Jolla Phone (2026) Bluetooth crashes randomly
REPRODUCIBILITY: Random / few times a day
OS VERSION: 5.2.0.13
HARDWARE: Jolla Phone (2026)
UI LANGUAGE: Finnish
REGRESSION: N/A
So, I’m having Bluetooth issues with the new Jolla Phone (currently on 5.2.0.13). The Bluetooth just crashes randomly. Using Utilities to restart Bluetooth works for a while, but then it crashes after some time. I haven’t found a way to pinpoint the cause for this.
Freshly installed Jolla Phone with apps downloaded during device setup.
  1. Turn on Bluetooth
  2. Start App Support during device startup
  3. Use the phone
Bluetooth stays on.
Bluetooth crashes.
Only official packages, App Support, Exchange, Predictive text input, F-Droid and Aurora Store
What I did so far:
  • Uninstall App Support Bluetooth
  • Turn the phone off and on again (:wink:)
  • Turned off the App Support autostart
  • Stopped App Support
  • Turned on Bluetooth from Settings (for some reason it was off, even though during power off I left it on)
  • Turn off the phone and turn it on again (Bluetooth stays on after shutdown and restart)
  • Install App Support Bluetooth
  • Turn off the phone and turn it on again (as instructed on the App Support Bluetooth installation instruction in the Store page)
  • Manually started App Support
  • Turned on the App Support Bluetooth in Bluetooth Settings
Now the Bluetooth stays on after phone shut down and power up. I tried adding my Suunto 5, and I was able to connect to my Suunto 5 from Sailfish Settings, but since it’s connected on the OS level, the Suunto App doesn’t find it anymore. If I remove the connection from the OS, the Suunto App finds the watch, but fails to initiate the connection. This is probably unrelated to the crashing, but more about the current state of Bluetooth support in App Support.
I have the same experience. And just like you, I haven’t been able to pinpoint the reason for the crash. Well, it doesn’t seem to be so much a crash but more like bluetooth getting stuck.
Well yes. It gets disabled and can’t be enabled without restarting it through Utilities.
When I got the phone, the initial aetup failed because it couldn’t find a WiFi adapter. I had to do a factory reset and after that I was able to go through the setup process. I really hope it was just a software glitch and not related to anything more serious with the hardware.
Maybe too early to say, but since the update yesterday (5.2.0.15) bluetooth has been working fine for me.
Worked half a day. This morning it got disabled again and had to restart through Utilities. Now it’s been up and running for a nice five hours. So, not quite there yet.
Ok, so I’ve been monitoring the Bluetooth connection for a few days, and it seems that the App Support Bluetooth in the System settings is the culprit for the crash. Here’s what I’ve seen:
  • 20.7. about 19:15, updated SFOS, turned on Bluetooth and App Support manually, including App Support Bluetooth in Settings.
  • 21.7. about 09:40 needed to reset Bluetooth due to crash
  • 22.7.:
    • 09:30 needed to reset Bluetooth due to crash.
    • 10:40 needed to reset Bluetooth due to crash.
    • 01:46 needed to reset Bluetooth due to crash, turned off App Support.
  • 23.7.:
    • 12:33 Bluetooth is still on, turned App Support on manually
    • 15:27 turned off App Support Bluetooth (SFOS Settings)
  • 24.7.:
    • As I’m writing this, the Bluetooth is still on. No crashes, nothing.
Turning off the App Support Bluetooth also stops my Withings app to sync and connect to the wathch. And even if I turn the BT Support on, it doesn’t reconnect and sync. Turning the Bluetooth off and on with App Support enabled, the Withings App reconnects, Sync is still a bit iffy, it syncs up until 13%, then disconnects, reconnects and syncs again up to 13%. Data is uploaded bit by bit, every 13% sync adds more data to the app.
Same experience with my Withings ScanWatch, erratic, but usable, better than before…
Yeah. I turned the App Support BT on and off, alas, the BT crashed after a while. So, with the current observations, it may crash even if it’s not kept on.
Great way to trigger this for me: play an album over Bluetooth in my car. When I get out of the car, a few minutes later it crashes (such that I can’t play music on the drive home).
For me just connecting to car seems to increase the likelihood of crash, even without playing music.
I think that’s fair here too. Additionally, usually the second round shows a repeated connect and disconnect on my car’s infotainment, and shows connected on the phone.
I have the same issues. The bt seems to work better if I start my music before entering the car. Then it usually connects. If I launch Tidal in my car the connection fails and sometimes I have to do the whole pairing again. Same issues at work with my Jabra headset. I have to set my phone bt to connect before turning the jabra on. If I turn my Jabra on first nothing works and connects and have to do the whole pairing again.
I have same problem, Jolla phone, 5.2.0.16. Only thing I have done so far with the Bluetooth is to connect to my Oura (gen3) ring. After I have been unable even to find any other Bluetooth devices. Bluetooth seems to crash regularly and when it gets up again, still can’t find any Bluetooth devices, but my Oura can connect. Can’t see the connection tho in the setting bluetooth page. Also Stumblefish can’t collect BLE, probably because it isn’t really up and running
I remember there were some Bluetooth module that was needed to be restarted for android bluetooth, but couldn’t quickly found it…. Could someone lend me hand here and remind me what was the command that was supposed to be run?
I don’t know if this is related to the original report but my bluetooth is giving me more and more issues. Now I suddenly can’t pair it with my car anymore at all. My phone shows my car on the list but fails pairing every time. Before it just dropped the connection and I had to pair it again every other day. I’m in my car a lot and am used to use Tidal and this is getting really annoying.
@abranson I tried to gather logs with this method, which can be seen below. Jolla phone, 5.2.0.16.
Log1, Bluetooth crashed, didn’t start from restart. No Bluetooth at all.
-- Logs begin at Mon 2026-08-10 18:45:13 EEST, end at Mon 2026-08-10 18:47:35 EEST. --
Aug 10 18:45:14 JollaPhone2026 appsupport-bridge-bt-aidl[23384]: Attempting AppSupport setup
Aug 10 18:45:14 JollaPhone2026 appsupport-bridge-bt-aidl[23384]: registerAdapter returned null IBluetooth object; Bluetooth likely off
Aug 10 18:45:14 JollaPhone2026 appsupport-bridge-bt-aidl[23384]: setBluetoothEnabled(off) requested
Aug 10 18:45:14 JollaPhone2026 appsupport-bridge-bt-aidl[23384]: setBluetoothEnabled(off) skipped; already set
Aug 10 18:45:16 JollaPhone2026 appsupport-bridge-bt-aidl[23384]: Attempting AppSupport setup
Aug 10 18:45:16 JollaPhone2026 appsupport-bridge-bt-aidl[23384]: registerAdapter returned null IBluetooth object; Bluetooth likely off
Aug 10 18:45:16 JollaPhone2026 appsupport-bridge-bt-aidl[23384]: setBluetoothEnabled(off) requested
Aug 10 18:45:16 JollaPhone2026 appsupport-bridge-bt-aidl[23384]: setBluetoothEnabled(off) skipped; already set
Aug 10 18:45:18 JollaPhone2026 appsupport-bridge-bt-aidl[23384]: Attempting AppSupport setup
Aug 10 18:45:18 JollaPhone2026 appsupport-bridge-bt-aidl[23384]: registerAdapter returned null IBluetooth object; Bluetooth likely off
Aug 10 18:45:18 JollaPhone2026 appsupport-bridge-bt-aidl[23384]: setBluetoothEnabled(off) requested
Aug 10 18:45:18 JollaPhone2026 appsupport-bridge-bt-aidl[23384]: setBluetoothEnabled(off) skipped; already set
Aug 10 18:45:20 JollaPhone2026 appsupport-bridge-bt-aidl[23384]: Attempting AppSupport setup
Aug 10 18:45:20 JollaPhone2026 appsupport-bridge-bt-aidl[23384]: registerAdapter returned null IBluetooth object; Bluetooth likely off
Aug 10 18:45:20 JollaPhone2026 appsupport-bridge-bt-aidl[23384]: setBluetoothEnabled(off) requested
Aug 10 18:45:20 JollaPhone2026 appsupport-bridge-bt-aidl[23384]: setBluetoothEnabled(off) skipped; already set
After few restart I can get the Bluetooth kind of running, still the settings → bluetooth → find devices shows nothing, but phone connects to my Oura ring (gen3). Log 2.
-- Logs begin at Mon 2026-08-10 19:03:49 EEST, end at Mon 2026-08-10 19:05:23 EEST. --
Aug 10 19:04:19 JollaPhone2026 systemd-journald[857]: Suppressed 2688 messages from appsupport-bridge-bt.service
Aug 10 19:04:19 JollaPhone2026 appsupport-bridge-bt[32649]: Binder call from AppSupport: code=3 flags=0x0 oneway=0
Aug 10 19:04:19 JollaPhone2026 appsupport-bridge-bt[32649]: Binder recv code=3 flags=0x0 oneway=0
Aug 10 19:04:19 JollaPhone2026 appsupport-bridge-bt[32649]: Binder vec ptr=0x71f41720a0 elemsize=1 count=14
Aug 10 19:04:19 JollaPhone2026 appsupport-bridge-bt[32649]: sendAclData called from AppSupport (flags=0x0 oneway=0)
Aug 10 19:04:19 JollaPhone2026 appsupport-bridge-bt[32649]: Data: |00|02|0a|00|06|00|04|00|12|15|00|16|01|02|
Aug 10 19:04:19 JollaPhone2026 appsupport-bridge-bt[32649]: Writing AppSupport command type: 2 len: 14
Aug 10 19:04:19 JollaPhone2026 appsupport-bridge-bt[32649]: AppSupport send packet: 2  0  2  a  0  6  0  4  0  12  15  0  16  1  2
Aug 10 19:04:19 JollaPhone2026 appsupport-bridge-bt[32649]: Controller queue size=1 (cmd=0 acl=1 sco=0 origin=AppSupport type=0x02 len=15)
Aug 10 19:04:19 JollaPhone2026 appsupport-bridge-bt[32649]: Sending controller packet from AppSupport len=15 type=0x02
Aug 10 19:04:19 JollaPhone2026 appsupport-bridge-bt[32649]: Write to controller: 2  0  2  a  0  6  0  4  0  12  15  0  16  1  2
Aug 10 19:04:19 JollaPhone2026 appsupport-bridge-bt[32649]: HCI channel callback
Aug 10 19:04:19 JollaPhone2026 appsupport-bridge-bt[32649]: HCI data (0x04): 0x13050100020100
Aug 10 19:04:19 JollaPhone2026 appsupport-bridge-bt[32649]: HCI event packet 19/5
Aug 10 19:04:19 JollaPhone2026 appsupport-bridge-bt[32649]: 0x13 completed packets handle=0x0200 count=1 owner=AppSupport
Aug 10 19:04:19 JollaPhone2026 appsupport-bridge-bt[32649]: Routing 0x13 completed packets to AppSupport (handles=1)
Aug 10 19:04:20 JollaPhone2026 appsupport-bridge-bt[32649]: HCI channel callback
Aug 10 19:04:20 JollaPhone2026 appsupport-bridge-bt[32649]: HCI data (0x02): 0x002205000100040013
Aug 10 19:04:20 JollaPhone2026 appsupport-bridge-bt[32649]: HCI ACL data packet
Aug 10 19:04:20 JollaPhone2026 appsupport-bridge-bt[32649]: Sending to AppSupport 2: 0x002205000100040013
Aug 10 19:04:20 JollaPhone2026 appsupport-bridge-bt[32649]: HCI data (0x02): 0x002210000c000500120308000c000c001400c800
Aug 10 19:04:20 JollaPhone2026 appsupport-bridge-bt[32649]: Sending to AppSupport 2: 0x002210000c000500120308000c000c001400c800
Aug 10 19:04:20 JollaPhone2026 appsupport-bridge-bt[32649]: Binder call from AppSupport: code=2 flags=0x0 oneway=0
Aug 10 19:04:20 JollaPhone2026 appsupport-bridge-bt[32649]: Binder recv code=2 flags=0x0 oneway=0
Aug 10 19:04:20 JollaPhone2026 appsupport-bridge-bt[32649]: Binder vec ptr=0x71f41720a0 elemsize=1 count=17
Aug 10 19:04:20 JollaPhone2026 appsupport-bridge-bt[32649]: sendHciCommand called from AppSupport (flags=0x0 oneway=0 opcode=0x2013)
Aug 10 19:04:20 JollaPhone2026 appsupport-bridge-bt[32649]: Data: |13|20|0e|00|02|0c|00|0c|00|14|00|c8|00|00|00|00|00|
Aug 10 19:04:20 JollaPhone2026 appsupport-bridge-bt[32649]: Received opcode: 2013
Aug 10 19:04:20 JollaPhone2026 appsupport-bridge-bt[32649]: Setting AppSupport LE random address before updating connection
Aug 10 19:04:20 JollaPhone2026 appsupport-bridge-bt[32649]: Writing AppSupport command type: 1 len: 9
Aug 10 19:04:20 JollaPhone2026 appsupport-bridge-bt[32649]: AppSupport send packet: 1  5  20  6  f3  8a  de  88  9e  77
Aug 10 19:04:20 JollaPhone2026 appsupport-bridge-bt[32649]: Controller queue size=1 (cmd=1 acl=0 sco=0 origin=AppSupport type=0x01 len=10)
Aug 10 19:04:20 JollaPhone2026 appsupport-bridge-bt[32649]: Sending controller packet from AppSupport len=10 type=0x01
Aug 10 19:04:20 JollaPhone2026 appsupport-bridge-bt[32649]: Write to controller: 1  5  20  6  f3  8a  de  88  9e  77
Aug 10 19:04:20 JollaPhone2026 appsupport-bridge-bt[32649]: waiting_command set: 0x2013 (pending=1)
Aug 10 19:04:20 JollaPhone2026 appsupport-bridge-bt[32649]: Writing AppSupport command type: 1 len: 17
Aug 10 19:04:20 JollaPhone2026 appsupport-bridge-bt[32649]: AppSupport send packet: 1  13  20  e  0  2  c  0  c  0  14  0  c8  0  0  0  0  0
Aug 10 19:04:20 JollaPhone2026 appsupport-bridge-bt[32649]: Controller queue size=1 (cmd=1 acl=0 sco=0 origin=AppSupport type=0x01 len=18)
Aug 10 19:04:20 JollaPhone2026 appsupport-bridge-bt[32649]: Binder call from AppSupport: code=3 flags=0x0 oneway=0
Aug 10 19:04:20 JollaPhone2026 appsupport-bridge-bt[32649]: Binder recv code=3 flags=0x0 oneway=0
Aug 10 19:04:20 JollaPhone2026 appsupport-bridge-bt[32649]: Binder vec ptr=0x71f41720a0 elemsize=1 count=14
Aug 10 19:04:20 JollaPhone2026 appsupport-bridge-bt[32649]: sendAclData called from AppSupport (flags=0x0 oneway=0)
Aug 10 19:04:20 JollaPhone2026 appsupport-bridge-bt[32649]: Data: |00|02|0a|00|06|00|05|00|13|03|02|00|00|00|
Aug 10 19:04:20 JollaPhone2026 appsupport-bridge-bt[32649]: Writing AppSupport command type: 2 len: 14
Aug 10 19:04:20 JollaPhone2026 appsupport-bridge-bt[32649]: AppSupport send packet: 2  0  2  a  0  6  0  5  0  13  3  2  0  0  0
Aug 10 19:04:20 JollaPhone2026 appsupport-bridge-bt[32649]: Controller queue size=2 (cmd=1 acl=1 sco=0 origin=AppSupport type=0x02 len=15)
Aug 10 19:04:20 JollaPhone2026 appsupport-bridge-bt[32649]: Sending controller packet from AppSupport len=15 type=0x02
Aug 10 19:04:20 JollaPhone2026 appsupport-bridge-bt[32649]: Write to controller: 2  0  2  a  0  6  0  5  0  13  3  2  0  0  0
Aug 10 19:04:20 JollaPhone2026 appsupport-bridge-bt[32649]: HCI data (0x04): 0x0e040105200c
Aug 10 19:04:20 JollaPhone2026 appsupport-bridge-bt[32649]: HCI event packet 14/4
Aug 10 19:04:20 JollaPhone2026 appsupport-bridge-bt[32649]: HCI command credits set: 1
Aug 10 19:04:20 JollaPhone2026 appsupport-bridge-bt[32649]: Sending controller packet from AppSupport len=18 type=0x01
Aug 10 19:04:20 JollaPhone2026 appsupport-bridge-bt[32649]: Write to controller: 1  13  20  e  0  2  c  0  c  0  14  0  c8  0  0  0  0  0
Aug 10 19:04:20 JollaPhone2026 appsupport-bridge-bt[32649]: Dropping controller command complete for AppSupport: opcode=0x2005 pending=0x2013 pending_count=1
Aug 10 19:04:20 JollaPhone2026 appsupport-bridge-bt[32649]: Command complete for BlueZ (opcode=0x2005 pending=0x2013)
Aug 10 19:04:20 JollaPhone2026 appsupport-bridge-bt[32649]: Sending event to BlueZ
Aug 10 19:04:20 JollaPhone2026 appsupport-bridge-bt[32649]: HCI data (0x04): 0x0f0400011320
Aug 10 19:04:20 JollaPhone2026 appsupport-bridge-bt[32649]: HCI event packet 15/4
Aug 10 19:04:20 JollaPhone2026 appsupport-bridge-bt[32649]: waiting_command done: 0x2013 (pending=0)
Aug 10 19:04:20 JollaPhone2026 appsupport-bridge-bt[32649]: Responding to forwarded command (status)
Aug 10 19:04:20 JollaPhone2026 appsupport-bridge-bt[32649]: Sending to AppSupport 4: 0x0f0400011320
Aug 10 19:04:20 JollaPhone2026 appsupport-bridge-bt[32649]: HCI data (0x04): 0x13050100020100
Aug 10 19:04:20 JollaPhone2026 appsupport-bridge-bt[32649]: HCI event packet 19/5
Aug 10 19:04:20 JollaPhone2026 appsupport-bridge-bt[32649]: 0x13 completed packets handle=0x0200 count=1 owner=AppSupport
Aug 10 19:04:20 JollaPhone2026 appsupport-bridge-bt[32649]: Routing 0x13 completed packets to AppSupport (handles=1)
Aug 10 19:04:24 JollaPhone2026 appsupport-bridge-bt[32649]: HCI channel callback
Aug 10 19:04:24 JollaPhone2026 appsupport-bridge-bt[32649]: HCI data (0x04): 0x57020002
Aug 10 19:04:24 JollaPhone2026 appsupport-bridge-bt[32649]: HCI event packet 87/2
Aug 10 19:04:24 JollaPhone2026 appsupport-bridge-bt[32649]: Sending event to BlueZ
Aug 10 19:04:24 JollaPhone2026 appsupport-bridge-bt[32649]: Sending to AppSupport 4: 0x57020002
Aug 10 19:04:36 JollaPhone2026 appsupport-bridge-bt[32649]: HCI channel callback
Aug 10 19:04:36 JollaPhone2026 appsupport-bridge-bt[32649]: HCI data (0x02): 0x00220a00060004001b1200170102
Aug 10 19:04:36 JollaPhone2026 appsupport-bridge-bt[32649]: HCI ACL data packet
Aug 10 19:04:36 JollaPhone2026 appsupport-bridge-bt[32649]: Sending to AppSupport 2: 0x00220a00060004001b1200170102
Aug 10 19:04:36 JollaPhone2026 appsupport-bridge-bt[32649]: HCI data (0x04): 0x3e0a030000020c001400c800
Aug 10 19:04:36 JollaPhone2026 appsupport-bridge-bt[32649]: HCI event packet 62/a
Aug 10 19:04:36 JollaPhone2026 appsupport-bridge-bt[32649]: Sending connection update event to AppSupport only
Aug 10 19:04:36 JollaPhone2026 appsupport-bridge-bt[32649]: Sending to AppSupport 4: 0x3e0a030000020c001400c800
Aug 10 19:04:36 JollaPhone2026 appsupport-bridge-bt[32649]: Binder call from AppSupport: code=3 flags=0x0 oneway=0
Aug 10 19:04:36 JollaPhone2026 appsupport-bridge-bt[32649]: Binder recv code=3 flags=0x0 oneway=0
Aug 10 19:04:36 JollaPhone2026 appsupport-bridge-bt[32649]: Binder vec ptr=0x71f41720a0 elemsize=1 count=13
Aug 10 19:04:36 JollaPhone2026 appsupport-bridge-bt[32649]: sendAclData called from AppSupport (flags=0x0 oneway=0)
Aug 10 19:04:36 JollaPhone2026 appsupport-bridge-bt[32649]: Data: |00|02|09|00|05|00|04|00|12|15|00|0c|00|
Aug 10 19:04:36 JollaPhone2026 appsupport-bridge-bt[32649]: Writing AppSupport command type: 2 len: 13
Aug 10 19:04:36 JollaPhone2026 appsupport-bridge-bt[32649]: AppSupport send packet: 2  0  2  9  0  5  0  4  0  12  15  0  c  0
Aug 10 19:04:36 JollaPhone2026 appsupport-bridge-bt[32649]: Controller queue size=1 (cmd=0 acl=1 sco=0 origin=AppSupport type=0x02 len=14)
Aug 10 19:04:36 JollaPhone2026 appsupport-bridge-bt[32649]: Sending controller packet from AppSupport len=14 type=0x02
Aug 10 19:04:36 JollaPhone2026 appsupport-bridge-bt[32649]: Write to controller: 2  0  2  9  0  5  0  4  0  12  15  0  c  0
Aug 10 19:04:36 JollaPhone2026 appsupport-bridge-bt[32649]: HCI data (0x04): 0x13050100020100
Aug 10 19:04:36 JollaPhone2026 appsupport-bridge-bt[32649]: HCI event packet 19/5
Aug 10 19:04:36 JollaPhone2026 appsupport-bridge-bt[32649]: 0x13 completed packets handle=0x0200 count=1 owner=AppSupport
Aug 10 19:04:36 JollaPhone2026 appsupport-bridge-bt[32649]: Routing 0x13 completed packets to AppSupport (handles=1)
Aug 10 19:04:36 JollaPhone2026 appsupport-bridge-bt[32649]: HCI data (0x02): 0x002205000100040013
Aug 10 19:04:36 JollaPhone2026 appsupport-bridge-bt[32649]: Sending to AppSupport 2: 0x002205000100040013
One thing about stumblefish - it only collects BLE beacons, not every device seen. I don’t see any of those at home, so not seeing any doesn’t necessarily mean BLE isn’t working.
It is grayed out and can’t be activated. I assume it senses from something that it can’t detect BLEs currently. After many Bluettooth restarts it might be active for few seconds
PS. @abranson just say if I can get you more or better logs!
I use the “Sailfish Utilities” App from Jolla store to restart Bluetooth subsystems, it usually works well.
I use the same and for me it gets back to some state with X number of restarts. Bluetooth stays on, automatically connects to my Oura ring, but nothing more. Can’t find any devices, so I can’t connect or disconnect anything
What is the purpose of “Visibility” or “näkyvyys” in finnish in the Bluetooth settings? I’ve tried it on and off to solve my issues but hasn’t worked.
