It can easily be from pocket - cloth dust.
I disagree itâd be normal even after a year unless something cracks, and I personally havenât seen dust buildup in any phone I owned yet
Luckily same here (I have the gorilla protective cover applied on top of the factory one, as was unaware there was a second layer to peel after the obvious plastic one, not sure if that changes things?)
Sorry⌠the dust is getting in via the side of the phone - because the screen has no inlets/holes for the camera.
Interesting, I wonder if that happens when changing covers? I havenât yet even tested the inari one (and now Iâm afraid to do it)
@throwaway69
I had all (both) protectors removed befor applying the privacy shield one. I guess one thing has nothing to do with the other.
Iâd rather think the dust gets in via the speaker grill just next to it. There is likely insufficient or no dust barrier between those two.
That´s a biased point of view. I use a Motorola ThinkPhone 25, 400e, and the camera module is wonderfully clean from dust.. after one year and a half of use.
It shouldn´t happen.
I have switched covers a few times and carried the phone in my pocket (not regularly) and -thanks to this thread- noticed a small amount of dust building up. My wife hasnât replaced the cover yet, never carry the phone outside -ie. never put it in her pocket- and there are tiny particles of dust in her JP2 ![]()
Agree. I consider product defective if there is dust between cam and screen glass.
This is disappointing, isnât there any mesh on speaker hole what prevents dust go inside phone.
I can imagine what amount of dust get inside phone when carried that in pocket
There is a mesh but the particles are super fine. I think you canât prevent ingress without a seal towards the camera lens.
I understand that this is a defect but for me personally it is not a big deal, I never use selfie cameras. I am aware though that others do and that this issue needs to be rectified.
Thank you all for reporting these! This problem worries me, I have not received the phone yet (still in transport). In particular, what about the main camera? Does it looks clean at least?
Could @jolla at least confirm that theyâre assessing the situation? This should not be happen, not matter if it is a low/mid/high range phone. Also should the people deny to getting the package, so it will be send back to the factory/Jolla?
No issues with the main camera at this point, looks pristine.
Iâm sure @Jolla is looking in to this, small problem might be that probably most of Jolla employees are on holiday, which probably causes delays with the matterâŚ
I think Iâve found the problem. Youâre keeping the phone in the same location as your pocket sand !
You were absolutely right in the first sentence you wrote, but what youâre saying now is a bit rude. Of course, you canât just compare this phone to a flagship; there are things that make it different, but you canât ignore those either.
Calm downâ even billion-dollar companies like Apple make mistakes, so donât be too hard on such small companies.
No need to start pointing with fingers here. Is that what you would do if Attah was here face to face with you?
I have not stated that Jolla has manufactured a âdefectiveâ device. I have reported a problem for Jolla which will be anyways coming their way sooner or later. There are many people who want/need to make video calls.
You said âBTW enjoy your selfiesâ with a laughing face. If this is friendly and nice to say to other people - I think we donât need an answer for that - but something you can think for yourself.
Jolla is a very very good telephone manufacturer in my opinion. But they are humans too and some things are not optimal sometimes.
PS. I beg for your forgiveness Jolla that I posted this on the forum. Should have left only the Zendesk reportâŚ
No, it isnât and shouldnât be. I am using a Pixel 6a, for which I paid around 350 to 400 if I recall correctly, and there is no dust in the front-camera at all.
