Long story short:
I’m facing this problem and am looking for a solution:
Part of the problem is similar to this:
Long story long:
I have the unhealthy habit on building apps and other programs directly on the SFOS device.
I have found previously, and just now, that installing and later removing dependencies of certain packages leaves the OS in an unstable state (up to the point that it will not boot).
Just now I installed the following packages, and upon realizing the build I wanted to do would not work, removed them again.
All this was done using pkcon install and pkcon remove.
libdrm-devel-2.4.97-1.3.1.jolla.armv7hl Direct Rendering Manager development package
libdrm-nouveau-2.4.97-1.3.1.jolla.armv7hl Direct Rendering Manager nouveau api
libdrm-omap-2.4.97-1.3.1.jolla.armv7hl Direct Rendering Manager omap api
libdrm-radeon-2.4.97-1.3.1.jolla.armv7hl Direct Rendering Manager radeon api
mesa-llvmpipe-libEGL-19.3.3+git2-1.5.1.jolla.armv7hl Mesa libEGL runtime libraries and DRI drivers
mesa-llvmpipe-libEGL-devel-19.3.3+git2-1.5.1.jolla.armv7hl Mesa libEGL development package
mesa-llvmpipe-libGLESv2-19.3.3+git2-1.5.1.jolla.armv7hl Mesa libGLESv2 runtime libraries
mesa-llvmpipe-libGLESv2-devel-19.3.3+git2-1.5.1.jolla.armv7hl Mesa libGLESv2 development package
mesa-llvmpipe-libgbm-19.3.3+git2-1.5.1.jolla.armv7hl Generic buffer management API
mesa-llvmpipe-libglapi-19.3.3+git2-1.5.1.jolla.armv7hl Mesa shared gl api library
qml-rpm-macros-0.0.5-1.1.12.jolla.armv7hl Macros for handling QML
qt5-qtdeclarative-devel-5.6.3+git13-1.8.1.jolla.armv7hl Qt Declarative - development files
qt5-qtdeclarative-qtquick-devel-5.6.3+git13-1.8.1.jolla.armv7hl Qt Declarative - QtQuick development files
qt5-qtgui-devel-5.6.3+git17.1-1.13.1.jolla.armv7hl Development files for QtGui
qt5-qtnetwork-devel-5.6.3+git17.1-1.13.1.jolla.armv7hl Development files for QtNetwork
qt5-qtsql-devel-5.6.3+git17.1-1.13.1.jolla.armv7hl Development files for QtSql
dbus-devel-1.13.12+git5-1.6.1.jolla.armv7hl Libraries and headers for D-Bus
expat-devel-2.2.9+git1-1.4.1.jolla.armv7hl Libraries and header files to develop applications using expat
fontconfig-devel-2.13.1+git2-1.5.1.jolla.armv7hl Font configuration and customization library
freetype-devel-2.10.0+git2-1.3.1.jolla.armv7hl FreeType development libraries and header files
libnemotransferengine-qt5-devel-1.0.5-1.7.1.jolla.armv7hl Development headers for transfer engine library.
libuuid-devel-2.33+git2-1.6.1.jolla.armv7hl Universally unique ID library
qt5-default-5.6.3+git17.1-1.13.1.jolla.armv7hl Qt5 development defaults packafge
qt5-qmake-5.6.3+git17.1-1.13.1.jolla.armv7hl QMake
qt5-qtcore-devel-5.6.3+git17.1-1.13.1.jolla.armv7hl Development files for QtCore
qt5-qtdbus-devel-5.6.3+git17.1-1.13.1.jolla.armv7hl Development files for QtDBus
qt5-tools-5.6.3+git17.1-1.13.1.jolla.armv7hl Development tools for qtbase
qtchooser-26-1.2.1.jolla.armv7hl Qt Chooser
libsailfishapp-devel-1.2.10-1.6.1.jolla.armv7hl Development library for Sailfish apps
mapplauncherd-qt5-devel-1.1.14-1.3.3.jolla.armv7hl Development files for launchable applications
Problem:
After uninstalling, the app launcher does not work any more. Launching apps results in:
mapplauncherd[12287]: Booster: Failed to invoke: Booster: Loading invoked application failed: 'libEGL.so.1: cannot open shared object file: No such file or directory'
or
error while loading shared libraries: libGLESv2.so.2: cannot open shared object file: No such file or directory
Analysis and trying to fix it:
Now I can find out where those libs are supposed to be coming from with:
# rpm -qf /usr/lib/libEGL.so.1
libhybris-libEGL-0.0.5.34-1.3.1.jolla.armv7hl
# rpm -qf /usr/lib/libGLESv2.so.2
libhybris-libGLESv2-0.0.5.34-1.3.1.jolla.armv7hl
However, trying to reinstall them gives:
# pkcon refresh && pkcon install libhybris-libGLESv2
Refreshing cache
Refreshing software list
Finished
Resolving [ ] (0%) Package not found: libhybris-libGLESv2
Command failed: This tool could not find any available package: No packages were found
# pkcon search libGLESv2
Searching by details
Querying
Finished
Installed libhybris-libGLESv2-0.0.5.34-1.3.1.jolla.armv7hl (installed) OpenGL ES 2.0 for libhybris
Available mesa-llvmpipe-libGLESv2-19.3.3+git2-1.5.1.jolla.armv7hl (jolla) Mesa libGLESv2 runtime libraries
Available mesa-llvmpipe-libGLESv2-devel-19.3.3+git2-1.5.1.jolla.armv7hl (jolla) Mesa libGLESv2 development package
# pkcon install libhybris-libGLESv2
Using zypper does not help either:
# zypper install -f libhybris-libGLESv2 libhybris-libEGL
Loading repository data...
Reading installed packages...
Forcing installation of 'libhybris-libEGL-0.0.5.34-1.3.1.jolla.armv7hl' from repository 'adaptation0'.
Forcing installation of 'libhybris-libGLESv2-0.0.5.34-1.3.1.jolla.armv7hl' from repository 'adaptation0'.
Resolving package dependencies...
The following 2 packages are going to be reinstalled:
libhybris-libEGL libhybris-libGLESv2
2 packages to reinstall.
Overall download size: 57.9 KiB. Already cached: 0 B. No additional space will be used or freed after the operation.
Continue? [y/n/...? shows all options] (y): y
Retrieving package libhybris-libEGL-0.0.5.34-1.3.1.jolla.armv7hl (1/2), 38.1 KiB ( 77.8 KiB unpacked)
Failed to provide Package libhybris-libEGL-0.0.5.34-1.3.1.jolla.armv7hl (adaptation0). Do you want to retry retrieval?
[adaptation0|plugin:/ssu?repo=adaptation0] Can't provide file './armv7hl/libhybris-libEGL-0.0.5.34-1.3.1.jolla.armv7hl.rpm' from repository 'adaptation0'
History:
- Store credentials not received. Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
- Can't provide ./armv7hl/libhybris-libEGL-0.0.5.34-1.3.1.jolla.armv7hl.rpm
Abort, retry, ignore? [a/r/i] (a):
Conclusions:
What does lead to this?
Answer: the two packages, mesa-llvmpipe-libEGL and mesa-llvmpipe-libGLESv2 install the same files (in part) as libhybris-libEGL and libhybris-libGLESv2, but they do NOT conflict. Installing the mesa packages will replace the library files, uninstalling the RPM will simply remove them.
It appears the missing libraries ALSO prevent the store application to provide credential to the official/licensed repos, so neither pkcon nor zypper can retrieve the correct packages to fix it (I have not verified this latter part, but zypper did start to work again after they were replaced.) -
How to recover from this?
Answer: not trivial. See the post below on how I did it.
