little to no effort on their part. In any new OS you need to spend time to work out how to make it do things differently, what are the options you have, how to customise it, learn to work different ways than before, etc. A new OS won’t feel comfortable or even usuable straight away. That may be especially true of SFOS, as it works quite differently to Android & iOS, and a lot of customisation options are hidden on the unofficial app stores…
And then the new Jolla 2 phone seems to have some rough edges (which personally I was expecting as an early adopter), which Jolla will hopefully fix sooner or later, e.g. some performance issues, and a few reliability issues. These don’t help of course, but just be patient, it should improve with time.
Also, in my mind part of the joy of Linux is that it may not do exactly what you want, but there’s usually a way to customise it how you want, sometimes with a little or a lot of effort. You are the root user, not Google or Apple or Microsoft! Just be careful when fiddling…
Maybe I should write a bug report, but before I do that, a quick question. For the third time in 10 days, J2 was unresponsive when trying to wake up the phone yesterday. Much to my surprise, I was able to ssh into the device, which then “woke up”. Has anyone else encountered something similar?
I’ve had mine since the Day1, and only slightly similar occurrences I had with double tap waking up activating in my lap pocket when walking.
This lead to J2 to accumulate a lot of touch based interactions that started to unravel when I opened the device. After a second or two of panels opening and closing (toggles as well) this settled down.
If your problem is triggered by doubletap wakeup triggering too easily as well, you could try disabling it for a few days test.
Some experience taking a longer drive to the beach yesterday.
Navigation using Waze (AAS) was ok, not great, it was a little choppy with my location updating only after 5 to 10 seconds sometimes.
Then I used another AAS app for parking (EasyPark / ParkMobile, this didn’t work on older SFOS phones but now it does except finding my location).
Spent a few hours on the beach watching the eclipse. Then when I wanted to use the parking app again I had no connectivity inside AAS, so I restarted it. Then everything worked again.
I guess there is not a setting for it…(?)
Maybe post a feature request about it?
(but do search before posting that there isn’t already a post about it)
I experience a high CPU Usage (and therefore high battery drain and heath production of the device) with some android apps, e. g. ARD Sounds. Maybe some codecs are rendered inefficient? But i can not compared if it is that bad as well on Android with this app.
I just opened the phone, chose Swedish and Sailfish started encrypting the new device.
It’s been going on for over 30 minutes now, am I supposed to leave it over night or something? I’ve never used sailfish before and since there’s no manual with the phone I don’t know what to expect
I’m doing un-unboxing video and well, I’ve paused it and hopefully will get back to it
And there seems to be some kind of cover already on the screen, is that supposed to be there if you apply gorilla glass to the phone? Cause the phone screen doesn’t have sharp edges right?
That doesn’t sound right, it took couple dozen seconds to maybe a minute or so for me, sooo, yeah, maybe try to force a restart with some combination of power+volume up/down if power alone doesn’t work, hard to tell what state the phone’s in, maybe recovery and reset will help and it will go through on second attempt (assuming it doesn’t reboot properly, but who knows)
This topic has been discussed already a lot of timrs. Though, here a description of the teo possibla layers already applied, when you receive your phone.
And no, of course, never, ever apply a new layer upon an already existing one. Either you leave the one on the glass until it has to be replaced or you take it away and replace it by a new one.
