Jolla Phone 2026 | preinstalled protection foil?
Hey all,
got my J2 yesterday and now i noticed, there is a kind of protective foil on the display. Has anyone this also on the display. Im not speaking of the one you can peel easily.
I do not like the feeling when swiping from edge because you feel the edge of the foil and more over there are two small inclusions, which can not be pressed out…
Yes, there is a preinstalled factory screen protector under the removable plastic film. As I understand, it is only supposed to be removed when installing the glass screen protector instead, which is sold separately.
The half-round non-adhesive area at the top right seems to be a manufacturing artifact and not a defect. Other units also have it.
There is more discussion on the factory screen protector and bubbles in this thread: Jolla Phone : First Experiences, Pros and Cons
Thanks for the hint! Will read the thread👍
I would ike to have some kind of official feedback from @Jolla , maybe @rainemak could say something. I still have the foil with that peel-off lid on my screen and am still irritated about the fact that the phone maybe comes with a screen protector installed while protectors are sold as accessories. Where’s the difference between the pre-installed and separatly sold ones (the difference between the two seperate protectors is clea btw) and if all new Jolla Phones have that attached.
This has been discussed a great many times before: the J2 (verifiably) comes with protection foil (no, not the one with the tab to peel off, a “real” one).
It’s well applied (by own experience) and is supposed to be removed before “proper” protection is applied.
Isn’t the pre-applied one made out of plastic the separate accessories are made out of Gorilla glass?
That’s one thing I don’t understand as I never used a screen protector before. I just know Gorilla Glass from displays, but now you speak of Gorilla Glass as screen protectors? So the seperate screen protectors are made out of glass?
Yes there are glass protectors (with a thin rubber as adhesive). I get these ones for my 10iii 9H 3mk HardGlass Max Lite™ glass for Sony Xperia 10 III 5G - Hurtel.com
Glass protectors add more thickness than a plastic foil. They tend to get damaged over time, so I need a new one every year or so. For the J2 I purchased two of them immediately.
