Jolla C2 - Settings - Storage won't show inserted 256Gb ext4 storage card
REPRODUCIBILITY: 100%
OS VERSION: 5.0.0.61 (and .55)
HARDWARE: Jolla C2 (Second batch opened and flashed by Jolla)
UI LANGUAGE: English
REGRESSION: None
Inserted ext4 formatted Memory card (Works in Xperia Xiii and XV) reported as “Memory Card not inserted” yet card appears and is writable when connected to PC in Media Transfer mode.
None (Although a 64GB card pre-formatted in another Jolla Device when inserted in C2 is reported as present when inserted.)
  1. Insert 256GB card
  2. Turn on C2
  3. Card reported as not inserted
To see Memory card and be able to format it / encrypt the card.
Card reported as not inserted. Yet it is viewable and writable when connected to PC - Media Transfer mode
Patchmanager
OpenRepos
Chum
Unable to report with Bugger as 502 Bad Gateway error message when attempting to post report.
See screenshot from PC showing card.
Screenshot of C2 System - Storage with ext4 card inserted.
Do I assume correctly that other SD cards are recognised and you already cleaned the contacts of affected SD?
Yes other SD cards are recognised and yes I have cleaned the contacts of the affected card.
It may be an issue with the individual card but (and I am NOT a technical expert) it is weird that the sDcard is seen in the computer and is mounted without issue when inserted into the PC.
To note though that while I say that other SD cards are recognised, they first (for a second or two) show as “Memory card not inserted” before being recognised a moment later in the C2 settings.
It is odd too that the Books App, after importing two books from Download, showed two .mobi books as being on the (suspect) sDcard but did not show them when the sDcard had been swapped for another.
Perhaps it is just a dodgy SDcard (SanDisk Ultra bought new from Amazon) so I’ll use another SD for now thanks.
