How to import calendar and contacts?
I am trying to set up my new C2’s Calendar, importing an .ics file from my desktop.
I have managed to export my desktop calendar to an ics file and transferred this by USB to the C2. I can’t find how to import this to the calendar on my C2.
(I will need to do similar with notes & tasks too, when I find the right apps.)
I was hoping to find a user manual with this information, but when I clicked the link, I get an empty page with a message saying I’m not allowed to access the resource!
Isn’t there a pdf user guide I can download? This is a fairly basic expectation for new users and shouldn’t be this difficult..
Not a good start.
:frowning:
You could try this support document instead
However, it doesn’t look like you can import a .ics file directly.
The simplest solution for me has always been to use a synchronised account, back when ActiveSync was working for me.
Perhaps this is something you could look into? (Nextcloud works perfectly with SFOS)
Hi, welcome!
Yes the docs.
Also this ressource: Beginner Resource Collection
And the search tool:
(The magnifier top right)
On my phone calendar import works out of the box. Just imported an ics from an email seconds ago. Click two times on the ics email-attachment and the import dialog opens.
AFAIR there’s a command line tool for that.
That’s the page where I clicked the useless ‘User Guides’ link!
We get it, you are not a satisfied customer. Good Bye!
I tried that.
A new page opens with options to cut, copy, share, delete.. anything but ‘import into calendar’ which is what I need.
Does anyone want to buy a second-hand C2 ?
Not very fairly said, thinking of people who took time and efforts to write those guides.
I thought this was a Linux phone that would enable me to install Evolution (or J-Pilot) which will sync with my desktop. It now looks like I can’t even import calendars or contacts.
None of this is rocket science. J-Pilot which works with my aged but reliable Palm Treo, was written (decades ago) and maintained by one guy, works and syncs with my desktop through USB.
I am very disappointed with my Jolla experience.
:frowning:
Having the guides accessible would help.
There are many Linux systems.
Linux ≠ Ubuntu, or other compatible WM.
Regarding calendar import, here is one of the GUI methods:
-Plug the phone
-Chose MTP
-Copy .ics to e.g. Documents
-Open Settings
-Scroll to, and open Storage
-Press the user data circle
-Press Documents
-Scroll to, and click your .ics file.
-Click “Import”
-Enjoy
I believe this is what you speak of…
Those steps worked for me!
@Hillmorton I would add that once you open Settings →Storage, tap on the User Data circle graph to access the Document folder or wherever you might have saved the imported .ics file.
I say this only because for years I didn’t realise you could proceed past that initial Storage page, what a noob!
Thanks for the helpful links!
:face_with_hand_over_mouth: Oh, yes, I forgot.
I’ll correct for further reference, in case…
Thanks
I think a replacement for the original official Jolla guide would be welcome. A guide that can be printed. I did that in 2014 but that guide is now considered to be outdated.
I just tried this, going via Settings/Storage/Downloads instead of via File Browser.
I am happy to report that it worked and I have imported my calendar and contacts and I now have a usable C2.
:slight_smile:
Thanks for that.
That looks very useful.
Thanks.
:slight_smile:
