Is my Jolla C2 hardware broken?
Hi,
my Jolla C2 from last August was running fine until I installed 5.0.0.78 some days ago. Since the next reboot after the installation the phone is in a reboot loop. I corrected some file system errors in recovery mode. I tried to factory reset, which failed with “md5sum: can’t read ‘root.img.gz’: Input/output error”. I reinstalled in fastboot mode, but the problem persists.
Right now the file system check does not even runs through, as it takes more than 10 minutes. And the time between two reboots got really long. Does this sound like a broken hardware to you?
Hard for me to say. There is always a full reflash.
No. It sounds like software.
But if your phone isn’t working after reflashing, that doesn’t matter too much. Broken is broken. I hope someone will be able to help you with ideas of additional steps you could do to try and fix it.
Just to check: did you use the latest images? Did you try an image thatvpreviously worked for you?
Did you manually flash the images, or only used the privided script? I.e. Manually typing in multiple flashboot commands.
Disclaimer: It is on your own responsibility. It is dangerous to not use the many safety features of the script. But it is dangerous like it is dangerous to cross a road. If you are careful, the risks are minimal.
Thank you for your hints. I followed the instructions of flashing-README.txt, which is part of each Sailfish OS release zip and looks like here Fastboot flashing of Jolla C2 . I tried versions 5.0.0.77 and 5.0.0.78. The .77 work previously on my device. I did not find any script to flash the device.
Flash-script is not needed, just perform:
I indeed found I was mistaken. There is no flashing script.
I hope someone will be able to help you soon :slight_smile:
Not yet, but now the phone already fails with the charging animation. I assume some hardware died and phone is beyond repair. I hope, it will be replaced.
