REPRODUCIBILITY: 100%
BUILD ID: 3.3.0.16
HARDWARE: XA2 Plus (dual sim)
UI LANGUAGE: English (US)
Because it seemed fun (and convenient) to me to develop directly on the phone (mainly to play with QML and Common Lisp (ecl and eql from OpenRepos)) I had to install some dependencies required by the qarma.pro file.
One of these dependencies was qt5-qtgui-devel which has as its own dependency mesa-llvmpipe-libGLESv2. This last package overwrites the existing /usr/lib/libGLESv2.so.2.0.0 which lead to this bug report.
(The packages are from the default Jolla repos on a fresh phone, not from OpenRepos or something else!)
None.
- Flash phone with a new installation,
- From the terminal or a remote session install:
2.1)devel-su pkcon install mesa-llvmpipe-libGLESv2, or
2.2)devel-su pkcon install qt5-qtgui-devel, - Reboot phone, enter correct security code,
- Observe the infinite spinner.
The telephone shows the normal lock screen.
The telephone keeps showing the decryption unlock screen and the spinner keeps spinning.
The telephone is remotely reachable (if enabled beforehand) and has most services running. The sailfish-unlock-agent seems stuck:
$ systemctl list-jobs
JOB UNIT TYPE STATE
134 sailfish-unlock-agent.service start running
If you installed just mesa-llvmpipe-libGLESv2 from step 2.1 then putting back the old libGLESv2.so.2.0.0 fixes everything again on a reboot. If you installed qt5-qtgui-devel from step 2.2 then there’s more issues (which I haven’t further explored).
I do not think packages installed from the default repos should do this. I do agree one is on his own when installing packages from unsupported repos.
