Wish an update of SailfishOS that include the function of easy searching for apps on the phone. Should make it a lot easier when the number of apps is raising.
You can organise them or use folders. See documentation about how.
Hi you can try the searchnemo app. It’s rather old so I’m not sure if it still works under SFOS 5 but you can try:
in Chum
https://sailfishos-chum.github.io/apps/harbour-searchnemo/
in Openrepos
https://openrepos.net/content/sargodevel/searchnemo
Searched with terms ‘search app’, first hit: https://forum.sailfishos.org/t/global-search-app-launcher-by-keyboard-search/7868, duplicate?
I don’t think the one in OpenRepos work that well, but the one in chum does.
For searching apps only, I would suggest QuickLaunch. Also in Chum.
